I am getting this error message, and “Compute mode” is default and no other process is using.
Could some one has an idea how to fix this?
I am using “GeForce RTX 2080” on Ubuntu 18.04, and used the below deb to install cuda drivers
Thank you.
ERROR MSG
- all CUDA-capable devices are busy or unavailabl
CUDA
- LINUX
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=18.04
DISTRIB_CODENAME=bionic
DISTRIB_DESCRIPTION=“Ubuntu 18.04.1 LTS”
- nvidia-sma -a
==============NVSMI LOG==============
Timestamp : Wed Oct 31 01:15:10 2018
Driver Version : 410.48
Attached GPUs : 1
GPU 00000000:03:00.0
Product Name : GeForce RTX 2080
Product Brand : GeForce
Display Mode : Disabled
Display Active : Disabled
Persistence Mode : Disabled
Accounting Mode : Disabled
Accounting Mode Buffer Size : 4000
Driver Model
Current : N/A
Pending : N/A
Serial Number : N/A
GPU UUID : GPU-cd23c077-022c-bbd9-7313-fd050a0c0423
Minor Number : 0
VBIOS Version : 90.04.0B.00.86
MultiGPU Board : No
Board ID : 0x300
GPU Part Number : N/A
Inforom Version
Image Version : G001.0000.02.04
OEM Object : 1.1
ECC Object : N/A
Power Management Object : N/A
GPU Operation Mode
Current : N/A
Pending : N/A
GPU Virtualization Mode
Virtualization mode : None
PCI
Bus : 0x03
Device : 0x00
Domain : 0x0000
Device Id : 0x1E8710DE
Bus Id : 00000000:03:00.0
Sub System Id : 0x350019DA
GPU Link Info
PCIe Generation
Max : 3
Current : 3
Link Width
Max : 16x
Current : 16x
Bridge Chip
Type : N/A
Firmware : N/A
Replays since reset : 0
Tx Throughput : 0 KB/s
Rx Throughput : 0 KB/s
Fan Speed : 30 %
Performance State : P0
Clocks Throttle Reasons
Idle : Not Active
Applications Clocks Setting : Not Active
SW Power Cap : Not Active
HW Slowdown : Not Active
HW Thermal Slowdown : Not Active
HW Power Brake Slowdown : Not Active
Sync Boost : Not Active
SW Thermal Slowdown : Not Active
Display Clock Setting : Not Active
FB Memory Usage
Total : 7952 MiB
Used : 0 MiB
Free : 7952 MiB
BAR1 Memory Usage
Total : 256 MiB
Used : 2 MiB
Free : 254 MiB
Compute Mode : Default
Utilization
Gpu : 0 %
Memory : 0 %
Encoder : 0 %
Decoder : 0 %
Encoder Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
Ecc Mode
Current : N/A
Pending : N/A
ECC Errors
Volatile
Single Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
Texture Memory : N/A
Texture Shared : N/A
CBU : N/A
Total : N/A
Double Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Aggregate
Single Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Double Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Retired Pages
Single Bit ECC : N/A
Double Bit ECC : N/A
Pending : N/A
Temperature
GPU Current Temp : 33 C
GPU Shutdown Temp : 100 C
GPU Slowdown Temp : 97 C
GPU Max Operating Temp : 88 C
Memory Current Temp : N/A
Memory Max Operating Temp : N/A
Power Readings
Power Management : Supported
Power Draw : 1.00 W
Power Limit : 225.00 W
Default Power Limit : 225.00 W
Enforced Power Limit : 225.00 W
Min Power Limit : 105.00 W
Max Power Limit : 250.00 W
Clocks
Graphics : 1515 MHz
SM : 1515 MHz
Memory : 7000 MHz
Video : 1395 MHz
Applications Clocks
Graphics : N/A
Memory : N/A
Default Applications Clocks
Graphics : N/A
Memory : N/A
Max Clocks
Graphics : 2205 MHz
SM : 2205 MHz
Memory : 7000 MHz
Video : 1950 MHz
Max Customer Boost Clocks
Graphics : N/A
Clock Policy
Auto Boost : N/A
Auto Boost Default : N/A
Processes : None
