The OpenGL API has been around for many years now. So, after many a frustrating error message like “invalid argument”, why do we still see these same “informative” messages from CUDA?
It’s logical to ask what argument was “invalid” and why? We just know that deep in the API code there’s some “if” statement checking an argument against its legal values. Is it too much ask that the argument name be reported?
Since the error system is asynchronous, why not report the name of the function called? (See macros below.) Every little hint helps dear API writers.
In general, if you are going to report an error condition, report the predicate and its arguments. (who, what, where, when)
After gaining the advantages of exception handling in C++, why do we have to devolve back to some error prone API with every new hardware technology? Having to use SAFE_CALL macros really looks pretty doesn’t it? Yes, I understand “C” as an LCD, but it’s costing me time and frustration. OpenCL looks even worse.
Wouldn’t it be better to apply a set standards for improving error reporting across the code base than to wait for customers to report issues one function at a time?
So, one rule would be that for every statement of the form (roughly)
if( (arg) )
return failure_enum;
should be:
if( (arg) )
msg += “”;
msg += “arg”;
report_error( msg );
return failure_id;
e.g.
if( 0 == ptr )
std::string msg = "nil pointer for arg: ptr in function: "; // replace with 'C' string stuff
msg += FUNCTION_SCOPE;
return cudaBadArgument;
Best I can tell, the bug reporting is done via a forum.
