Hi there,
I’m trying to use cuda-gdb (32 bits, from CUDA 2.1) on a 64 bits Linux machine.
I have a proper multilib environment, I can compile all my stuff in 32 bits with -m32 for gcc and nvcc without any problem, but I have problem with “nvcc -g -G”, which is needed by cuda-gdb.
Apparently the -m32 option is not passed correctly to ptxas nor to the linker, and I had to add “-Xptxas -m32” to get ptxas working. For the linker, it’s even worse: adding “-Xlinker -melf_i386” is not enough, and I had to write a little script that is before “ld” on my path and that calls the real /usr/bin/ld with the proper parameters to make it work in 32 bits mode.
But now I’m stuck to another error during the final link. Undefined references to things in the symbol table apparently…
Here is what I get using “nvcc -g -G -v”:
[codebox]
nvcc --compiler-bindir=gcc-4.1 --ptxas-options=-v -m32 -O0 -g -G -v -Xptxas -m32 -Xlinker -melf_i386 -c -o kernels_bicg.o kernels_bicg.cu
#$ ptxas --key=“b7df5b781a61e779” -arch=sm_10 --debug-info “/tmp/tmpxft_00006332_00000000-6_kernels_bicg.sm_10.cubin.dwarf.s” --translation-map “/tmp/tmpxft_00006332_00000000-6_kernels_bicg.sm_10.cubin.ptxmap” --link-info “kernels_bicg.linkinfo” -v -m32 --dont-merge-basicblocks --return-at-end “/tmp/tmpxft_00006332_00000000-2_kernels_bicg.ptx” -o “/tmp/tmpxft_00006332_00000000-6_kernels_bicg.sm_10.cubin”
#$ ld -r -o “kernels_bicg.o” “/tmp/tmpxft_00006332_00000000-11_tmpxft_00006332_00000000-6_kernels_bicg.sm_10.cubin.dwarf.o” “/tmp/tmpxft_00006332_00000000-14_kernels_bicg.o”
g++ -Wall -m32 -L/home/me/lib32 -L/emul/ia32-linux/usr/lib -lm -lcudart -lcublas -g -o my_app all_my_files.o kernels_bicg.o
kernels_bicg.o: In function `$$SymbolTable’:
(.nv11Segment+0x16c): undefined reference to `$gpu_registers’
(.nv11Segment+0x244): undefined reference to `blockDim’
(.nv11Segment+0x250): undefined reference to `gridDim’
(.nv11Segment+0x25c): undefined reference to `blockIdx’
(.nv11Segment+0x268): undefined reference to `threadIdx’
collect2: ld returned 1 exit status
make: *** [solver] Error 1
[/codebox]
gcc/g++ version is 4.3 (with gcc 4.1 installed in a subdir and used by nvcc as gcc 4.3 is not supported by nvcc)
Does someone know how I could fix that? Is there a nice way that doesn’t involve launching 42 commands each with 17 parameters?
Thanks in advance! :)
