One fotran program bench.f and one cuda interface Cuda_kernel.cu
When not adding ¨-G¨ there is no error during compiling.
For debugging device code, ¨-G¨ option is added as follows. But errors exist.
What is wrong?
mpif77 -c -g -O3 bench.f
nvcc -c -g -G -O3 Cuda_kernel.cu
mpif77 -o lxp-cuda bench.o Cuda_kernel.o -L/usr/local/cuda/lib -lcudart
Cuda_kernel.o: In function $$SymbolTable': (.nv10Segment+0x80): undefined reference to $gpu_registers’
Cuda_kernel.o: In function $$SymbolTable': (.nv10Segment+0x110): undefined reference to blockDim’
Cuda_kernel.o: In function $$SymbolTable': (.nv10Segment+0x11c): undefined reference to gridDim’
Cuda_kernel.o: In function $$SymbolTable': (.nv10Segment+0x128): undefined reference to blockIdx’
Cuda_kernel.o: In function $$SymbolTable': (.nv10Segment+0x134): undefined reference to blockIdx’
collect2: ld return 1
make: *** [lxp-cuda] Error 1
You need to compile ptxvars.cu and link with it. When you run nvcc in default mode it will compile, and link and do this automatically for you. If you only compile (-c) this is not done automatically. So what you need to do is :
