I am quite new to cuda.
Currently I am using cuda 2.2 on ubuntu 64 bit machine.
when I tried to compile with -G option, I have received the below error,
$ nvcc -g -G incrementArray.cu
gcc: /usr/local/cuda/bin/ptxvars.cu: No such file or directory
gcc: warning: ‘-x c++’ after last input file has no effect
gcc: no input files
I cant find ptxvars.cu in /usr/local/cuda/bin/.
gcc: no input files
Sounds like something went wrong with your installation?
This is the contents of my ptxvars, if you wanna try copy/paste
nvcc ptxvars.cu -g -G --host-compilation=c -c -D__DEVICE_LAUCH_PARAMETERS_H__ -Xptxas -fext
typedef struct dim3_16 {
unsigned short x, y, z;
} dim3_16;
typedef struct dim2_16 {
unsigned short x, y;
} dim2_16;
shared dim3_16 threadIdx;
shared dim2_16 blockIdx;
shared dim3_16 blockDim;
shared dim2_16 gridDim;
int $gpu_registers[128];
} dim3_16;
} dim2_16;
thank you Letharion
a re-installation did solve my problem
