I have visual studio code set up with Nsight. My code runs remotely through ssh on a server with a 1080Ti. The following code will catch breakpoints (I placed one on line 5):
#include<string>
int main(){
// std::string test;
return 0;
with the following cuda-gdb output:
NVIDIA (R) CUDA Debugger
11.1 release
Portions Copyright (C) 2007-2020 NVIDIA Corporation
GNU gdb (GDB) 8.3.1
Copyright (C) 2019 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
Type "show copying" and "show warranty" for details.
This GDB was configured as "x86_64-pc-linux-gnu".
Type "show configuration" for configuration details.
For bug reporting instructions, please see:
<http://www.gnu.org/software/gdb/bugs/>.
Find the GDB manual and other documentation resources online at:
<http://www.gnu.org/software/gdb/documentation/>.
For help, type "help".
Type "apropos word" to search for commands related to "word".
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib64/libthread_db.so.1".
Breakpoint 1, main () at test.cu:5
5 return 0;
When uncommenting the line:
#include<string>
int main(){
std::string test;
return 0;
the breakpoint is not hit anymore, and the following output is given:
11.1 release
GNU gdb (GDB) 8.3.1
[Inferior 1 (process 53318) exited with code 01]
Then, when manually running cuda-gdb and placing the breakpoint, it does hit it:
11.1 release
GNU gdb (GDB) 8.3.1
Type "apropos word" to search for commands related to "word"...
Reading symbols from Testing/a.out...
(cuda-gdb) break 5
Breakpoint 1 at 0x403ab3: file test.cu, line 5.
(cuda-gdb) run
Starting program: /home/heemsjan/Testing/a.out
warning: File "/opt/apps/software/GCCcore/10.2.0/lib64/libstdc++.so.6.0.28-gdb.py" auto-loading has been declined by your `auto-load safe-path' set to "$debugdir:$datadir/auto-load".
To enable execution of this file add
add-auto-load-safe-path /opt/apps/software/GCCcore/10.2.0/lib64/libstdc++.so.6.0.28-gdb.py
line to your configuration file "/home/heemsjan/.cuda-gdbinit".
To completely disable this security protection add
set auto-load safe-path /
For more information about this security protection see the
"Auto-loading safe path" section in the GDB manual. E.g., run from the shell:
info "(gdb)Auto-loading safe path"
5 return 0;
(cuda-gdb)
Is this a bug?
