Hello, I am having trouble figuring out why my cuda code runs slower than my cpu code
my desktop configuration is i7 2600S, geforce 560ti
and my code is as follows:
int** kernel_shiftSeam(int **MCEnergyMat, int **newE, int *seam, int width, int height, int direction)
//time measurement
float elapsed_time_ms = 0;
cudaEvent_t start, stop; //threads per block
dim3 threads(16,16);
//blocks
dim3 blocks((width+threads.x-1)/threads.x, (height+threads.y-1)/threads.y);
int *device_Seam;
int *host_Seam;
int seamSize;
if(direction == 1)
seamSize = height*sizeof(int);
host_Seam = (int*)malloc(seamSize);
for(int i=0;i<height;i++)
host_Seam[i] = seam[i];
else
seamSize = width*sizeof(int);
for(int i=0;i<width;i++)
cudaMalloc((void**)&device_Seam, seamSize);
cudaMemcpy(device_Seam, host_Seam, seamSize, cudaMemcpyHostToDevice);
global_host_MC = MCEnergyMat;
new_host_MC = newE;
//copy host array to device
cudaMemcpy(global_MC, global_MC2, sizeof(int*)*width, cudaMemcpyHostToDevice);
cudaMemcpy(global_MC2[i], global_host_MC[i], sizeof(int)*height, cudaMemcpyHostToDevice);
cudaMemcpy(new_MC, new_MC2, sizeof(int*)*width, cudaMemcpyHostToDevice);
cudaMemcpy(new_MC2[i], new_host_MC[i], sizeof(int)*height, cudaMemcpyHostToDevice);
cudaEventCreate(&start);
cudaEventCreate(&stop);
cudaEventRecord(start, 0);
//do some operations on the 2d matrix
gpu_shiftSeam<<< blocks,threads >>>(global_MC, new_MC, device_Seam, width, height);
//measure end time for cpu calcuations
cudaEventRecord(stop, 0);
cudaEventSynchronize(stop);
cudaEventElapsedTime(&elapsed_time_ms, start, stop );
execTime += elapsed_time_ms;
//copy out the data back to host (RESULT)
cudaMemcpy(newE[i], new_MC2[i], sizeof(int)*height, cudaMemcpyDeviceToHost);
return newE;
I looped it 800 times and I got the follow results:
GPU
Computation Time (the gpu_shiftseam part) : 1176ms
Total program run time: 22s
CPU
Computation Time (same operation as gpu_shiftseam but on host) : 12522ms
Total program run time: 12s
Apparently the GPU computation time is way shorter than the one on CPU, but
for some reason the total program run time for gpu is a lot longer, does
anyone know why? Is it because of the number of threads/blocks I am assigning
is incorrect? Or is the “slowness” coming from allocating memory on device?
Thanks a lot!
