GPU vs. CPU GPU is always much slower
Hey there,
I’m hoping to use CUDA on an image processing project: a very simple kernel that calculates the intensity of each pixel by summing each color channel (RGB) together. Each thread will handle one pixel of the image (1600x1200) and I’ve tried passing the pixel data in as either a uchar4 type or else I’ve tried creating a 2D array in global device memory using cudaMallocPitch() and cudaMemcpy2D() and passing in a pointer to that image array.
However, even if commenting out all the instructions of the kernel, the GPU is always several times slower than a reference implementation running on the CPU. I’ve included some dummy code that- while the data type being passed is different, I’m allocating memory in my program the same way.
I’m using Visual Studio 2008. I’ve ran the following code on a laptop Quadro FX 570M. The CPU took .05sec, when the GPU portion ran, the screen blinked black and took ~6seconds. I copied the Visual Studio project to a desktop Tesla C1060 and the CPU was .04sec while the GPU jumped to ~20seconds.
I can’t understand the performance differences. I’m not sure if I’m allocating blocks and threads in the correct dimensions. Changing the array size to less than 512 causes the Quadro laptop to take 17seconds on the GPU while the Tesla GPU executes in .5secs and the CPU in 0.00sec. I’m not sure if there are some Visual Studio issues occuring either. Changing between debug and release mode affects only the GPU speed (Running the template bandwidth test in debug mode causes the device<->device bandwidth to slow to .5GB/sec). Also, I’m not sure if the VS compiler settings are being correctly set/managed.
I’m really lost on what can be done to manage performance. Any help would be incredibly appreciated.
#include <stdio.h>
#include <cuda.h>
void CPU(int n, int alpha, int *x, int *y);
int iDivUp(int a, int b) // Round a / b to nearest higher integer value
	{ return (a % b != 0) ? (a / b + 1) : (a / b); }
int iAlignUp(int a, int b) // Align a to nearest higher multiple of b
	{ return (a % b != 0) ?  (a - a % b + b) : a; }
/** Kernel Definition **/
__global__ void GPU(int n, int alpha, int *x, int *y)
	int i = blockIdx.x * blockDim.x + threadIdx.x;
	if (i<n) y[i] = alpha*x[i] + y[i];
{	for (int i=0; i<n; i++) y[i] = alpha*x[i] + y[i];	}
/** Host Definition **/
int main(void)
	cudaSetDevice(0);
	int timingLoops=10000;
	int n=5000;
	int arraySize = n*sizeof(int);
	int *x = (int *) malloc(arraySize);
	for (int i=0; i<n; i++) x[i] = 1;
	int *x_devMem;
	cudaMalloc( (void**)&x_devMem, arraySize);
	cudaMemcpy(x_devMem, x, arraySize, cudaMemcpyHostToDevice);
	int *y = (int *) malloc(arraySize);
	int *y_devMem;
	cudaMalloc( (void**)&y_devMem, arraySize);
	/** CPU Calculation **/
	clock_t startTimeCPU, endTimeCPU;
	startTimeCPU = clock();
	for (int i=0; i<timingLoops; i++)
		CPU(n,2,x,y);
	endTimeCPU = clock();
	double secondsCPU = ((double)endTimeCPU - (double)startTimeCPU) / (double)CLOCKS_PER_SEC;
	printf ("Seconds to completion (CPU):  %f\n", secondsCPU);
	system("pause");
	/** GPU Calculation **/
	clock_t startTimeGPU, endTimeGPU;
	startTimeGPU = clock();
	dim3 dimBlock(8,16);
	dim3 dimGrid( iDivUp(n,dimBlock.x), iDivUp(n,dimBlock.y) );
		GPU<<<dimGrid, dimBlock>>>(n,2,x_devMem,y_devMem);
	endTimeGPU = clock();
	double secondsGPU = ((double)endTimeGPU - (double)startTimeGPU) / (double)CLOCKS_PER_SEC;
	printf ("\nSeconds to completion (GPU):  %f\n", secondsGPU);
	system("pause");
	cudaMemcpy(y, y_devMem, arraySize, cudaMemcpyDeviceToHost);
	cudaFree(x_devMem);
	cudaFree(y_devMem);
	free(x);
	free(y);
	return 0;
OK, let’s have a look here
AH
yes, what is happening is that you’re creating 2D blocks. That’s fine, even good. I think it’s better to have the blocks 16 threads (pixels) wide, you get nicer load memory load properties.
However, you’re creating an excessively big grid I think – your input array is only 1-dimensional but you’re allocating a 2D grid of 2D blocks
This grid/block config looks good for a 2D image array
What I’d do for this 1D array of size N:
int n = 5000;
int blockSize_X = 256;
int deviceArraySize = iAlignUp(n, 16); // to have some safety padding for the very last block, not needed but cheap
dim3 dimBlock(blockSize_X, 1); // each thread does 256 pixels
dim3 dimGrid(iAlignUp(n, blockSize_X), 1); // you get a grid that is (20, 1), or 20 blocks total --> 20 * 256 = 5120 threads
On the other hand, for a 2D image of size 1600x1200, you want a 2D grid of 2D blocks, around 7500 blocks of 256 threads. You’ll also need 2D array position calculations in the kernel. Here’s some hints, hope this gets you started:
int imageWidth = 1600;
int imageHeight = 1200;
int blockSize_X = 16;
int blockSize_Y = 16;
dim3 dimBlock(blockSize_X, blockSize_Y); // each thread does 16 * 16 = 256 pixels
dim3 dimGrid(iAlignUp(imageWidth, blockSize_X), iAlignUp(imageHeight, blockSize_Y); // you get a grid that is (100, 75), or 7500 blocks total --> 7500 * 256 = 1.920.000 threads = 1600 * 1200 pixels
// further down ...
__global__ void GPU(int width, int height, int alpha, int *x, int *y)
int i = blockIdx.y * width + blockIdx.x * blockDim.x + threadIdx.x; // jump blockIdx.y rows down, blockIdx.x times the blockWidth right, and jump threadIdx.x pixels more right
Confusing? :)
Have a look at the convolutionSeparable, I think that’s a good example for this. It’s a bit more complex than you need, but it’s worth a look. Also maybe the simple transpose example, that one reads blocks in a 2D array almost exactly like your program will.
