CUDA graphs error with cudaEventElapsedTime (cudaEventInvalidValue)
Hi everyone,
I recently started to work with the CUDA graph API. However, I bumped into some issues while trying to measure execution time of a part of my graph.
As suggested in another post, I tried to put two timing events in the graph through cudaEventRecord(), then calling cudaEventElapsedTime after the graph execution.
However, it seems I can’t get it right with this implementation. cudaEvents captured inside the graph cause a cudaEventInvalidValue when calling cudaEventElapsedTime() right after the graph execution.
I tried to change cudaEventRecord() with cudaEventRecordWithFlags(event, stream, cudaEventRecordExternal, but this unexpectedly slows down heavily the graph execution.
Am I doing something wrong? I’m not so sure that we can time event in a graph such as I do with «regular» CUDA programming. Thanks.
Example :
cudaGraph_t cuGraph;
cudaEvent_t start;
cudaEvent_t stop;
checkCudaErrors(cudaEventCreate(&start));
checkCudaErrors(cudaEventCreate(&stop));
int count = 0;
checkCudaErrors(cudaStreamBeginCapture(stream, cudaStreamCaptureModeGlobal));
randomKernel<<<1,1,0,stream>>>(…);
checkCudaErrors(cudaEventRecord(start, stream));
kernelWeWantToMeasure<<<1,1,0,stream>>>(…);
checkCudaErrors(cudaEventRecord(stop, stream));
checkCudaErrors(cudaStreamEndCapture(stream, &cuGraph));
cudaGraphExec_t graphExec = NULL;
checkCudaErrors(cudaGraphInstantiate(&graphExec, cuGraph, NULL, NULL, 0));
//cudaGraphDebugDotPrint(cuGraph, “debugGraphTimer.txt”, 0);
checkCudaErrors(cudaGraphDestroy(cuGraph));
for (int k = 0; k < maxIter; k++) {
checkCudaErrors(cudaGraphLaunch(graphExec, stream));
checkCudaErrors(cudaStreamSynchronize(stream));
checkCudaErrors(cudaEventElapsedTime(&times[k], start, stop));
that seems to be the way to go
according to my simple test, it adds about 5us to the graph execution:
$ cat t1975.cu
#include <helper_cuda.h>
#include <iostream>
#include <time.h>
#include <sys/time.h>
#define USECPSEC 1000000ULL
unsigned long long dtime_usec(unsigned long long start=0){
  timeval tv;
  gettimeofday(&tv, 0);
  return ((tv.tv_sec*USECPSEC)+tv.tv_usec)-start;
__global__ void randomKernel(){};
int main(){
  const int maxIter=2;
  cudaStream_t stream;
  checkCudaErrors(cudaStreamCreate(&stream));
#ifdef USE_EVENT
  float times[maxIter];
  cudaEvent_t start;
  cudaEvent_t stop;
#endif
  randomKernel<<<1,1,0,stream>>>();
#ifdef USE_EVENT
  checkCudaErrors(cudaEventRecordWithFlags(start, stream,cudaEventRecordExternal));
#endif
#ifdef USE_EVENT
  checkCudaErrors(cudaEventRecordWithFlags(stop, stream,cudaEventRecordExternal));
#endif
    long long dt = dtime_usec(0);
    dt = dtime_usec(dt);
    std::cout << "graph elapsed time: " << dt  << "us" << std::endl;
#ifdef USE_EVENT
    std::cout << "event elapsed time: " <<  times[k] << "ms" <<  std::endl;
#endif
$ nvcc -o t1975 t1975.cu -I/usr/local/cuda/samples/common/inc -DUSE_EVENT
$ ./t1975
graph elapsed time: 49us
event elapsed time: 0.004992ms
graph elapsed time: 19us
event elapsed time: 0.004192ms
$ ./t1975
graph elapsed time: 44us
graph elapsed time: 14us
You are right! Using cudaEventRecordWithFlags seems to be the way to go. I should have used a simpler test case such as yours. In my program, it is a host callback which seems to be slowing down my pipeline, but this is not relevant in this thread.
Thank you for your fast reply!
