I’m using l4t-r32.4.3 based yocto environment. When I try to compile my cuda program I’m stuck with the following compiler issue that #include_next math.h
not found.
I found this issue with both gcc versions 7.3.0 and 8.3.0. I’m using cmake
enable_laguage(cuda)
to enable cuda compilation.
How to get rid of this issue? I have noticed that the cuda is using isystem to include the files rather than -I.
| In file included from work/armv8a_tegra194-oe4t-linux/testsoftware/6.x.y-r0/recipe-sysroot-native/usr/local/cuda-10.2/bin/..//include/crt/math_functions.h:8841:0,
| from /work/armv8a_tegra194-oe4t-linux/testsoftware/6.x.y-r0/recipe-sysroot-native/usr/local/cuda-10.2/bin/..//include/crt/common_functions.h:267,
| from /work/armv8a_tegra194-oe4t-linux/testsoftware/6.x.y-r0/recipe-sysroot-native/usr/local/cuda-10.2/bin/..//include/cuda_runtime.h:115,
| from <command-line>:0:
| /work/armv8a_tegra194-oe4t-linux/testsoftware/6.x.y-r0/recipe-sysroot/usr/include/c++/7.3.0/cmath:45:15: fatal error: math.h: No such file or directory
| #include_next <math.h>
| compilation terminated.
