I’m running into an issue building OpenCV 4 on my Xavier. Cmake can’t find CUDA.
Running nvcc --version I get:
Copyright (c) 2005-2019 NVIDIA Corporation
Built on Wed_Oct_23_21:14:42_PDT_2019
Cuda compilation tools, release 10.2, V10.2.89
I can locate CUDA at /usr/local/cuda-8.0
My initial command was
cmake -D CMAKE_BUILD_TYPE=RELEASE \
-D CMAKE_INSTALL_PREFIX=/usr/local \
-D INSTALL_PYTHON_EXAMPLES=ON \
-D INSTALL_C_EXAMPLES=OFF \
-D OPENCV_ENABLE_NONFREE=ON \
-D WITH_CUDA=ON \
-D WITH_CUDNN=ON \
-D OPENCV_DNN_CUDA=ON \
-D ENABLE_FAST_MATH=1 \
-D CUDA_FAST_MATH=1 \
-D CUDA_ARCH_BIN=7.2 \
-D WITH_CUBLAS=1 \
-D OPENCV_EXTRA_MODULES_PATH=~/opencv_contrib/modules \
-D HAVE_opencv_python3=ON \
-D PYTHON_EXECUTABLE=~/.virtualenvs/opencv_cuda/bin/python \
-D BUILD_EXAMPLES=ON ..
After digging into the Cmake files, I discovered the param CUDA_BIN_PATH can be passed to specify the cuda path.
However, that still doesn’t work. I tried both as a param to the command and as an env var set before executing the command, it still won’t find CUDA.
I tried both CUDA_BIN_PATH=/usr/local/cuda-8.0 and CUDA_BIN_PATH=/usr/local/cuda-8.0/bin
I tried to build with and without a virtual env. I tried with and without sudo. Failing in all cases.
I have ran out of options to explore.
Here is the terminal output:
~/opencv/build$ cmake -D CMAKE_BUILD_TYPE=RELEASE -D CMAKE_INSTALL_PREFIX=/usr/local -D INSTALL_PYTHON_EXAMPLES=ON -D INSTALL_C_EXAMPLES=OFF -D OPENCV_ENABLE_NONFREE=ON -D WITH_CUDA=ON -D WITH_CUDNN=ON -D OPENCV_DNN_CUDA=ON -D ENABLE_FAST_MATH=1 -D CUDA_FAST_MATH=1 -D CUDA_ARCH_BIN=7.2 -D WITH_CUBLAS=1 -D OPENCV_EXTRA_MODULES_PATH=~/opencv_contrib/modules -D HAVE_opencv_python3=ON -D PYTHON_EXECUTABLE=~/.virtualenvs/opencv_cuda/bin/python -D BUILD_EXAMPLES=ON -D CUDA_BIN_PATH=/usr/local/cuda-8.0 ..
-- Detected processor: aarch64
-- Looking for ccache - not found
-- Found ZLIB: /usr/lib/aarch64-linux-gnu/libz.so (found suitable version "1.2.11", minimum required is "1.2.3")
-- Could NOT find Jasper (missing: JASPER_LIBRARIES JASPER_INCLUDE_DIR)
-- Found ZLIB: /usr/lib/aarch64-linux-gnu/libz.so (found version "1.2.11")
CMake Warning at cmake/OpenCVFindLibsPerf.cmake:35 (message):
OpenCV is not able to find/configure CUDA SDK (required by WITH_CUDA).
CUDA support will be disabled in OpenCV build.
To eliminate this warning remove WITH_CUDA=ON CMake configuration option.
Anybody ran into this issues, or know what I could attempt to fix it?
