Dear Team,
I have a jetson nano 4gb B01 with 16gb emmc. I installed the os, then CUDA and other tools through sdkmanager. I used a flash script to change rootfs to external usb drive.(Change Root File System to SD Card Directly).
After booting from usb drive, i upgraded opencv to 4.5.1. On trying to install ncnn, the cmake fails with the following error
cmake -DCUDAToolkit_ROOT=/usr/local/cuda-10.2 -D CMAKE_TOOLCHAIN_FILE=../toolchains/jetson.toolchain.cmake -D NCNN_DISABLE_RTTI=OFF -D NCNN_BUILD_TOOLS=ON -D NCNN_VULKAN=ON -D CMAKE_BUILD_TYPE=Release ..
CMake Warning at CMakeLists.txt:279 (message):
The compiler does not support armv8.2 fp16. NCNN_ARM82 will be OFF.
-- Target arch: arm 64bit
CMake Error at /usr/local/share/cmake-3.19/Modules/FindPackageHandleStandardArgs.cmake:218 (message):
Could NOT find CUDA (missing: CUDA_TOOLKIT_ROOT_DIR CUDA_INCLUDE_DIRS
CUDA_CUDART_LIBRARY) (found suitable exact version "10.2")
jtop (jetson-stats) also shows CUDA, Opwncv with CUDA: YES
The cuda paths are as below:
nvidia@ubuntu:~$ ls /usr/local/cuda*
/usr/local/cuda:
bin doc include nvvm share version.json
cuda EULA.txt lib64 nvvmx targets version.txt
cuda-10.2 extras nvml samples tools
/usr/local/cuda-10:
/usr/local/cuda-10.2:
Opencv was built using CUDA so CUDA is ofcourse installed but for some reason cmake for ncnn is not able to read it.
I have also added it to the path in bashrc.
I have no idea where to go from this.
