Could NOT find CUDA (missing: CUDA_TOOLKIT_ROOT_DIR CUDA_NVCC_EXECUTABLE
I am working on Nvidia Xavier AGX hardware, I am trying to build one application which is using OpenCV. But when i compile this application I get following error.
| CUDA_INCLUDE_DIRS CUDA_CUDART_LIBRARY) (Required is exact version “10.2”)
I am using following items in image file.
IMAGE_INSTALL += “cuda-libraries cuda-nvcc cuda-nvtx cuda-nvml cudnn”
IMAGE_INSTALL += “cuda-cudart cuda-cudart-dev”
IMAGE_INSTALL += “cuda-misc-headers cuda-misc-headers-dev”
IMAGE_INSTALL += “cuda-misc-headers-container-csv”
IMAGE_INSTALL += “cuda-cusparse cuda-cusparse-dev”
IMAGE_INSTALL += “cuda-cusolver cuda-cusolver-dev”
IMAGE_INSTALL += “libcublas libcublas-dev”
IMAGE_INSTALL += “cuda-toolkit cuda-target-environment cuda-npp”
IMAGE_INSTALL += “cuda-command-line-tools cuda-nvcc-headers”
I request you to please help me in resolving it.
Regards,
Hariom
Hi
it looks like you dont have CUDA installed. Can you try to re-install CUDA either via SDKmanager (re-flash AGX) or manually :
Hi @neel_patel,
Thanks for reply,
I am having CUDA installed in my system and i verified it by checking the /usr/local folder.
Have you set the path variable correctly ?
https://docs.nvidia.com/cuda/cuda-installation-guide-linux/index.html#post-installation-actions
