Did you only install the “cuda-repo-l4t-10-2-local-10.2.89_1.0-1_arm64.deb”? Or did you install other packages?
With the repo installed you can “sudo apt update”, and then install actual CUDA. The repo just tells apt how to find the repository which has the CUDA content.
The following is from an NX, but the list should similar to what you see with command “dpkg -l | egrep -i 'cuda'”:
EDIT: This was from my PC, same idea, but will add the packages I see for NX below (I remote ssh to my NX, must’ve used the wrong terminal).
ii cuda-command-line-tools-10-2 10.2.89-1 amd64 CUDA command-line tools
ii cuda-compiler-10-2 10.2.89-1 amd64 CUDA compiler
ii cuda-cross-aarch64-10-2 10.2.89-1 all CUDA 10.2 cross-platform meta-package
ii cuda-cudart-10-2 10.2.89-1 amd64 CUDA Runtime native Libraries
ii cuda-cudart-cross-aarch64-10-2 10.2.89-1 all CUDA Runtime cross-aarch64 dev links, headers
ii cuda-cudart-dev-10-2 10.2.89-1 amd64 CUDA Runtime native dev links, headers
ii cuda-cufft-10-2 10.2.89-1 amd64 CUFFT native runtime libraries
ii cuda-cufft-cross-aarch64-10-2 10.2.89-1 all CUFFT cross-aarch64 dev links, headers
ii cuda-cufft-dev-10-2 10.2.89-1 amd64 CUFFT native dev links, headers
ii cuda-cuobjdump-10-2 10.2.89-1 amd64 CUDA cuobjdump
ii cuda-cupti-10-2 10.2.89-1 amd64 CUDA profiling tools runtime libs.
ii cuda-cupti-cross-aarch64-10-2 10.2.89-1 all CUDA cross-aarch64 profiling tools interface.
ii cuda-cupti-dev-10-2 10.2.89-1 amd64 CUDA profiling tools interface.
ii cuda-curand-10-2 10.2.89-1 amd64 CURAND native runtime libraries
ii cuda-curand-cross-aarch64-10-2 10.2.89-1 all CURAND cross-aarch64 dev links, headers
ii cuda-curand-dev-10-2 10.2.89-1 amd64 CURAND native dev links, headers
ii cuda-cusolver-10-2 10.2.89-1 amd64 CUDA solver native runtime libraries
ii cuda-cusolver-cross-aarch64-10-2 10.2.89-1 all CUSOLVER cross-aarch64 dev links, headers
ii cuda-cusolver-dev-10-2 10.2.89-1 amd64 CUDA solver native dev links, headers
ii cuda-cusparse-10-2 10.2.89-1 amd64 CUSPARSE native runtime libraries
ii cuda-cusparse-cross-aarch64-10-2 10.2.89-1 all CUSPARSE cross-aarch64 dev links, headers
ii cuda-cusparse-dev-10-2 10.2.89-1 amd64 CUSPARSE native dev links, headers
ii cuda-documentation-10-2 10.2.89-1 amd64 CUDA documentation
ii cuda-driver-cross-aarch64-10-2 10.2.89-1 all CUDA Driver cross-aarch64 dev links, headers
ii cuda-driver-dev-10-2 10.2.89-1 amd64 CUDA Driver native dev stub library
ii cuda-gdb-10-2 10.2.89-1 amd64 CUDA-GDB
ii cuda-libraries-10-2 10.2.89-1 amd64 CUDA Libraries 10.2 meta-package
ii cuda-libraries-dev-10-2 10.2.89-1 amd64 CUDA Libraries 10.2 development meta-package
ii cuda-license-10-2 10.2.89-1 amd64 CUDA licenses
ii cuda-memcheck-10-2 10.2.89-1 amd64 CUDA-MEMCHECK
ii cuda-misc-headers-10-2 10.2.89-1 amd64 CUDA miscellaneous headers
ii cuda-misc-headers-cross-aarch64-10-2 10.2.89-1 all CUDA headers for cross-aarch64
ii cuda-npp-10-2 10.2.89-1 amd64 NPP native runtime libraries
ii cuda-npp-cross-aarch64-10-2 10.2.89-1 all NPP cross-aarch64 dev links, headers
ii cuda-npp-dev-10-2 10.2.89-1 amd64 NPP native dev links, headers
ii cuda-nsight-10-2 10.2.89-1 amd64 CUDA nsight
ii cuda-nsight-compute-10-2 10.2.89-1 amd64 NVIDIA Nsight Compute
ii cuda-nsight-compute-addon-l4t-10-2 10.2.89-1 all NVIDIA Nsight Compute Addon
ii cuda-nsight-systems-10-2 10.2.89-1 amd64 NVIDIA Nsight Systems
ii cuda-nvcc-10-2 10.2.89-1 amd64 CUDA nvcc
ii cuda-nvdisasm-10-2 10.2.89-1 amd64 CUDA disassembler
ii cuda-nvgraph-10-2 10.2.89-1 amd64 NVGRAPH native runtime libraries
ii cuda-nvgraph-cross-aarch64-10-2 10.2.89-1 all NVGRAPH cross-aarch64 dev links, headers
ii cuda-nvgraph-dev-10-2 10.2.89-1 amd64 NVGRAPH native dev links, headers
ii cuda-nvjpeg-10-2 10.2.89-1 amd64 NVJPEG native runtime libraries
ii cuda-nvjpeg-dev-10-2 10.2.89-1 amd64 NVJPEG native dev links, headers
ii cuda-nvml-cross-aarch64-10-2 10.2.89-1 all NVML cross-aarch64 dev links, headers
ii cuda-nvml-dev-10-2 10.2.89-1 amd64 NVML native dev links, headers
ii cuda-nvprof-10-2 10.2.89-1 amd64 CUDA Profiler tools
ii cuda-nvprune-10-2 10.2.89-1 amd64 CUDA nvprune
ii cuda-nvrtc-10-2 10.2.89-1 amd64 NVRTC native runtime libraries
ii cuda-nvrtc-cross-aarch64-10-2 10.2.89-1 all NVRTC cross-aarch64 dev links, headers
ii cuda-nvrtc-dev-10-2 10.2.89-1 amd64 NVRTC native dev links, headers
ii cuda-nvtx-10-2 10.2.89-1 amd64 NVIDIA Tools Extension
ii cuda-nvvp-10-2 10.2.89-1 amd64 CUDA nvvp
ii cuda-repo-cross-aarch64-10-2-local-10.2.89 1.0-1 all cuda repository configuration files
ii cuda-repo-ubuntu1804-10-2-local-10.2.89-440.40 1.0-1 amd64 cuda repository configuration files
ii cuda-samples-10-2 10.2.89-1 amd64 CUDA example applications
ii cuda-sanitizer-api-10-2 10.2.89-1 amd64 CUDA Sanitizer API
ii cuda-toolkit-10-2 10.2.89-1 amd64 CUDA Toolkit 10.2 meta-package
ii cuda-tools-10-2 10.2.89-1 amd64 CUDA Tools meta-package
ii cuda-visual-tools-10-2 10.2.89-1 amd64 CUDA visual tools
ii libcudart9.1:amd64 9.1.85-3ubuntu1 amd64 NVIDIA CUDA Runtime Library
ii libnvrtc9.1:amd64 9.1.85-3ubuntu1 amd64 CUDA Runtime Compilation (NVIDIA NVRTC Library)
ii nvidia-cuda-doc 9.1.85-3ubuntu1 all NVIDIA CUDA and OpenCL documentation
ii nvidia-cuda-gdb 9.1.85-3ubuntu1 amd64 NVIDIA CUDA Debugger (GDB)
ARM64 (there are other packages you can get, this is just what was on the NX at the moment):
ii cuda-compiler-10-2 10.2.89-1 arm64 CUDA compiler
ii cuda-core-10-2 10.2.89-1 arm64 CUDA core tools
ii cuda-cuobjdump-10-2 10.2.89-1 arm64 CUDA cuobjdump
ii cuda-license-10-2 10.2.89-1 arm64 CUDA licenses
ii cuda-misc-headers-10-2 10.2.89-1 arm64 CUDA miscellaneous headers
ii cuda-nvcc-10-2 10.2.89-1 arm64 CUDA nvcc
ii cuda-nvprune-10-2 10.2.89-1 arm64 CUDA nvprune
ii nvidia-l4t-cuda 32.4.3-20200625213407 arm64 NVIDIA CUDA Package
Those were installed when telling JetPack/SDKM to install CUDA to the Jetson. If you manually installed, then you would also have to consider using apt-get to install those other packages as well. The advantage of JetPack/SDKM being that it knows about all of those packages and just installs them.
NOTE: If you have those, then your CUDA may just not know where to find the CUDA content. You’d need your “$PATH” environment variable to include the right “bin/” directory at “/usr/local/cuda/bin/”.
