Troubles Installing CUDA cross compile LINUX in host
Hello, Im having some troubles installing the CUDA Cross compile in SDKManager. It’s already downloaded. Here are the logs
Everything is downloaded and installed, with exception from that component. It stops at 3 pcent and it always gives me the same error. I tried changing the HOST and tried the (Retry) button several times.
SDKM_logs_DRIVE_Software_10.0_(rev.2)_Linux_for_DRIVE_AGX_Developer_Kit_2022-03-25_12-15-17.zip (777.3 KB)
Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.7.1.8928
other
Host Machine Version
native Ubuntu 18.04
other
Hello. Here is the solution
After seeing in the terminal that a package was missing, I issued the following commands in the terminal tab
$ wget https://repo.download.nvidia.com/jetson/x86_64/pool/r32.4/c/cuda/cuda-npp-cross-aarch64-10-2_10.2.89-1_all.deb
$ sudo apt-get install -y cuda-npp-cross-aarch64-10-2
And I did that for the following packages that were causing the failure of the installation.
I would reccomend installing the following packages before going through the installation:
wget https://repo.download.nvidia.com/jetson/x86_64/pool/r32.4/c/cuda/cuda-cross-aarch64-10-2_10.2.89-1_all.deb &&
wget https://repo.download.nvidia.com/jetson/x86_64/pool/r32.4/c/cuda/cuda-cross-aarch64_10.2.89-1_all.deb &&
wget https://repo.download.nvidia.com/jetson/x86_64/pool/r32.4/c/cuda/cuda-cudart-cross-aarch64-10-2_10.2.89-1_all.deb &&
wget https://repo.download.nvidia.com/jetson/x86_64/pool/r32.4/c/cuda/cuda-cufft-cross-aarch64-10-2_10.2.89-1_all.deb &&
wget https://repo.download.nvidia.com/jetson/x86_64/pool/r32.4/c/cuda/cuda-cupti-cross-aarch64-10-2_10.2.89-1_all.deb &&
wget https://repo.download.nvidia.com/jetson/x86_64/pool/r32.4/c/cuda/cuda-curand-cross-aarch64-10-2_10.2.89-1_all.deb &&
wget https://repo.download.nvidia.com/jetson/x86_64/pool/r32.4/c/cuda/cuda-cusolver-cross-aarch64-10-2_10.2.89-1_all.deb &&
wget https://repo.download.nvidia.com/jetson/x86_64/pool/r32.4/c/cuda/cuda-cusparse-cross-aarch64-10-2_10.2.89-1_all.deb &&
wget https://repo.download.nvidia.com/jetson/x86_64/pool/r32.4/c/cuda/cuda-driver-cross-aarch64-10-2_10.2.89-1_all.deb &&
wget https://repo.download.nvidia.com/jetson/x86_64/pool/r32.4/c/cuda/cuda-misc-headers-cross-aarch64-10-2_10.2.89-1_all.deb &&
wget https://repo.download.nvidia.com/jetson/x86_64/pool/r32.4/c/cuda/cuda-npp-cross-aarch64-10-2_10.2.89-1_all.deb &&
wget https://repo.download.nvidia.com/jetson/x86_64/pool/r32.4/c/cuda/cuda-nsight-compute-addon-l4t-10-2_10.2.89-1_all.deb &&
wget https://repo.download.nvidia.com/jetson/x86_64/pool/r32.4/c/cuda/cuda-nvgraph-cross-aarch64-10-2_10.2.89-1_all.deb &&
wget https://repo.download.nvidia.com/jetson/x86_64/pool/r32.4/c/cuda/cuda-nvml-cross-aarch64-10-2_10.2.89-1_all.deb &&
wget https://repo.download.nvidia.com/jetson/x86_64/pool/r32.4/c/cuda/cuda-nvrtc-cross-aarch64-10-2_10.2.89-1_all.deb &&
wget https://repo.download.nvidia.com/jetson/x86_64/pool/r32.4/c/cublas/libcublas-cross-aarch64_10.2.2.89-1_all.deb &&
wget https://repo.download.nvidia.com/jetson/x86_64/pool/r32.4/n/nsight-compute/nsight-compute-addon-l4t-2019.5.0_2019.5.0.14-1_all.deb && \
And “sudo apt-get” each one of them.
Dear @Thommy_Dowling,
Note that the Jetson debians have different CUDA version than in DRIVE. It may cause issues due to version mismatch.
