- I have l4t 4.6 installed using the SDKManager
- I try to install 4.5.1 using the SDKManager and get a CUDA build error
14:42:28 INFO: CUDA Cross Compile Package on Host - host: Some packages could not be installed. This may mean that you have
14:42:28 INFO: CUDA Cross Compile Package on Host - host: requested an impossible situation or if you are using the unstable
14:42:28 INFO: CUDA Cross Compile Package on Host - host: distribution that some required packages have not yet been created
14:42:28 INFO: CUDA Cross Compile Package on Host - host: or been moved out of Incoming.
14:42:28 INFO: CUDA Cross Compile Package on Host - host: The following information may help to resolve the situation:
14:42:28 INFO: CUDA Cross Compile Package on Host - host: The following packages have unmet dependencies:
14:42:28 INFO: CUDA Cross Compile Package on Host - host: cuda-cross-aarch64-10-2 : Depends: cuda-cufft-cross-aarch64-10-2 (>= 10.2.89)14:42:28 INFO: CUDA Cross Compile Package on Host - host: Depends: cuda-curand-cross-aarch64-10-2 (>= 10.2.89)
14:42:28 INFO: CUDA Cross Compile Package on Host - host: Depends: cuda-npp-cross-aarch64-10-2 (>= 10.2.89)
14:42:28 ERROR: CUDA Cross Compile Package on Host - host: E
14:42:28 ERROR: CUDA Cross Compile Package on Host - host: :
14:42:28 ERROR: CUDA Cross Compile Package on Host - host: Unable to correct problems, you have held broken packages.
14:42:28 INFO: CUDA Cross Compile Package on Host - host: [ Package Install Finished with Error ]
14:42:28 INFO: CUDA Cross Compile Package on Host - host: [host] [ 16.00 KB used. Disk Avail: 57.96 GB ]
14:42:28 INFO: CUDA Cross Compile Package on Host - host: [ NV_CUDA_CROSS_HOST_COMP Install took 5s ]
14:42:28 ERROR: CUDA Cross Compile Package on Host - host: [error]: Error when apt install failed; [exec_command]: sudo apt-get update; sleep 0.5; sudo apt-get -y install cuda-cross-aarch64-10-2=10.2.89* ; [error]: exit status 100; [deb_path]: /home/asei/Downloads/nvidia/sdkm_downloads/cuda-repo-cross-aarch64-10-2-local-10.2.89_1.0-1_all.deb
14:42:28 ERROR: CUDA Cross Compile Package on Host - host: command terminated with error
14:42:28 SUMMARY: CUDA Cross Compile Package on Host - host: First Error: APT system is broken and requires manual fix
Here is the full Log
SDKM_logs_JetPack_4.5.1_Linux_for_Jetson_AGX_Xavier_2021-08-26_14-37-23.zip (145.8 KB)
There is another post similar to this: [Error while installing cuda on Host and Deepstream on target]
(Error while installing cuda on Host and Deepstream on target)
I am hesitant to do the sudo dpkg --purge <cuda_packages_listed_above> because of the 4.6 install.
