Hello, I am trying install jetpack 4.4. I am facing few issues with SDK manager
CUDA and Computer vision installation error.
My error is exactly similar to (Error while installing cuda on Host and Deepstream on target)
I followed the following steps
- Use
dpkg -l | grep cudacommand to list all CUDA packages. - Use
sudo dpkg --purge <cuda_packages_listed_above>command to remove CUDA packages one by one - Reinstall CUDA
and also i followed this step Error while installing cuda on Host and Deepstream on target - #8 by Bazziil
But I am facing the same error again
ERROR: CUDA on Host: E: Unable to correct problems, you have held broken packages.
I successfully installed jetpack 4.6 a few weeks ago.But, for my project, I needed to install Jetpack 4.4, so when I tried to install it, these issues began to appear, and if I tried to install the same Jetpack 4.6, the same errors appeared.
Any help or advise on this subject would be greatly appreciated!
