I try to install the sdk manager but everytime I try to run it i get a lot of error.
also if I try to the run the --fix-broken i get alot of these errors
the first command i use is sudo apt install ./sdkmanager_2.1.0=11660_amd64.deb
This is not related to SDK Manager at all.
Please fix your CUDA issue first.
I also can’t get cuda remove to start over or get it fixed with the command sudo apt --fix-broken install
sudo apt --purge autoremove <any of your failing CUDA deb>
See if autoremove works.
the cuda error’s are gone but now i have broken packages and i am not sure if it is safe to remove them
Looks like the Ubuntu version you are using is too old so dependencies are not available.
Anyway, always give full log in text, and don’t give screenshots.
the distro is ubuntu 20.04 from the nvidia jetson develop kit
Oh, right…
SDK Manager is for the host x86 host PC, and you cannot install it on Jetson…
Of course you don’t get amd64 packages on an arm64 machine.
just nvidia-jetpack isn’t installing or is that also not for the jetson. I thought it was compatible for the jetson.
devion@devion-desktop:~$ sudo apt install nvidia-jetpack
[sudo] password for devion:
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
nvidia-jetpack : Depends: nvidia-jetpack-runtime (= 5.1.1-b56) but it is not going to be installed
Depends: nvidia-jetpack-dev (= 5.1.1-b56) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.```
Try like:
i have tried almost everything that is on that page but it also doesn’t work
Then are you able to install nvidia-jetpack-runtime and nvidia-jetpack-dev separately?
Or re-flash the device to fix it.
that also doesn’t work
Then please re-flash the device.
