I get the following error when installing CUDA on a Jetson Nano. I have checked the dependencies with uname - r and they should be there
$sudo apt-get -y install cuda
Reading package lists… Done Building dependency tree Reading state information… Done cuda is already the newest version (11.0.1-1). You might want to run 'apt --fix-broken install' to correct these. The following packages have unmet dependencies: cuda-drivers-450 : Depends: libnvidia-compute-450 (>= 450.36.06) but it is not going to be installed Depends: libnvidia-gl-450 (>= 450.36.06) but it is not going to be installed libnvidia-decode-450 : Depends: libnvidia-compute-450 (= 450.36.06-0ubuntu1) but it is not going to be installed libnvidia-ifr1-450 : Depends: libnvidia-gl-450 but it is not going to be installed nvidia-compute-utils-450 : Depends: libnvidia-compute-450 but it is not going to be installed nvidia-driver-450 : Depends: libnvidia-gl-450 (= 450.36.06-0ubuntu1) but it is not going to be installed Depends: libnvidia-compute-450 (= 450.36.06-0ubuntu1) but it is not going to be installed nvidia-utils-450 : Depends: libnvidia-compute-450 but it is not going to be installed E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution). sudo apt-get install linux-headers-
$(uname -r) [sudo] password for gregory: Reading package lists… Done Building dependency tree Reading state information… Done E: Unable to locate package linux-headers-4.9.140-tegra E: Couldn't find any package by glob 'linux-headers-4.9.140-tegra' E: Couldn't find any package by regex 'linux-headers-4.9.140-tegra' gregory@gregory-desktop:
~$ uname -r 4.9.140-tegra
I have also tried to use the SDKManager as below but get the same messages as below
I have tried to install SDK Manager as below but get the same messages after downloading SDK Manager.
gregory@gregory-desktop:~/Downloads$ sudo apt install ./sdkmanager_1.1.0-6343_amd64.deb
You might want to run ‘apt --fix-broken install’ to correct these.
cuda-drivers-450 : Depends: libnvidia-compute-450 (>= 450.36.06) but it is not installed
Depends: libnvidia-gl-450 (>= 450.36.06) but it is not installed
libnvidia-decode-450 : Depends: libnvidia-compute-450 (= 450.36.06-0ubuntu1) but it is not installed
libnvidia-ifr1-450 : Depends: libnvidia-gl-450 but it is not installed
nvidia-compute-utils-450 : Depends: libnvidia-compute-450 but it is not installed
nvidia-driver-450 : Depends: libnvidia-gl-450 (= 450.36.06-0ubuntu1) but it is not installed
nvidia-utils-450 : Depends: libnvidia-compute-450 but it is not installed
E: Unmet dependencies. Try ‘apt --fix-broken install’ with no packages (or specify a solution).
