Hi all, I’ve tried several forums including the official CUDA installation guide. Everything runs fine in the pre-installation until I get to this command: sudo apt-get install linux-headers-$(uname -r)
in the Ubuntu section which yields:
E: Unable to locate package linux-headers-4.9.299-tegra
E: Couldn’t find any package by glob ‘linux-headers-4.9.299-tegra’
E: Couldn’t find any package by regex ‘linux-headers-4.9.299-tegra’
Link here: CUDA Installation Guide for Linux
I also tried the instructions here as this corresponds to my Ubuntu 18 and desired 11.x CUDA version. But to no avail either. I get a lot of missing packages and things and nothing works. I’m using the latest flashed image for the Nano.
If I run the fix broke install command this is what I get:
krypto@nano1:~$ sudo apt --fix-broken install
Reading package lists... Done
Building dependency tree
Reading state information... Done
Correcting dependencies... Done
The following packages were automatically installed and are no longer required:
apt-clone archdetect-deb bogl-bterm busybox-static cryptsetup-bin
dpkg-repack gir1.2-timezonemap-1.0 gir1.2-xkl-1.0 grub-common
kde-window-manager kinit kio kpackagetool5 kwayland-data kwin-common
kwin-data kwin-x11 libdebian-installer4 libkdecorations2-5v5
libkdecorations2private5v5 libkf5activities5 libkf5attica5
libkf5completion-data libkf5completion5 libkf5declarative-data
libkf5declarative5 libkf5doctools5 libkf5globalaccel-data libkf5globalaccel5
libkf5globalaccelprivate5 libkf5idletime5 libkf5jobwidgets-data
libkf5jobwidgets5 libkf5kcmutils-data libkf5kcmutils5 libkf5kiocore5
libkf5kiontlm5 libkf5kiowidgets5 libkf5newstuff-data libkf5newstuff5
libkf5newstuffcore5 libkf5package-data libkf5package5 libkf5plasma5
libkf5quickaddons5 libkf5solid5 libkf5solid5-data libkf5sonnet5-data
libkf5sonnetcore5 libkf5sonnetui5 libkf5textwidgets-data libkf5textwidgets5
libkf5waylandclient5 libkf5waylandserver5 libkf5xmlgui-bin libkf5xmlgui-data
libkf5xmlgui5 libkscreenlocker5 libkwin4-effect-builtins1 libkwineffects11
libkwinglutils11 libkwinxrenderutils11 libqgsttools-p1 libqt5designer5
libqt5help5 libqt5multimedia5 libqt5multimedia5-plugins
libqt5multimediaquick-p5 libqt5multimediawidgets5 libqt5opengl5
libqt5quickwidgets5 libqt5sql5 libqt5test5 libxcb-composite0 libxcb-cursor0
libxcb-damage0 os-prober python3-dbus.mainloop.pyqt5 python3-icu python3-pam
python3-pyqt5 python3-pyqt5.qtsvg python3-pyqt5.qtwebkit
qml-module-org-kde-kquickcontrolsaddons qml-module-qtmultimedia
qml-module-qtquick2 rdate tasksel tasksel-data
Use 'sudo apt autoremove' to remove them.
The following additional packages will be installed:
libnvidia-compute-450 libnvidia-gl-450
The following NEW packages will be installed:
0 upgraded, 2 newly installed, 0 to remove and 3 not upgraded.
71 not fully installed or removed.
Need to get 0 B/64.1 MB of archives.
After this operation, 257 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 file:/var/cuda-repo-ubuntu1804-11-0-local libnvidia-compute-450 450.51.05-0ubuntu1 [9,231 kB]
Get:2 file:/var/cuda-repo-ubuntu1804-11-0-local libnvidia-gl-450 450.51.05-0ubuntu1 [54.9 MB]
debconf: delaying package configuration, since apt-utils is not installed
(Reading database ... 218428 files and directories currently installed.)
Preparing to unpack .../libnvidia-compute-450_450.51.05-0ubuntu1_arm64.deb ...
Unpacking libnvidia-compute-450:arm64 (450.51.05-0ubuntu1) ...
dpkg: error processing archive /var/cuda-repo-ubuntu1804-11-0-local/./libnvidia-compute-450_450.51.05-0ubuntu1_arm64.deb (--unpack):
trying to overwrite '/usr/lib/aarch64-linux-gnu/libcuda.so', which is also in package nvidia-l4t-cuda 32.7.3-20221122092935
Preparing to unpack .../libnvidia-gl-450_450.51.05-0ubuntu1_arm64.deb ...
Unpacking libnvidia-gl-450:arm64 (450.51.05-0ubuntu1) ...
dpkg: error processing archive /var/cuda-repo-ubuntu1804-11-0-local/./libnvidia-gl-450_450.51.05-0ubuntu1_arm64.deb (--unpack):
trying to overwrite '/usr/share/glvnd/egl_vendor.d/10_nvidia.json', which is also in package nvidia-l4t-3d-core 32.7.3-20221122092935
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
krypto@nano1:~$
any help would be appreciated
