Installing CUDA 11.x on Jetson Nano
Hi all -
Downloaded and installed the newest Jetson Nano SD image - jetson-nano-jp45-sd-card-image.zip
Tried to update to CUDA 11.0 (same thing happens with CUDA 11.2 update) buy:
wget https://developer.download.nvidia.com/compute/cuda/repos/ubuntu1804/sbsa/cuda-ubuntu1804.pin
sudo mv cuda-ubuntu1804.pin /etc/apt/preferences.d/cuda-repository-pin-600
wget http://developer.download.nvidia.com/compute/cuda/11.0.2/local_installers/cuda-repo-ubuntu1804-11-0-local_11.0.2-450.51.05-1_arm64.deb
sudo dpkg -i cuda-repo-ubuntu1804-11-0-local_11.0.2-450.51.05-1_arm64.deb
sudo apt-key add /var/cuda-repo-ubuntu1804-11-0-local/7fa2af80.pub
sudo apt-get update
sudo apt-get -y install cuda
The last command gives these errors:
Selecting previously unselected package libnvidia-compute-450:arm64.
Preparing to unpack …/11-libnvidia-compute-450_450.51.05-0ubuntu1_arm64.deb …
Unpacking libnvidia-compute-450:arm64 (450.51.05-0ubuntu1) …
dpkg: error processing archive /tmp/apt-dpkg-install-Nja4Yz/11-libnvidia-compute-450_450.51.05-0ubuntu1_arm64.deb (–unpack):
trying to overwrite ‘/usr/lib/aarch64-linux-gnu/libcuda.so’, which is also in package nvidia-l4t-cuda 32.5.0-20210115145440
Unpacking libnvidia-gl-450:arm64 (450.51.05-0ubuntu1) …
dpkg: error processing archive /tmp/apt-dpkg-install-Nja4Yz/15-libnvidia-gl-450_450.51.05-0ubuntu1_arm64.deb (–unpack):
trying to overwrite ‘/usr/share/glvnd/egl_vendor.d/10_nvidia.json’, which is also in package nvidia-l4t-3d-core 32.5.0-20210115145440
Selecting previously unselected package libnvidia-ifr1-450:arm64.
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
I’m uncertain how to clean this up as aptitude database is now hosed.
Is there a way to update the Nano to an 11.X version of CUDA?
Also -
After I update CUDA, can I update the Nano to Ubuntu 20.04 from the 18.04 default in the above SD card image without encountering issues?
thanks
Sorry that there is no CUDA 11.x support on Jetson device currently.
The limitation comes from GPU driver. Please wait for our next major JetPack update to get a compatible driver.
However, there is a sharing to run Ubuntu 20.04 with docker on Xavier.
Please check below topic for the information:
Is CUDA 11.x supported on Jetson Nano by now?
Thanks in advance.
Not yet, it will be supported in future release.
