I just tried to upgrade to the latest CUDa toolkit 11.0 as instructed here → https://developer.nvidia.com/cuda-downloads?target_os=Linux&target_arch=sbsa&compilation=compilation_native&target_distro=Ubuntu&target_version=1804&target_type=deblocal
Installation was partial with the following errors:
sudo apt-get -y install cuda
Reading package lists... Done
Building dependency tree
Reading state information... Done
cuda is already the newest version (11.0.3-1).
You might want to run 'apt --fix-broken install' to correct these.
The following packages have unmet dependencies:
cuda-drivers-450 : Depends: libnvidia-compute-450 (>= 450.51.06) but it is not going to be installed
Depends: libnvidia-gl-450 (>= 450.51.06) but it is not going to be installed
libnvidia-decode-450 : Depends: libnvidia-compute-450 (= 450.51.06-0ubuntu1) but it is not going to be installed
libnvidia-ifr1-450 : Depends: libnvidia-gl-450 but it is not going to be installed
nvidia-compute-utils-450 : Depends: libnvidia-compute-450 but it is not going to be installed
nvidia-driver-450 : Depends: libnvidia-gl-450 (= 450.51.06-0ubuntu1) but it is not going to be installed
nvidia-utils-450 : Depends: libnvidia-compute-450 but it is not going to be installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
and then
damian@jetson-nano:~$ sudo apt --fix-broken install
Correcting dependencies... Done
The following packages were automatically installed and are no longer required:
apt-clone archdetect-deb bogl-bterm busybox-static cryptsetup-bin dpkg-repack gir1.2-timezonemap-1.0 gir1.2-xkl-1.0 grub-common kde-window-manager kinit kio kpackagetool5 kwayland-data kwin-common
kwin-data kwin-x11 libdebian-installer4 libkdecorations2-5v5 libkdecorations2private5v5 libkf5activities5 libkf5attica5 libkf5completion-data libkf5completion5 libkf5declarative-data libkf5declarative5
libkf5doctools5 libkf5globalaccel-data libkf5globalaccel5 libkf5globalaccelprivate5 libkf5idletime5 libkf5jobwidgets-data libkf5jobwidgets5 libkf5kcmutils-data libkf5kcmutils5 libkf5kiocore5
libkf5kiontlm5 libkf5kiowidgets5 libkf5newstuff-data libkf5newstuff5 libkf5newstuffcore5 libkf5package-data libkf5package5 libkf5plasma5 libkf5quickaddons5 libkf5solid5 libkf5solid5-data
libkf5sonnet5-data libkf5sonnetcore5 libkf5sonnetui5 libkf5textwidgets-data libkf5textwidgets5 libkf5waylandclient5 libkf5waylandserver5 libkf5xmlgui-bin libkf5xmlgui-data libkf5xmlgui5
libkscreenlocker5 libkwin4-effect-builtins1 libkwineffects11 libkwinglutils11 libkwinxrenderutils11 libqgsttools-p1 libqt5designer5 libqt5help5 libqt5multimedia5 libqt5multimedia5-plugins
libqt5multimediaquick-p5 libqt5multimediawidgets5 libqt5opengl5 libqt5positioning5 libqt5printsupport5 libqt5qml5 libqt5quick5 libqt5quickwidgets5 libqt5sensors5 libqt5sql5 libqt5test5
libqt5webchannel5 libqt5webkit5 libxcb-composite0 libxcb-cursor0 libxcb-damage0 os-prober python3-dbus.mainloop.pyqt5 python3-icu python3-pam python3-pyqt5 python3-pyqt5.qtsvg python3-pyqt5.qtwebkit
python3-sip qml-module-org-kde-kquickcontrolsaddons qml-module-qtmultimedia qml-module-qtquick2 rdate tasksel tasksel-data
Use 'sudo apt autoremove' to remove them.
The following additional packages will be installed:
libnvidia-compute-450 libnvidia-gl-450
The following NEW packages will be installed:
0 upgraded, 2 newly installed, 0 to remove and 21 not upgraded.
71 not fully installed or removed.
Need to get 0 B/64,3 MB of archives.
After this operation, 258 MB of additional disk space will be used.
Do you want to continue? [Y/n] Y
Get:1 file:/var/cuda-repo-ubuntu1804-11-0-local libnvidia-compute-450 450.51.06-0ubuntu1 [9 235 kB]
Get:2 file:/var/cuda-repo-ubuntu1804-11-0-local libnvidia-gl-450 450.51.06-0ubuntu1 [55,0 MB]
debconf: delaying package configuration, since apt-utils is not installed
(Reading database ... 186618 files and directories currently installed.)
Preparing to unpack .../libnvidia-compute-450_450.51.06-0ubuntu1_arm64.deb ...
Unpacking libnvidia-compute-450:arm64 (450.51.06-0ubuntu1) ...
dpkg: error processing archive /var/cuda-repo-ubuntu1804-11-0-local/./libnvidia-compute-450_450.51.06-0ubuntu1_arm64.deb (--unpack):
trying to overwrite '/usr/lib/aarch64-linux-gnu/libcuda.so', which is also in package nvidia-l4t-cuda 32.4.3-20200625213809
Preparing to unpack .../libnvidia-gl-450_450.51.06-0ubuntu1_arm64.deb ...
Unpacking libnvidia-gl-450:arm64 (450.51.06-0ubuntu1) ...
dpkg: error processing archive /var/cuda-repo-ubuntu1804-11-0-local/./libnvidia-gl-450_450.51.06-0ubuntu1_arm64.deb (--unpack):
trying to overwrite '/usr/share/glvnd/egl_vendor.d/10_nvidia.json', which is also in package nvidia-l4t-3d-core 32.4.3-20200625213809
Errors were encountered while processing:
Now I have a broken package management (apt-get install whatever) throws this error:
Please provide informatin on how to fix my system
