Can Cuda 11 works on the jetson nano ? a couple of contradictory information need some clarify
Hello.
I’m trying to understand if I can install cuda 11 on the jetson nano. According with this website :
he says :
Pytorch 2.0 and above uses CUDA 11. The Jetson Nano has CUDA 10.2.
Due to low-level GPU incompatibility, installing CUDA 11 on your Nano is impossible.
but,here,at the seeedstudio managed to install cuda 11 :
so,cuda 11 will work or not ? thanks.
It won’t work.
We start to release the aarch64-jetson package on our CUDA website from version 11.8.
However, it only supports Ubuntu 20.04 which indicates that it is for the JetPack 5 user.
Thanks. Actually I’m running ubuntu 22.04 on the jetson nano and everything is working great. But the version of CUDA that I’m using is 10. So,I’m going to upgrade it to 11. If I have understood well your words,it could work. Furthermore I see that seeeed studio wrote the tutorial about how to install CUDA 11 three years ago,when the jetson orin didn’t exist yet.
Just want to confirm first.
Do you use Jetson Nano or Orin Nano?
Did you read what I said before ? the tutorial has been written 3 years ago,check the date. 3 years ago the jetson orin didn’t exist.
I tried to install CUDA 11 on top of ubuntu 18. This is what happened :
wget https://developer.download.nvidia.com/compute/cuda/repos/ubuntu1804/sbsa/cuda-ubuntu1804.pin
sudo mv cuda-ubuntu1804.pin /etc/apt/preferences.d/cuda-repository-pin-600
wget http://developer.download.nvidia.com/compute/cuda/11.0.2/local_installers/cuda-repo-ubuntu1804-11-0-local_11.0.2-450.51.05-1_arm64.deb
sudo dpkg -i cuda-repo-ubuntu1804-11-0-local_11.0.2-450.51.05-1_arm64.deb
sudo apt-key add /var/cuda-repo-ubuntu1804-11-0-local/7fa2af80.pub
sudo apt-get update
Scaricamento di:1 file:/var/cuda-repo-l4t-10-2-local  InRelease
Ignorato:1 file:/var/cuda-repo-l4t-10-2-local  InRelease
Scaricamento di:2 file:/var/cuda-repo-ubuntu1804-11-0-local  InRelease
Ignorato:2 file:/var/cuda-repo-ubuntu1804-11-0-local  InRelease
Scaricamento di:3 file:/var/visionworks-repo  InRelease
Ignorato:3 file:/var/visionworks-repo  InRelease
Scaricamento di:4 file:/var/visionworks-sfm-repo  InRelease
Ignorato:4 file:/var/visionworks-sfm-repo  InRelease
Scaricamento di:5 file:/var/visionworks-tracking-repo  InRelease
Ignorato:5 file:/var/visionworks-tracking-repo  InRelease
Scaricamento di:6 file:/var/cuda-repo-l4t-10-2-local  Release [564 B]
Scaricamento di:7 file:/var/cuda-repo-ubuntu1804-11-0-local  Release [564 B]
Scaricamento di:8 file:/var/visionworks-repo  Release [2,001 B]
Scaricamento di:9 file:/var/visionworks-sfm-repo  Release [2,005 B]
Scaricamento di:10 file:/var/visionworks-tracking-repo  Release [2,010 B]
Scaricamento di:11 file:/var/cuda-repo-ubuntu1804-11-0-local  Release.gpg [836 B]
Trovato:12 http://ports.ubuntu.com/ubuntu-ports bionic InRelease
Scaricamento di:13 http://ppa.launchpad.net/pipewire-debian/pipewire-upstream/ubuntu bionic InRelease [21.3 kB]
Ignorato:16 https://esm.ubuntu.com/apps/ubuntu bionic-apps-security InRelease
Scaricamento di:18 https://repo.download.nvidia.com/jetson/common r32.7 InRelease [2,555 B]
Scaricamento di:14 http://ports.ubuntu.com/ubuntu-ports bionic-updates InRelease [88.7 kB]
Scaricamento di:19 https://repo.download.nvidia.com/jetson/t210 r32.7 InRelease [2,550 B]
Ignorato:20 https://esm.ubuntu.com/apps/ubuntu bionic-apps-updates InRelease
Scaricamento di:15 http://ports.ubuntu.com/ubuntu-ports bionic-backports InRelease [83.3 kB]
Ignorato:22 https://esm.ubuntu.com/infra/ubuntu bionic-infra-security InRelease
Scaricamento di:17 http://ports.ubuntu.com/ubuntu-ports bionic-security InRelease [88.7 kB]
Ignorato:23 https://esm.ubuntu.com/infra/ubuntu bionic-infra-updates InRelease
Errore:24 https://esm.ubuntu.com/apps/ubuntu bionic-apps-security Release
  Certificate verification failed: The certificate is NOT trusted. The certificate chain uses not yet valid certificate.  Could not handshake: Error in the certificate verification. [IP: 185.125.190.24 443]
Errore:26 https://esm.ubuntu.com/apps/ubuntu bionic-apps-updates Release
Errore:27 https://esm.ubuntu.com/infra/ubuntu bionic-infra-security Release
Errore:28 https://esm.ubuntu.com/infra/ubuntu bionic-infra-updates Release
Scaricamento di:31 file:/var/cuda-repo-ubuntu1804-11-0-local  Packages [21.9 kB]
Lettura elenco dei pacchetti... Fatto
E: Il repository "https://esm.ubuntu.com/apps/ubuntu bionic-apps-security Release" non ha più un file Release.
N: L'aggiornamento da tale repository non può essere eseguito in modo sicuro ed è quindi disabilitato come impostazione predefinita.
N: Consultare la pagina man apt-secure(8) per la creazione di un repository e la configurazione utente.
E: Il repository "https://esm.ubuntu.com/apps/ubuntu bionic-apps-updates Release" non ha più un file Release.
E: Il repository "https://esm.ubuntu.com/infra/ubuntu bionic-infra-security Release" non ha più un file Release.
E: Il repository "https://esm.ubuntu.com/infra/ubuntu bionic-infra-updates Release" non ha più un file Release.
E: Il file Release per http://ppa.launchpad.net/pipewire-debian/pipewire-upstream/ubuntu/dists/bionic/InRelease non è ancora valido (non valido per 35g 13h 6min 9s). Gli aggiornamenti per questo repository non verranno applicati.
E: Il file Release per https://repo.download.nvidia.com/jetson/common/dists/r32.7/InRelease non è ancora valido (non valido per 60g 12h 44min 23s). Gli aggiornamenti per questo repository non verranno applicati.
E: Il file Release per http://ports.ubuntu.com/ubuntu-ports/dists/bionic-updates/InRelease non è ancora valido (non valido per 62g 20h 22min 15s). Gli aggiornamenti per questo repository non verranno applicati.
E: Il file Release per http://ports.ubuntu.com/ubuntu-ports/dists/bionic-backports/InRelease non è ancora valido (non valido per 62g 19h 46min 21s). Gli aggiornamenti per questo repository non verranno applicati.
E: Il file Release per http://ports.ubuntu.com/ubuntu-ports/dists/bionic-security/InRelease non è ancora valido (non valido per 62g 19h 42min 54s). Gli aggiornamenti per questo repository non verranno applicati.
sudo apt-get -y install cuda
Generazione albero delle dipendenze
Lettura informazioni sullo stato... Fatto
I seguenti pacchetti aggiuntivi saranno inoltre installati:
  cuda-11-0 cuda-command-line-tools-11-0 cuda-compiler-11-0 cuda-cudart-11-0 cuda-cudart-dev-11-0
  cuda-cuobjdump-11-0 cuda-cupti-11-0 cuda-cupti-dev-11-0 cuda-documentation-11-0
  cuda-driver-dev-11-0 cuda-drivers cuda-drivers-450 cuda-gdb-11-0 cuda-libraries-11-0
  cuda-libraries-dev-11-0 cuda-nsight-compute-11-0 cuda-nsight-systems-11-0 cuda-nvcc-11-0
  cuda-nvdisasm-11-0 cuda-nvml-dev-11-0 cuda-nvprof-11-0 cuda-nvprune-11-0 cuda-nvrtc-11-0
  cuda-nvrtc-dev-11-0 cuda-nvtx-11-0 cuda-runtime-11-0 cuda-samples-11-0 cuda-sanitizer-11-0
  cuda-toolkit-11-0 cuda-tools-11-0 cuda-visual-tools-11-0 dkms libcublas-11-0 libcublas-dev-11-0
  libcufft-11-0 libcufft-dev-11-0 libcurand-11-0 libcurand-dev-11-0 libcusolver-11-0
  libcusolver-dev-11-0 libcusparse-11-0 libcusparse-dev-11-0 libnpp-11-0 libnpp-dev-11-0
  libnvidia-cfg1-450 libnvidia-common-450 libnvidia-compute-450 libnvidia-decode-450
  libnvidia-encode-450 libnvidia-extra-450 libnvidia-fbc1-450 libnvidia-gl-450 libnvidia-ifr1-450
  libnvjpeg-11-0 libnvjpeg-dev-11-0 libxnvctrl0 linux-headers-4.15.0-208
  linux-headers-4.15.0-208-generic linux-headers-generic nsight-compute-2020.1.1
  nsight-systems-linux-tegra-public-2021.5.4.19-e642d4b nvidia-compute-utils-450 nvidia-dkms-450
  nvidia-driver-450 nvidia-kernel-common-450 nvidia-kernel-source-450 nvidia-modprobe nvidia-prime
  nvidia-settings nvidia-utils-450 screen-resolution-extra xserver-xorg-video-nvidia-450
I seguenti pacchetti NUOVI saranno installati:
  cuda cuda-11-0 cuda-command-line-tools-11-0 cuda-compiler-11-0 cuda-cudart-11-0
  cuda-cudart-dev-11-0 cuda-cuobjdump-11-0 cuda-cupti-11-0 cuda-cupti-dev-11-0
  cuda-documentation-11-0 cuda-driver-dev-11-0 cuda-drivers cuda-drivers-450 cuda-gdb-11-0
  cuda-libraries-11-0 cuda-libraries-dev-11-0 cuda-nsight-compute-11-0 cuda-nsight-systems-11-0
  cuda-nvcc-11-0 cuda-nvdisasm-11-0 cuda-nvml-dev-11-0 cuda-nvprof-11-0 cuda-nvprune-11-0
  cuda-nvrtc-11-0 cuda-nvrtc-dev-11-0 cuda-nvtx-11-0 cuda-runtime-11-0 cuda-samples-11-0
  cuda-sanitizer-11-0 cuda-toolkit-11-0 cuda-tools-11-0 cuda-visual-tools-11-0 dkms libcublas-11-0
  libcublas-dev-11-0 libcufft-11-0 libcufft-dev-11-0 libcurand-11-0 libcurand-dev-11-0
  libcusolver-11-0 libcusolver-dev-11-0 libcusparse-11-0 libcusparse-dev-11-0 libnpp-11-0
  libnpp-dev-11-0 libnvidia-cfg1-450 libnvidia-common-450 libnvidia-compute-450
  libnvidia-decode-450 libnvidia-encode-450 libnvidia-extra-450 libnvidia-fbc1-450
  libnvidia-gl-450 libnvidia-ifr1-450 libnvjpeg-11-0 libnvjpeg-dev-11-0 libxnvctrl0
  linux-headers-4.15.0-208 linux-headers-4.15.0-208-generic linux-headers-generic
  nsight-compute-2020.1.1 nsight-systems-linux-tegra-public-2021.5.4.19-e642d4b
  nvidia-compute-utils-450 nvidia-dkms-450 nvidia-driver-450 nvidia-kernel-common-450
  nvidia-kernel-source-450 nvidia-modprobe nvidia-prime nvidia-settings nvidia-utils-450
0 aggiornati, 73 installati, 0 da rimuovere e 0 non aggiornati.
È necessario scaricare 79.3 MB/1,550 MB di archivi.
Dopo quest'operazione, verranno occupati 4,135 MB di spazio su disco.
Scaricamento di:1 file:/var/cuda-repo-ubuntu1804-11-0-local  cuda-cudart-11-0 11.0.194-1 [124 kB]
Scaricamento di:2 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main arm64 dkms all 2.3-3ubuntu9.7 [68.1 kB]
Scaricamento di:3 file:/var/cuda-repo-ubuntu1804-11-0-local  cuda-nvrtc-11-0 11.0.194-1 [5,926 kB]
Scaricamento di:4 https://repo.download.nvidia.com/jetson/common r32.7/main arm64 nsight-systems-linux-tegra-public-2021.5.4.19-e642d4b arm64 2021.5.4.19-e642d4b [67.3 MB]
Scaricamento di:5 http://ports.ubuntu.com/ubuntu-ports bionic/main arm64 screen-resolution-extra all 0.17.3 [11.7 kB]
Scaricamento di:6 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main arm64 linux-headers-4.15.0-208 all 4.15.0-208.220 [11.0 MB]
Scaricamento di:7 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main arm64 linux-headers-4.15.0-208-generic arm64 4.15.0-208.220 [895 kB]
Ignorato:8 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main arm64 linux-headers-generic arm64 4.15.0.208.191
Scaricamento di:9 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main arm64 nvidia-prime all 0.8.16~0.18.04.1 [9,224 B]
Errore:8 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main arm64 linux-headers-generic arm64 4.15.0.208.191
  404  Not Found [IP: 185.125.190.36 80]
Scaricamento di:10 file:/var/cuda-repo-ubuntu1804-11-0-local  libcublas-11-0 11.1.0.229-1 [116 MB]
Scaricamento di:11 file:/var/cuda-repo-ubuntu1804-11-0-local  libcufft-11-0 10.2.0.218-1 [97.9 MB]
Scaricamento di:12 file:/var/cuda-repo-ubuntu1804-11-0-local  libcurand-11-0 10.2.1.218-1 [39.0 MB]
Scaricamento di:13 file:/var/cuda-repo-ubuntu1804-11-0-local  libcusolver-11-0 10.5.0.218-1 [284 MB]
Scaricamento di:14 file:/var/cuda-repo-ubuntu1804-11-0-local  libcusparse-11-0 11.1.0.218-1 [72.9 MB]
Scaricamento di:15 file:/var/cuda-repo-ubuntu1804-11-0-local  libnpp-11-0 11.1.0.218-1 [56.3 MB]
Scaricamento di:16 file:/var/cuda-repo-ubuntu1804-11-0-local  libnvjpeg-11-0 11.1.0.218-1 [1,275 kB]
Scaricamento di:17 file:/var/cuda-repo-ubuntu1804-11-0-local  cuda-libraries-11-0 11.0.2-1 [2,490 B]
Scaricamento di:18 file:/var/cuda-repo-ubuntu1804-11-0-local  libnvidia-common-450 450.51.05-0ubuntu1 [10.0 kB]
Scaricamento di:19 file:/var/cuda-repo-ubuntu1804-11-0-local  libnvidia-compute-450 450.51.05-0ubuntu1 [9,231 kB]
Scaricamento di:20 file:/var/cuda-repo-ubuntu1804-11-0-local  libnvidia-decode-450 450.51.05-0ubuntu1 [1,077 kB]
Scaricamento di:21 file:/var/cuda-repo-ubuntu1804-11-0-local  libnvidia-encode-450 450.51.05-0ubuntu1 [39.5 kB]
Scaricamento di:22 file:/var/cuda-repo-ubuntu1804-11-0-local  libnvidia-fbc1-450 450.51.05-0ubuntu1 [7,040 B]
Scaricamento di:23 file:/var/cuda-repo-ubuntu1804-11-0-local  libnvidia-gl-450 450.51.05-0ubuntu1 [54.9 MB]
Scaricamento di:24 file:/var/cuda-repo-ubuntu1804-11-0-local  libnvidia-ifr1-450 450.51.05-0ubuntu1 [7,068 B]
Scaricamento di:25 file:/var/cuda-repo-ubuntu1804-11-0-local  nvidia-compute-utils-450 450.51.05-0ubuntu1 [109 kB]
Scaricamento di:26 file:/var/cuda-repo-ubuntu1804-11-0-local  nvidia-kernel-source-450 450.51.05-0ubuntu1 [11.6 MB]
Scaricamento di:27 file:/var/cuda-repo-ubuntu1804-11-0-local  nvidia-kernel-common-450 450.51.05-0ubuntu1 [9,402 B]
Scaricamento di:28 file:/var/cuda-repo-ubuntu1804-11-0-local  nvidia-dkms-450 450.51.05-0ubuntu1 [26.7 kB]
Scaricamento di:29 file:/var/cuda-repo-ubuntu1804-11-0-local  libnvidia-extra-450 450.51.05-0ubuntu1 [38.0 kB]
Scaricamento di:30 file:/var/cuda-repo-ubuntu1804-11-0-local  nvidia-driver-450 450.51.05-0ubuntu1 [411 kB]
Scaricamento di:31 file:/var/cuda-repo-ubuntu1804-11-0-local  nvidia-utils-450 450.51.05-0ubuntu1 [347 kB]
Scaricamento di:32 file:/var/cuda-repo-ubuntu1804-11-0-local  libnvidia-cfg1-450 450.51.05-0ubuntu1 [74.2 kB]
Scaricamento di:33 file:/var/cuda-repo-ubuntu1804-11-0-local  xserver-xorg-video-nvidia-450 450.51.05-0ubuntu1 [1,235 kB]
Scaricamento di:34 file:/var/cuda-repo-ubuntu1804-11-0-local  nvidia-modprobe 450.51.05-0ubuntu1 [17.7 kB]
Scaricamento di:35 file:/var/cuda-repo-ubuntu1804-11-0-local  libxnvctrl0 450.51.05-0ubuntu1 [20.5 kB]
Scaricamento di:36 file:/var/cuda-repo-ubuntu1804-11-0-local  nvidia-settings 450.51.05-0ubuntu1 [826 kB]
Scaricamento di:37 file:/var/cuda-repo-ubuntu1804-11-0-local  cuda-drivers-450 450.51.05-1 [2,628 B]
Scaricamento di:38 file:/var/cuda-repo-ubuntu1804-11-0-local  cuda-drivers 450.51.05-1 [2,504 B]
Scaricamento di:39 file:/var/cuda-repo-ubuntu1804-11-0-local  cuda-runtime-11-0 11.0.2-1 [2,426 B]
Scaricamento di:40 file:/var/cuda-repo-ubuntu1804-11-0-local  cuda-cuobjdump-11-0 11.0.194-1 [91.3 kB]
Scaricamento di:41 file:/var/cuda-repo-ubuntu1804-11-0-local  cuda-driver-dev-11-0 11.0.194-1 [26.1 kB]
Scaricamento di:42 file:/var/cuda-repo-ubuntu1804-11-0-local  cuda-cudart-dev-11-0 11.0.194-1 [1,609 kB]
Scaricamento di:43 file:/var/cuda-repo-ubuntu1804-11-0-local  cuda-nvcc-11-0 11.0.194-1 [15.7 MB]
Scaricamento di:44 file:/var/cuda-repo-ubuntu1804-11-0-local  cuda-nvprune-11-0 11.0.167-1 [46.5 kB]
Scaricamento di:45 file:/var/cuda-repo-ubuntu1804-11-0-local  cuda-compiler-11-0 11.0.2-1 [2,422 B]
Scaricamento di:46 file:/var/cuda-repo-ubuntu1804-11-0-local  cuda-nvrtc-dev-11-0 11.0.194-1 [22.0 kB]
Scaricamento di:47 file:/var/cuda-repo-ubuntu1804-11-0-local  libcublas-dev-11-0 11.1.0.229-1 [118 MB]
Scaricamento di:48 file:/var/cuda-repo-ubuntu1804-11-0-local  libcufft-dev-11-0 10.2.0.218-1 [176 MB]
Scaricamento di:49 file:/var/cuda-repo-ubuntu1804-11-0-local  libcurand-dev-11-0 10.2.1.218-1 [39.2 MB]
Scaricamento di:50 file:/var/cuda-repo-ubuntu1804-11-0-local  libcusolver-dev-11-0 10.5.0.218-1 [17.6 MB]
Scaricamento di:51 file:/var/cuda-repo-ubuntu1804-11-0-local  libcusparse-dev-11-0 11.1.0.218-1 [72.8 MB]
Scaricamento di:52 file:/var/cuda-repo-ubuntu1804-11-0-local  libnpp-dev-11-0 11.1.0.218-1 [57.3 MB]
Scaricamento di:53 file:/var/cuda-repo-ubuntu1804-11-0-local  libnvjpeg-dev-11-0 11.1.0.218-1 [1,243 kB]
Scaricamento di:54 file:/var/cuda-repo-ubuntu1804-11-0-local  cuda-libraries-dev-11-0 11.0.2-1 [2,514 B]
Scaricamento di:55 file:/var/cuda-repo-ubuntu1804-11-0-local  cuda-cupti-11-0 11.0.194-1 [3,551 kB]
Scaricamento di:56 file:/var/cuda-repo-ubuntu1804-11-0-local  cuda-cupti-dev-11-0 11.0.194-1 [124 kB]
Scaricamento di:57 file:/var/cuda-repo-ubuntu1804-11-0-local  cuda-nvdisasm-11-0 11.0.194-1 [27.2 MB]
Scaricamento di:58 file:/var/cuda-repo-ubuntu1804-11-0-local  cuda-gdb-11-0 11.0.194-1 [2,925 kB]
Scaricamento di:59 file:/var/cuda-repo-ubuntu1804-11-0-local  cuda-nvprof-11-0 11.0.194-1 [18.0 kB]
Scaricamento di:60 file:/var/cuda-repo-ubuntu1804-11-0-local  cuda-nvtx-11-0 11.0.167-1 [51.8 kB]
Scaricamento di:61 file:/var/cuda-repo-ubuntu1804-11-0-local  cuda-sanitizer-11-0 11.0.194-1 [5,553 kB]
Scaricamento di:62 file:/var/cuda-repo-ubuntu1804-11-0-local  cuda-command-line-tools-11-0 11.0.2-1 [2,472 B]
Scaricamento di:63 file:/var/cuda-repo-ubuntu1804-11-0-local  nsight-compute-2020.1.1 2020.1.1.8-1 [75.0 MB]
Scaricamento di:64 file:/var/cuda-repo-ubuntu1804-11-0-local  cuda-nsight-compute-11-0 11.0.2-1 [3,574 B]
Scaricamento di:65 file:/var/cuda-repo-ubuntu1804-11-0-local  cuda-nsight-systems-11-0 11.0.2-1 [3,284 B]
Scaricamento di:66 file:/var/cuda-repo-ubuntu1804-11-0-local  cuda-nvml-dev-11-0 11.0.167-1 [71.9 kB]
Scaricamento di:67 file:/var/cuda-repo-ubuntu1804-11-0-local  cuda-visual-tools-11-0 11.0.2-1 [2,934 B]
Scaricamento di:68 file:/var/cuda-repo-ubuntu1804-11-0-local  cuda-tools-11-0 11.0.2-1 [2,382 B]
Scaricamento di:69 file:/var/cuda-repo-ubuntu1804-11-0-local  cuda-samples-11-0 11.0.194-1 [42.3 MB]
Scaricamento di:70 file:/var/cuda-repo-ubuntu1804-11-0-local  cuda-documentation-11-0 11.0.207-1 [59.6 MB]
Scaricamento di:71 file:/var/cuda-repo-ubuntu1804-11-0-local  cuda-toolkit-11-0 11.0.2-1 [2,726 B]
Scaricamento di:72 file:/var/cuda-repo-ubuntu1804-11-0-local  cuda-11-0 11.0.2-1 [2,440 B]
Scaricamento di:73 file:/var/cuda-repo-ubuntu1804-11-0-local  cuda 11.0.2-1 [2,392 B]
Recuperati 79.3 MB in 42s (1,895 kB/s)
This seems to be the real error :
E: Impossibile recuperare http://ports.ubuntu.com/ubuntu-ports/pool/main/l/linux-meta/linux-headers-generic_4.15.0.208.191_arm64.deb  404  Not Found [IP: 185.125.190.36 80]
E: Impossibile scaricare alcuni pacchetti. Potrebbe essere utile eseguire "apt-get update" o provare l'opzione "--fix-missing".
Anyway,that’s it. Now the Jetson nano can work with a lot of new software components. To have Ubuntu 18.04 (that’s even EOL and this should should put nvidia to shame) and CUDA 10 was so wrong. The last thing that I want to try is to upgrade the kernel. It is still 4.9. Too old. I would like to try 5.x ; do you have some good articles that suggest to me how to do that ? I will do the rest. thanks.
Please refer to Ubuntu 22.04 image beta test for jetson nano - Jetson & Embedded Systems / Jetson Nano - NVIDIA Developer Forums to see if can work.
Unfortunately it doesn’t work it’s more it will break the GPU graphics acceleration.
The packages in that tutorial force an installation that will cause GLXINFO loading and OpenGL acceleration to fail.
cuda11 is tied to libGLnv from 450.xx branch which breaks driver detection of jetson nano driver correctly.
Edit : also it’s rewrite xserver config to xserver-xorg-nvidia-450 .
After research I highly doubt that Cuda11 and Cuda12 will ever work on jetson nano
Unless NVIDIA updates the drivers on jetson nano but since it is EOL I highly doubt they will.
Requires a more current driver base to work
You can get to install cuda11/12 without problems but it will not detect the initialization of the tegra chip returning error 999 or error 3 Initial error.
In cuda12 that message is much clearer, returning insufficient and incompatible drivers to work.
Requires more current base drivers than those provided for 32.7.3
Therefore the maximum supported version is cuda10.
It is the same problem that happens in nvidia GPU pcie driver when trying to work with old drivers.
I have some ideas to try but unfortunately I’m not able to fix my board :
