Error while installing cuda on Host and Deepstream on target
I’m trying to install some components on my host pc and my Jetson Xavier NX with SDKManager in order to code on Nsight Eclipse Edition and cross-compile to my Jetson.
I’m facing some installation issue with SDKM. Result of the SDKM installation :
  • Jetson OS image flashed correctly.
Host Components :
  • CUDA and Computer Vision Error while installing.
  • Developer Tools successfully installed.
Target Components :
  • CUDA, CUDA-X AI, Computer Vision, NVIDIA Container Runtime installed successfully.
  • Multimedia APi and DeepStream SDK errors while installing.
Host issue :
I have Ubuntu 18.04.5 LTS, my graphics card is a GeForce GTX 780 Ti.
Result of arch command = x86_64.
Result of dpkg --print-architecture : amd64.
Terminal result for CUDA on Host (i didn't find a better way to show this)
14:44:09 INFO: CUDA on Host: Reading package lists…
14:44:09 INFO: CUDA on Host: Building dependency tree…
14:44:09 INFO: CUDA on Host: Reading state information…
14:44:09 INFO: CUDA on Host: cuda-repo-ubuntu1804-10-2-local-10.2.89-440.40 is already the newest version (1.0-1).
14:44:09 INFO: CUDA on Host: 0 upgraded, 0 newly installed, 0 to remove and 3 not upgraded.
14:44:09 INFO: CUDA on Host: no repoPackageInfo found in additionalParameters.
14:44:09 INFO: CUDA on Host: infer package info from file name cuda-repo-ubuntu1804-10-2-local-10.2.89-440.40_1.0-1_amd64.deb [ name: cuda-repo-ubuntu1804-10-2-local-10.2.89-440.40, version: 1.0-1 ]
14:44:09 INFO: CUDA on Host: exec_command: dpkg -L cuda-repo-ubuntu1804-10-2-local-10.2.89-440.40 | grep ‘.pub$’ | tr -d ‘\n’
14:44:09 INFO: CUDA on Host: exec_command: sudo apt-key add /var/cuda-repo-10-2-local-10.2.89-440.40/7fa2af80.pub
14:44:09 : CUDA on Host: Warning: apt-key output should not be parsed (stdout is not a terminal)
14:44:09 INFO: CUDA on Host: OK
14:44:09 INFO: CUDA on Host: exec_command: sudo apt-get check
14:44:10 INFO: CUDA on Host: Building dependency tree…
14:44:10 INFO: CUDA on Host: Reading state information…
14:44:10 INFO: CUDA on Host: exec_command: sudo apt-get update; sleep 0.5; sudo apt-get -y --allow-downgrades install cuda-toolkit-10-2=10.2.89*
14:44:10 INFO: CUDA on Host: Hit:1 fr.archive.ubuntu.com / ubuntu.lafibre.info bionic InRelease
14:44:10 INFO: CUDA on Host: Hit:2 Index of /graphics-drivers/ppa/ubuntu bionic InRelease
14:44:10 INFO: CUDA on Host: Hit:3 fr.archive.ubuntu.com / ubuntu.lafibre.info bionic-updates InRelease
14:44:10 INFO: CUDA on Host: Hit:4 fr.archive.ubuntu.com / ubuntu.lafibre.info bionic-backports InRelease
14:44:10 INFO: CUDA on Host: Get:5 Index of /ubuntu bionic-security InRelease [88.7 kB]
14:44:10 INFO: CUDA on Host: Fetched 88.7 kB in 1s (162 kB/s)
14:44:12 INFO: CUDA on Host: Reading package lists…
14:44:13 INFO: CUDA on Host: Building dependency tree…
14:44:13 INFO: CUDA on Host: Reading state information…
14:44:13 INFO: CUDA on Host: Some packages could not be installed. This may mean that you have
14:44:13 INFO: CUDA on Host: requested an impossible situation or if you are using the unstable
14:44:13 INFO: CUDA on Host: distribution that some required packages have not yet been created
14:44:13 INFO: CUDA on Host: or been moved out of Incoming.
14:44:13 INFO: CUDA on Host: The following information may help to resolve the situation:
14:44:13 INFO: CUDA on Host: The following packages have unmet dependencies:
14:44:13 INFO: CUDA on Host: cuda-toolkit-10-2 : Depends: cuda-compiler-10-2 (>= 10.2.89) but it is not installable
14:44:13 INFO: CUDA on Host: Depends: cuda-tools-10-2 (>= 10.2.89) but it is not installable
14:44:13 INFO: CUDA on Host: Depends: cuda-samples-10-2 (>= 10.2.89) but it is not installable
14:44:13 INFO: CUDA on Host: Depends: cuda-documentation-10-2 (>= 10.2.89) but it is not installable
14:44:13 INFO: CUDA on Host: Depends: cuda-libraries-dev-10-2 (>= 10.2.89) but it is not installable
14:44:13 INFO: CUDA on Host: Depends: cuda-libraries-10-2 (>= 10.2.89) but it is not installable
14:44:13 INFO: CUDA on Host: Depends: cuda-nvml-dev-10-2 (>= 10.2.89) but it is not installable
14:44:13 INFO: CUDA on Host: Depends: cuda-license-10-2 (>= 10.2.89) but it is not installable
14:44:13 ERROR: CUDA on Host: E: Unable to correct problems, you have held broken packages.
14:44:13 INFO: CUDA on Host: [ Package Install Finished with Error ]
14:44:13 INFO: CUDA on Host: [host] [ 3.10 MB released. Disk Avail: 793.34 GB ]
14:44:13 INFO: CUDA on Host: [ NV_CUDA_HOST_COMP Install took 4s ]
14:44:13 ERROR: CUDA on Host: [error]: Error when apt install failed; [exec_command]: sudo apt-get update; sleep 0.5; sudo apt-get -y --allow-downgrades install cuda-toolkit-10-2=10.2.89* ; [error]: exit status 100; [deb_path]: /home/louis/Downloads/nvidia/sdkm_downloads/cuda-repo-ubuntu1804-10-2-local-10.2.89-440.40_1.0-1_amd64.deb
14:44:13 ERROR: CUDA on Host: command terminated with error
14:44:13 SUMMARY: CUDA on Host: APT system is broken and requires manual fix
Terminal result for CUDA Cross Compile Package on Host
14:44:05 INFO: CUDA Cross Compile Package on Host: verifying checksum of /home/louis/Downloads/nvidia/sdkm_downloads/cuda-repo-cross-aarch64-10-2-local-10.2.89_1.0-1_all.deb
14:44:06 INFO: CUDA Cross Compile Package on Host: Found file /home/louis/Downloads/nvidia/sdkm_downloads/cuda-repo-cross-aarch64-10-2-local-10.2.89_1.0-1_all.deb with correct checksum, skip downloading.
14:44:13 SUMMARY: CUDA Cross Compile Package on Host: Depends on failed component
Computer Vision logs doesn’t give more information than this one but i can put it if you want.
I tried sudo apt --fix-broken install and sudo apt-get update because of this but got no luck.
interesting log info
Target issue :
DeepStream terminal result
14:44:06 INFO: DeepStream: verifying checksum of /home/louis/Downloads/nvidia/sdkm_downloads/deepstream-5.0_5.0.1-1_arm64.deb
14:44:07 INFO: DeepStream: Found file /home/louis/Downloads/nvidia/sdkm_downloads/deepstream-5.0_5.0.1-1_arm64.deb with correct checksum, skip downloading.
14:44:57 DEBUG: DeepStream: using adapter to install NV_DEEPSTREAM_TARGET_POST_INSTALL_COMP@JETSON_XAVIER_NX_DEVKIT to /home/louis/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_XAVIER_NX_DEVKIT
14:44:57 INFO: DeepStream: exec_command: ssh -t -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no loulou@192.168.55.1 “df -B1 / | tail -1 | awk ‘{ printf $4 }’”
14:44:57 INFO: DeepStream: [target] loulou@192.168.55.1’s password:
14:44:58 INFO: DeepStream: Using GenericInstaller to Install NV_DEEPSTREAM_TARGET_POST_INSTALL_COMP
14:44:58 INFO: DeepStream: NV_DEEPSTREAM_TARGET_POST_INSTALL_COMP include 1 package
14:44:58 INFO: DeepStream: [ Package PreInstall Started ]
14:44:58 INFO: DeepStream: current working directory is /home/louis/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_XAVIER_NX_DEVKIT
14:44:58 INFO: DeepStream: exec_command [target]:
14:44:58 INFO: DeepStream: **********************
14:44:58 INFO: DeepStream: #!/bin/bash
14:44:58 INFO: DeepStream: set -e
14:44:58 INFO: DeepStream: function safe_apt_install {
14:44:58 INFO: DeepStream: echo “*begin $1, $2”
14:44:58 INFO: DeepStream: tmp_log=/tmp/jetpack_dpkg_log.txt
14:44:58 INFO: DeepStream: sudo rm -f $tmp_log
14:44:58 INFO: DeepStream: set +e; $1 2>&1 | tee $tmp_log; CMD_STATUS=${PIPESTATUS[0]}; set -e
14:44:58 INFO: DeepStream: while [ ${CMD_STATUS} -ne 0 ]; do
14:44:58 INFO: DeepStream: if grep -q -e “is locked by another process” -e “E: Could not get lock /var/” $tmp_log; then
14:44:58 INFO: DeepStream: echo “Waiting $2 seconds for apt to be available”; sleep ${2}
14:44:58 INFO: DeepStream: else
14:44:58 INFO: DeepStream: echo “Unhandled error when running $1”; exit 1
14:44:58 INFO: DeepStream: fi
14:44:58 INFO: DeepStream: done
14:44:58 INFO: DeepStream: }
14:44:58 INFO: DeepStream: export LC_ALL=en_US.UTF-8 LANG=en_US.UTF-8 LANGUAGE=en_US.UTF-8
14:44:58 INFO: DeepStream: safe_apt_install “sudo apt-get update” 5
14:44:58 INFO: DeepStream: safe_apt_install "sudo apt-get install -y libssl1.0.0 libgstreamer1.0-0 libgstreamer1.0-dev libgstreamer-plugins-base1.0-dev gstreamer1.0-tools gstreamer1.0-plugins-good gstreamer1.0-plugins-bad gstreamer1.0-plugins-ugly gstreamer1.0-libav libgstrtspserver-1.0-0 libjansson4 librdkafka1=0.11.3-1build1 " 5
14:44:58 INFO: DeepStream: exec_command: scp -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no /tmp/tmp_NV_DEEPSTREAM_TARGET_POST_INSTALL_COMP.sh loulou@192.168.55.1:~; ssh -t -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no loulou@192.168.55.1 “~/tmp_NV_DEEPSTREAM_TARGET_POST_INSTALL_COMP.sh && rm -f ~/tmp_NV_DEEPSTREAM_TARGET_POST_INSTALL_COMP.sh”
14:44:58 INFO: DeepStream: [target] loulou@192.168.55.1’s password:
14:44:59 INFO: DeepStream: *begin sudo apt-get update, 5
14:44:59 INFO: DeepStream: [target] [sudo] password for loulou:
14:44:59 INFO: DeepStream: Hit:1 Index of /ubuntu-ports bionic InRelease
14:44:59 INFO: DeepStream: Hit:2 https://repo.download.nvidia.com/jetson/common r32.4 InRelease
14:44:59 INFO: DeepStream: Hit:3 Index of /ubuntu-ports bionic-updates InRelease
14:44:59 INFO: DeepStream: Hit:4 Index of /ubuntu-ports bionic-backports InRelease
14:44:59 INFO: DeepStream: Hit:5 Index of /ubuntu-ports bionic-security InRelease
14:44:59 INFO: DeepStream: Hit:6 https://repo.download.nvidia.com/jetson/t194 r32.4 InRelease
14:45:07 INFO: DeepStream: Reading package lists…
Multimedia terminal result
14:44:06 INFO: Multimedia API: verifying checksum of /home/louis/Downloads/nvidia/sdkm_downloads/nvidia-l4t-jetson-multimedia-api_32.4.4-20201016123640_arm64.deb
14:44:06 INFO: Multimedia API: Found file /home/louis/Downloads/nvidia/sdkm_downloads/nvidia-l4t-jetson-multimedia-api_32.4.4-20201016123640_arm64.deb with correct checksum, skip downloading.
14:44:34 DEBUG: Multimedia API: using adapter to install NV_L4T_MULTIMEDIA_API_TARGET_POST_INSTALL_T194_COMP@JETSON_XAVIER_NX_DEVKIT to /home/louis/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_XAVIER_NX_DEVKIT
14:44:34 INFO: Multimedia API: exec_command: ssh -t -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no loulou@192.168.55.1 “df -B1 / | tail -1 | awk ‘{ printf $4 }’”
14:44:34 INFO: Multimedia API: [target] loulou@192.168.55.1’s password:
14:44:35 INFO: Multimedia API: Using GenericInstaller to Install NV_L4T_MULTIMEDIA_API_TARGET_POST_INSTALL_T194_COMP
14:44:35 INFO: Multimedia API: NV_L4T_MULTIMEDIA_API_TARGET_POST_INSTALL_T194_COMP include 1 package
14:44:35 INFO: Multimedia API: [ Package Install Started ]
14:44:35 INFO: Multimedia API: target deb installer start to install
14:44:35 INFO: Multimedia API: exec_command: dpkg -f /home/louis/Downloads/nvidia/sdkm_downloads/nvidia-l4t-jetson-multimedia-api_32.4.4-20201016123640_arm64.deb Package | tr -d ‘\n’
14:44:35 INFO: Multimedia API: exec_command: dpkg -f /home/louis/Downloads/nvidia/sdkm_downloads/nvidia-l4t-jetson-multimedia-api_32.4.4-20201016123640_arm64.deb Version | tr -d ‘\n’
14:44:35 INFO: Multimedia API: deb file /home/louis/Downloads/nvidia/sdkm_downloads/nvidia-l4t-jetson-multimedia-api_32.4.4-20201016123640_arm64.deb, package name [nvidia-l4t-jetson-multimedia-api], package version [32.4.4-20201016123640]
14:44:35 INFO: Multimedia API: infer package info from file name nvidia-l4t-jetson-multimedia-api_32.4.4-20201016123640_arm64.deb [ name: nvidia-l4t-jetson-multimedia-api, version: 32.4.4-20201016123640 ]
14:44:35 INFO: Multimedia API: exec_command [target]:
14:44:35 INFO: Multimedia API: **********************
14:44:35 INFO: Multimedia API: #!/bin/bash
14:44:35 INFO: Multimedia API: set -e
14:44:35 INFO: Multimedia API: export LC_ALL=en_US.UTF-8 LANG=en_US.UTF-8 LANGUAGE=en_US.UTF-8
14:44:35 INFO: Multimedia API: sudo mkdir -p /opt/nvidia/deb_repos
14:44:35 INFO: Multimedia API: sudo chmod 777 /opt/nvidia/deb_repos
14:44:35 INFO: Multimedia API: sudo rm -f /opt/nvidia/deb_repos/nvidia-l4t-jetson-multimedia-api_32.4.4-20201016123640_arm64.deb
14:44:35 INFO: Multimedia API: [target] loulou@192.168.55.1’s password:
14:44:36 INFO: Multimedia API: [target] [sudo] password for loulou:
14:44:36 : Multimedia API: Warning: Permanently added ‘192.168.55.1’ (ECDSA) to the list of known hosts.
14:44:36 INFO: Multimedia API: [target] loulou@192.168.55.1’s password:
14:44:39 INFO: Multimedia API: nvidia-l4t-jetson-multimedia-api_32.4.4-20201 0% 0 0.0KB/s --:-- ETA nvidia-l4t-jetson-multimedia-api_32.4.4-20201 56% 38MB 37.8MB/s 00:00 ETA nvidia-l4t-jetson-multimedia-api_32.4.4-20201 100% 67MB 20.0MB/s 00:03
14:44:39 INFO: Multimedia API: exec_command [target]:
14:44:39 INFO: Multimedia API: **********************
14:44:39 INFO: Multimedia API: #!/bin/bash
14:44:39 INFO: Multimedia API: set -e
14:44:39 INFO: Multimedia API: export LC_ALL=en_US.UTF-8 LANG=en_US.UTF-8 LANGUAGE=en_US.UTF-8
14:44:39 INFO: Multimedia API: function safe_apt_install {
14:44:39 INFO: Multimedia API: echo “*begin $1, $2”
14:44:39 INFO: Multimedia API: tmp_log=/tmp/jetpack_dpkg_log.txt
14:44:39 INFO: Multimedia API: sudo rm -f $tmp_log
14:44:39 INFO: Multimedia API: set +e; $1 2>&1 | tee $tmp_log; CMD_STATUS=${PIPESTATUS[0]}; set -e
14:44:39 INFO: Multimedia API: while [ ${CMD_STATUS} -ne 0 ]; do
14:44:39 INFO: Multimedia API: if grep -q -e “is locked by another process” -e “E: Could not get lock /var/” $tmp_log; then
14:44:39 INFO: Multimedia API: echo “Waiting $2 seconds for apt to be available”; sleep ${2}
14:44:39 INFO: Multimedia API: else
Also tried sudo apt --fix-broken install and sudo apt-get update with no result.
My issue seems similar to this thread.
Any help or advice about this will be greatly welcome !
Could you share the complete log from SDK manager with us first?
STEP 04 → INSTALLATION FAILED → EXPORT LOGS.
SDKM_logs_JetPack_4.4.1_Linux_for_Jetson_Xavier_NX_[developer_kit_version]_2020-11-20_09-38-53.zip (167.5 KB)
The error code 67 is related to the link issue.
Could you delete the download folder and try to install it again?
ENOLINK 67 Link has been severed
Thanks for your answer,
The folder at ~/Downloads/nvidia/sdkm_downloads ?
If you’re talking about this one, i just noticed that i have nothing else in that folder except the nvidia folder. Maybe the SDKM create the folder ~/Downloads if it’s not there (I don’t have an English Ubuntu version). And that’s why my installation fails.
I’m sorry i can’t remember which step was necessary to get this Downloads folder, was that when i tried to install components with SDKM ?
The default download folder is located at ${HOME}/Downloads/nvidia/sdkm_downloads.
Based on your log, all the required .deb is downloaded into the /home/louis/Downloads/nvidia/sdkm_downloads/.
The file might be deleted if a clean option is selected through the SDKmanager.
For now, since the folder is empty, could you run the installation again to see if all the deb can be successfully downloaded this time?
Hi AastaLLL,
Thank you again for your answer. My last reply wasn’t very clear so let me clarify this :
  • The ~/Downloads folder only have the nvidia/sdkm_downloads folder.
  • The folder ~/Downloads/nvidia/sdkm_downloads has .deb files, like you said.
First i tried to install it again but with no success.
Then I deleted the ~/Donwloads/nvidia folder and reinstall with SDKM and got a Warning : "Installation of ‘Flash jetson Xavier NX [Devkit]’ is taking longer than expected.
After pressing Try again, it couldn’t detect the NX. And my installation fails as before (except for the target component that are skipped).
Log of failed installation : SDKM_logs_JetPack_4.4_Linux_for_Jetson_Xavier_NX_[developer_kit_version]_2020-11-25_11-36-07.zip (140.5 KB)
More informations :
  • I’m using the automatic setup in SDKM to put my NX into recovery mode.
  • I have an ethernet cable between my NX and my PC and a usb cable.
Thanks again for your time !
Thanks for testing this again.
We are checking this issue with our internal team.
Will share more information with you once we have any finding.
Hi AastaLLL,
Do you have any news about this ?
Sorry to keep you waiting.
Based on the error log below, it seems that somehow the CUDA installation is blocked in your environment.
And the CUDA failure prevents other packages from being installed.
May I know which GPU driver do you use?
You can find this information via running nvidia-smi on the console directly.
$ sudo nvidia-smi
Ex.
$ nvidia-smi
Fri Dec 18 13:13:34 2020
| NVIDIA-SMI 455.45.01 Driver Version: 455.45.01 CUDA Version: 11.1 |
hi AastaLLL,
louis@louis-All-Series:~$ sudo nvidia-smi
| | | MIG M. |
| 0 GeForce GTX 780 Ti Off | 00000000:01:00.0 N/A | N/A |
| 17% 37C P8 N/A / N/A | 242MiB / 3018MiB | N/A Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| No running processes found |
Thanks for your update, and the GPU driver looks compatible.
Let us check this issue with our internal team and get back to you later.
Thanks for your patience.
After discussing with our internal team, could you uninstall all CUDA version and reinstall it again.
  1. Use dpkg -l | grep cuda command to list all CUDA packages.
  2. Use sudo dpkg --purge <cuda_packages_listed_above> command to remove CUDA packages one by one
  3. Reinstall CUDA
Hi AastaLLL,
Thank you for your reply.
I purged all of the cuda packages and successfully reinstall everything with SDKM, so thank you so much for your help !
I tried to do something similar by purging every nvidia packages, but it didn’t work, so i guess i should have reinstalled cuda.
Do you have any idea why my first download went wrong ?
I will probably create a new thread because i’m struggling to cross-compile on my NX, but as I start with the development of Nvidia board, this may be an easy question for you :
  • The sample application works fine on my host pc, but when i try to cross-compile my code doesn’t execute and i have “permission denied”.
Good to know the CUDA installation is working now.
The original error may cause by some incompatible driver/libraries.
To cross-compile an app, you will need the root authority.
Here is a related topic for enabling authority for your reference:
