I’m using SDK Manager 1.3.1.7110 and get the following error when installing JetPack 4.4.1 Linux on the host (ubuntu 18.04) with custom download folder xavier_sdkmanager_download:
11:34:14 INFO: VPI on Host: exec_command: dpkg -f xavier_sdkmanager_download/vpi-lib-0.4.4-cuda10-x86_64-linux.deb Package | tr -d '\n'
11:34:14 INFO: VPI on Host: exec_command: dpkg -f xavier_sdkmanager_download/vpi-lib-0.4.4-cuda10-x86_64-linux.deb Version | tr -d '\n'
11:34:14 ERROR: VPI on Host: command terminated with error
11:34:14 SUMMARY: VPI Cross Compile Package on Host: Depends on failed component
And similar errors for other packages.
When I run the command in terminal, no error occurs:
$ sudo dpkg -f xavier_sdkmanager_download/vpi-lib-0.4.4-cuda10-x86_64-linux.deb Package | tr -d '\n'
vpi$ echo $?
0
I can even install the packages manually without issues, but the SDK Manager always responds with INSTALLATION ERROR.
How can I fix it?
