I use SDK Manager to flash my Jetson Xavier with Jetpack 4.2.2. However it always encountered the CUDA install error with Target as follows:
14:16:40 INFO : CUDA Toolkit for L4T : Found file /home/ujing/JetPack4.2/Jetpack4.2.2/cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64.deb with correct checksum, skip downloading.
14:40:00 DEBUG : CUDA Toolkit for L4T : running command < cd '/home/ujing/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P2888' ; '/opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter' -a='install' -c='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' -i='NV_L4T_CUDA_TARGET_POST_INSTALL_COMP' -v='10.0' -l='/home/ujing/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P2888' -L='/home/ujing/.nvsdkm/logs/JetPack_4.2.2_Linux_GA' -p='4816' -t='P2888' -e='/home/ujing/JetPack4.2/Jetpack4.2.2/cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64.deb' >
14:40:00 INFO : CUDA Toolkit for L4T : [ Disk Avail:1.31 GB ]
14:40:00 INFO : CUDA Toolkit for L4T : Using GenericInstaller to Install NV_L4T_CUDA_TARGET_POST_INSTALL_COMP
14:40:00 INFO : CUDA Toolkit for L4T : NV_L4T_CUDA_TARGET_POST_INSTALL_COMP include 1 package
14:40:00 INFO : CUDA Toolkit for L4T : [ Package Install Started ]
14:40:00 INFO : CUDA Toolkit for L4T : target deb installer start to install
14:40:00 INFO : CUDA Toolkit for L4T : exec_command: dpkg -f /home/ujing/JetPack4.2/Jetpack4.2.2/cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64.deb Package | tr -d '\n'
14:40:00 INFO : CUDA Toolkit for L4T : exec_command: dpkg -f /home/ujing/JetPack4.2/Jetpack4.2.2/cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64.deb Version | tr -d '\n'
14:40:00 INFO : CUDA Toolkit for L4T : deb file /home/ujing/JetPack4.2/Jetpack4.2.2/cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64.deb, package name [cuda-repo-l4t-10-0-local-10.0.326], package version [1.0-1]
14:40:00 INFO : CUDA Toolkit for L4T : infer package info from file name cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64.deb [ name: cuda-repo-l4t-10-0-local-10.0.326, version: 1.0-1 ]
14:40:00 INFO : CUDA Toolkit for L4T : exec_command [target]:
14:40:00 INFO : CUDA Toolkit for L4T : **********************
14:40:00 INFO : CUDA Toolkit for L4T : #!/bin/bash
14:40:00 INFO : CUDA Toolkit for L4T : set -e
14:40:00 INFO : CUDA Toolkit for L4T : export LC_ALL=en_US.UTF-8 LANG=en_US.UTF-8 LANGUAGE=en_US.UTF-8
14:40:00 INFO : CUDA Toolkit for L4T : sudo mkdir -p /opt/nvidia/deb_repos
14:40:00 INFO : CUDA Toolkit for L4T : sudo chmod 777 /opt/nvidia/deb_repos
14:40:00 INFO : CUDA Toolkit for L4T : sudo rm -f /opt/nvidia/deb_repos/cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64.deb
14:40:01 INFO : CUDA Toolkit for L4T : [target] nvidia@192.168.1.155's password:
14:40:02 INFO : CUDA Toolkit for L4T : [target] nvidia@192.168.1.155's password:
14:40:03 INFO : CUDA Toolkit for L4T : [target] [sudo] password for nvidia:
14:40:04 WARNING : CUDA Toolkit for L4T : Warning: Permanently added '192.168.1.155' (ECDSA) to the list of known hosts.
14:40:04 INFO : CUDA Toolkit for L4T : [target] nvidia@192.168.1.155's password:
14:42:15 INFO : CUDA Toolkit for L4T : cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64 0% 0 0.0KB/s --:-- ETA cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64 1% 11MB 10.6MB/s 01:29 ETA cuda-repo-l4t-10-0-local-10.0.326_1.0-1_
14:42:15 INFO : CUDA Toolkit for L4T : exec_command: dpkg -c /home/ujing/JetPack4.2/Jetpack4.2.2/cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64.deb | awk '{ print $6 }' | grep '\.pub | sed 's/^\.//' | tr -d '\n'
14:42:17 INFO : CUDA Toolkit for L4T : exec_command [target]:
14:42:17 INFO : CUDA Toolkit for L4T : **********************
14:42:17 INFO : CUDA Toolkit for L4T : #!/bin/bash
14:42:17 INFO : CUDA Toolkit for L4T : set -e
14:42:17 INFO : CUDA Toolkit for L4T : export LC_ALL=en_US.UTF-8 LANG=en_US.UTF-8 LANGUAGE=en_US.UTF-8
14:42:17 INFO : CUDA Toolkit for L4T : function safe_apt_install {
14:42:17 INFO : CUDA Toolkit for L4T : echo "*begin $1, $2"
14:42:17 INFO : CUDA Toolkit for L4T : tmp_log=/tmp/jetpack_dpkg_log.txt
14:42:17 INFO : CUDA Toolkit for L4T : sudo rm -f $tmp_log
14:42:17 INFO : CUDA Toolkit for L4T : set +e; $1 2>&1 | tee $tmp_log; CMD_STATUS=${PIPESTATUS[0]}; set -e
14:42:17 INFO : CUDA Toolkit for L4T : while [ ${CMD_STATUS} -ne 0 ]; do
14:42:17 INFO : CUDA Toolkit for L4T : if grep -q -e "is locked by another process" -e "E: Could not get lock /var/lib" $tmp_log; then
14:42:17 INFO : CUDA Toolkit for L4T : echo "Waiting $2 seconds for apt to be available"; sleep ${2}
14:42:17 INFO : CUDA Toolkit for L4T : else
14:42:17 INFO : CUDA Toolkit for L4T : echo "Unhandled error when running $1"; exit 1
14:42:17 INFO : CUDA Toolkit for L4T : fi
14:42:17 INFO : CUDA Toolkit for L4T : done
14:42:17 INFO : CUDA Toolkit for L4T : }
14:42:17 INFO : CUDA Toolkit for L4T : safe_apt_install "sudo dpkg -i /opt/nvidia/deb_repos/cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64.deb" 5
14:42:17 INFO : CUDA Toolkit for L4T : sleep 5
14:42:17 INFO : CUDA Toolkit for L4T : safe_apt_install "sudo apt-key add /var/cuda-repo-10-0-local-10.0.326/7fa2af80.pub" 5
14:42:17 INFO : CUDA Toolkit for L4T : sleep 2
14:42:17 INFO : CUDA Toolkit for L4T : safe_apt_install "sudo apt-get -y update" 5
14:42:17 INFO : CUDA Toolkit for L4T : safe_apt_install "sudo apt-get -y install cuda-toolkit-10-0 " 5
14:42:17 INFO : CUDA Toolkit for L4T : sudo rm -f /opt/nvidia/deb_repos/cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64.deb
14:42:17 INFO : CUDA Toolkit for L4T : [target] nvidia@192.168.1.155's password:
14:42:18 INFO : CUDA Toolkit for L4T : [target] nvidia@192.168.1.155's password:
14:42:19 INFO : CUDA Toolkit for L4T : *begin sudo dpkg -i /opt/nvidia/deb_repos/cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64.deb, 5
14:42:19 INFO : CUDA Toolkit for L4T : [target] [sudo] password for nvidia:
14:42:19 INFO : CUDA Toolkit for L4T : Selecting previously unselected package cuda-repo-l4t-10-0-local-10.0.326.
14:42:19 INFO : CUDA Toolkit for L4T : (Reading database ... 118029 files and directories currently installed.)
14:42:19 INFO : CUDA Toolkit for L4T : Preparing to unpack .../cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64.deb ...
14:42:19 INFO : CUDA Toolkit for L4T : Unpacking cuda-repo-l4t-10-0-local-10.0.326 (1.0-1) ...
14:42:32 INFO : CUDA Toolkit for L4T : Setting up cuda-repo-l4t-10-0-local-10.0.326 (1.0-1) ...
14:42:32 INFO : CUDA Toolkit for L4T : The public CUDA GPG key does not appear to be installed.
14:42:32 INFO : CUDA Toolkit for L4T : To install the key, run this command:
14:42:32 INFO : CUDA Toolkit for L4T : sudo apt-key add /var/cuda-repo-10-0-local-10.0.326/7fa2af80.pub
14:42:37 INFO : CUDA Toolkit for L4T : *begin sudo apt-key add /var/cuda-repo-10-0-local-10.0.326/7fa2af80.pub, 5
14:42:38 INFO : CUDA Toolkit for L4T : Warning: apt-key output should not be parsed (stdout is not a terminal)
14:42:38 INFO : CUDA Toolkit for L4T : OK
14:42:40 INFO : CUDA Toolkit for L4T : *begin sudo apt-get -y update, 5
14:42:40 INFO : CUDA Toolkit for L4T : Get:1 file:/var/cuda-repo-10-0-local-10.0.326 InRelease
14:42:40 INFO : CUDA Toolkit for L4T : Ign:1 file:/var/cuda-repo-10-0-local-10.0.326 InRelease
14:42:40 INFO : CUDA Toolkit for L4T : Get:2 file:/var/cuda-repo-10-0-local-10.0.326 Release [574 B]
14:42:40 INFO : CUDA Toolkit for L4T : Get:3 file:/var/cuda-repo-10-0-local-10.0.326 Release.gpg [819 B]
14:42:41 INFO : CUDA Toolkit for L4T : Get:4 file:/var/cuda-repo-10-0-local-10.0.326 Packages [11.3 kB]
14:43:11 INFO : CUDA Toolkit for L4T : Err:5 http://ports.ubuntu.com/ubuntu-ports bionic InRelease
14:43:11 INFO : CUDA Toolkit for L4T : Cannot initiate the connection to ports.ubuntu.com:80 (2001:67c:1360:8001::22). - connect (101: Network is unreachable) Could not connect to ports.ubuntu.com:80 (91.189.88.150), connection timed out
14:43:11 INFO : CUDA Toolkit for L4T : Err:6 http://ports.ubuntu.com/ubuntu-ports bionic-updates InRelease
14:43:11 INFO : CUDA Toolkit for L4T : Err:7 http://ports.ubuntu.com/ubuntu-ports bionic-backports InRelease
14:43:11 INFO : CUDA Toolkit for L4T : Err:8 http://ports.ubuntu.com/ubuntu-ports bionic-security InRelease
14:43:13 INFO : CUDA Toolkit for L4T : Reading package lists...
14:43:13 INFO : CUDA Toolkit for L4T : W: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/dists/bionic/InRelease Cannot initiate the connection to ports.ubuntu.com:80 (2001:67c:1360:8001::22). - connect (101: Network is unreachable) Could not connect to ports.ubuntu.com:80 (91.189.88.150), connection timed out
14:43:13 INFO : CUDA Toolkit for L4T : W: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/dists/bionic-updates/InRelease Cannot initiate the connection to ports.ubuntu.com:80 (2001:67c:1360:8001::22). - connect (101: Network is unreachable)
14:43:13 INFO : CUDA Toolkit for L4T : W: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/dists/bionic-backports/InRelease Cannot initiate the connection to ports.ubuntu.com:80 (2001:67c:1360:8001::22). - connect (101: Network is unreachable)
14:43:13 INFO : CUDA Toolkit for L4T : W: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/dists/bionic-security/InRelease Cannot initiate the connection to ports.ubuntu.com:80 (2001:67c:1360:8001::22). - connect (101: Network is unreachable)
14:43:13 INFO : CUDA Toolkit for L4T : W: Some index files failed to download. They have been ignored, or old ones used instead.
14:43:13 INFO : CUDA Toolkit for L4T : *begin sudo apt-get -y install cuda-toolkit-10-0 , 5
14:43:13 INFO : CUDA Toolkit for L4T : Building dependency tree...
14:43:13 INFO : CUDA Toolkit for L4T : Reading state information...
14:43:13 INFO : CUDA Toolkit for L4T : Some packages could not be installed. This may mean that you have
14:43:13 INFO : CUDA Toolkit for L4T : requested an impossible situation or if you are using the unstable
14:43:13 INFO : CUDA Toolkit for L4T : distribution that some required packages have not yet been created
14:43:13 INFO : CUDA Toolkit for L4T : or been moved out of Incoming.
14:43:13 INFO : CUDA Toolkit for L4T : The following information may help to resolve the situation:
14:43:13 INFO : CUDA Toolkit for L4T : The following packages have unmet dependencies:
14:43:13 INFO : CUDA Toolkit for L4T : cuda-toolkit-10-0 : Depends: cuda-samples-10-0 (>= 10.0.326) but it is not going to be installed
14:43:13 INFO : CUDA Toolkit for L4T : Depends: cuda-documentation-10-0 (>= 10.0.326) but it is not going to be installed
14:43:13 INFO : CUDA Toolkit for L4T : E: Unable to correct problems, you have held broken packages.
14:43:13 INFO : CUDA Toolkit for L4T : Unhandled error when running sudo apt-get -y install cuda-toolkit-10-0
14:43:13 INFO : CUDA Toolkit for L4T : exit status 1
14:43:13 INFO : CUDA Toolkit for L4T : [ Package Install Finished with Error ]
14:43:13 INFO : CUDA Toolkit for L4T : [ 108.00 KB used. Disk Avail: 1.31 GB ]
14:43:13 INFO : CUDA Toolkit for L4T : [ NV_L4T_CUDA_TARGET_POST_INSTALL_COMP Install took 3m12s ]
14:43:13 ERROR : CUDA Toolkit for L4T : command scp -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no /tmp/tmp_NV_L4T_CUDA_TARGET_POST_INSTALL_COMP.sh nvidia@192.168.1.155:~; ssh -t -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no nvidia@192.168.1.155 "~/tmp_NV_L4T_CUDA_TARGET_POST_INSTALL_COMP.sh && rm -f ~/tmp_NV_L4T_CUDA_TARGET_POST_INSTALL_COMP.sh" finished with error
14:43:13 ERROR : CUDA Toolkit for L4T : command terminated with error
On a recent release the login account is not created until first boot. After the flash, did you have a monitor/keyboard attached and did you create a login account? I forget if 4.2.2 requires this, but on the flashed Xavier, are you able to log in to it locally or via ssh or via serial console? If you can do any of those things, then a login account is not an issue.
If it turns out to not be a login account issue, then from your host, what is the output of “ifconfig”? Do you see an interface with IP address 192.168.55.100?
scp was using “nvidia@192.168.1.155” for its login. Is the the account your ssh test succeeded with? If the ssh was ok, then it was probably this file on the host PC side not existing:
Basically the command which failed was trying to copy that file on your host to the Jetson. The file itself is part of the NVIDIA files, and does not require access to any of the Ubuntu servers (though I don’t know if this is downloaded from an NVIDIA server or part of SDK Manager…I suspect it has to be downloaded).
The actual network traffic to 192.168.1.155 would be through wlp3s0 (which is “192.168.1.179/24”). This interface did show a dropped packet, but it is hard to say if this was the cause of the ssh failure (in which case the earlier mentioned “tmp_NV_L4T_CUDA_TARGET_POST_INSTALL_COMP.sh” would have been ok and networking would have been the scp failure cause). Some dropped packets are not fatal, e.g., when using TCP, and though this is suspicious my bet would be on the network itself not being the issue (there was a lot of traffic through the link and only one packet was dropped).
Would anyone from NVIDIA be able to comment on whether “~/tmp_NV_L4T_CUDA_TARGET_POST_INSTALL_COMP.sh” is downloaded via the manifest, and if so, would install of CUDA have stopped at that point, or would install have continued until scp failed to copy the file?
Hi,I also encountered some problems when I installed Jetson Xavier,the errors are as followed:
7:10:36 ERROR : Drivers for Jetson AGX : E: Failed to fetch http://mirrors.zte.com.cn/ubuntu/dists/xenial-backports/main/dep11/Components-amd64.yml.xz Hash Sum mismatch
18:00:45 ERROR : NVIDIA Nsight Graphics : download error: checksum is wrong
18:14:58 ERROR : TensorRT on Target : download error: checksum is wrong
18:27:29 ERROR : NVIDIA Nsight Systems : update-alternatives: error: alternative path is not absolute as it should be:
18:35:27 ERROR : CUDA on Host : E: Failed to fetch http://mirrors.zte.com.cn/ubuntu/dists/xenial-backports/main/dep11/Components-amd64.yml.gz Hash Sum mismatch
18:35:27 ERROR : CUDA on Host : E: Failed to fetch http://mirrors.zte.com.cn/ubuntu/dists/xenial-security/main/dep11/Components-amd64.yml.xz Hash Sum mismatch
18:35:41 ERROR : CUDA on Host : Extracting templates from packages: 40%
18:35:41 ERROR : CUDA on Host : Extracting templates from packages: 80%
18:35:41 ERROR : CUDA on Host : Extracting templates from packages: 100%
18:37:01 ERROR : OpenCV on Host : dpkg: dependency problems prevent configuration of libopencv:
18:37:01 ERROR : OpenCV on Host : Errors were encountered while processing:
18:37:02 ERROR : OpenCV on Host : E: Unmet dependencies. Try using -f.
18:37:05 ERROR : OpenCV on Host : dpkg: considering removing python-opencv in favour of libopencv-python ...
18:37:15 ERROR : CUDA Cross Compile Package on Host : E: Failed to fetch http://mirrors.zte.com.cn/ubuntu/dists/xenial-backports/universe/dep11/Components-amd64.yml.xz Hash Sum mismatch
18:37:15 ERROR : CUDA Cross Compile Package on Host : E: Failed to fetch http://mirrors.zte.com.cn/ubuntu/dists/xenial-security/main/dep11/Components-amd64.yml.xz Hash Sum mismatch
18:37:25 ERROR : CUDA Cross Compile Package on Host : Extracting templates from packages: 85%
18:37:25 ERROR : CUDA Cross Compile Package on Host : Extracting templates from packages: 100%
18:37:58 ERROR : VisionWorks on Host : E: Failed to fetch http://mirrors.zte.com.cn/ubuntu/dists/xenial-backports/main/dep11/Components-amd64.yml.gz
18:37:58 ERROR : VisionWorks on Host : E: Failed to fetch http://mirrors.zte.com.cn/ubuntu/dists/xenial-security/multiverse/dep11/Components-amd64.yml.xz 404 Not Found
18:38:12 ERROR : VisionWorks on Host : E: Failed to fetch http://mirrors.zte.com.cn/ubuntu/dists/xenial-backports/universe/dep11/Components-amd64.yml.xz Hash Sum mismatch
18:38:12 ERROR : VisionWorks on Host : E: Failed to fetch http://mirrors.zte.com.cn/ubuntu/dists/xenial-security/main/dep11/Components-amd64.yml.xz Hash Sum mismatch
18:38:21 ERROR : VisionWorks on Host : E: Failed to fetch http://mirrors.zte.com.cn/ubuntu/dists/xenial-backports/universe/dep11/Components-amd64.yml.xz Hash Sum mismatch
18:38:21 ERROR : VisionWorks on Host : E: Some index files failed to download. They have been ignored, or old ones used instead.
18:38:25 ERROR : command terminated with error
18:38:25 ERROR : Could not detect Nvidia Jetson device connected to USB. *To validate if the device is in connected correctly, run 'lsusb' command on your host, and look for "0955:7019" (NVIDIA Corp).
08:38:00 ERROR : command terminated with error
08:38:00 ERROR : Could not detect Nvidia Jetson device connected to USB. *To validate if the device is in connected correctly, run 'lsusb' command on your host, and look for "0955:7019" (NVIDIA Corp).
08:38:12 ERROR : command terminated with error
08:38:12 ERROR : Could not detect Nvidia Jetson device connected to USB. *To validate if the device is in connected correctly, run 'lsusb' command on your host, and look for "0955:7019" (NVIDIA Corp).
08:38:24 ERROR : command terminated with error
08:38:24 ERROR : Could not detect Nvidia Jetson device connected to USB. *To validate if the device is in connected correctly, run 'lsusb' command on your host, and look for "0955:7019" (NVIDIA Corp).
08:38:36 ERROR : command terminated with error
08:38:36 ERROR : Could not detect Nvidia Jetson device connected to USB. *To validate if the device is in connected correctly, run 'lsusb' command on your host, and look for "0955:7019" (NVIDIA Corp).
08:38:48 ERROR : command terminated with error
08:38:48 ERROR : Could not detect Nvidia Jetson device connected to USB. *To validate if the device is in connected correctly, run 'lsusb' command on your host, and look for "0955:7019" (NVIDIA Corp).
08:39:00 ERROR : command terminated with error
08:39:00 ERROR : Could not detect Nvidia Jetson device connected to USB. *To validate if the device is in connected correctly, run 'lsusb' command on your host, and look for "0955:7019" (NVIDIA Corp).
08:39:12 ERROR : command terminated with error
08:39:12 ERROR : Could not detect Nvidia Jetson device connected to USB. *To validate if the device is in connected correctly, run 'lsusb' command on your host, and look for "0955:7019" (NVIDIA Corp).
08:39:24 ERROR : command terminated with error
08:39:24 ERROR : Failed to use 'Automatic setup'. Please try again or change to 'Manual setup' to continue.
08:39:36 ERROR : command terminated with error
08:39:36 ERROR : Failed to use 'Automatic setup'. Please try again or change to 'Manual setup' to continue.
08:39:48 ERROR : command terminated with error
08:39:48 ERROR : Failed to use 'Automatic setup'. Please try again or change to 'Manual setup' to continue.
08:45:12 ERROR : command terminated with error
08:45:34 ERROR : Flash Jetson AGX Xavier : Board ID(2888) version(400) sku(0001) revision(J.0)
08:45:35 ERROR : Flash Jetson AGX Xavier : 1+0 records in
08:48:00 ERROR : Flash Jetson AGX Xavier :
Hope you can help me solve the problems, looking forwards to your reply.
Thanks for your response, I am a little confused about " ppa repository to local ", how to change ppa repository to local? Please explain in details. Thanks a lot.
Thanks a lot.I have solved the problem. Because I didn’t make network configuration for the Xavier. As the User Guide said, we must “Connect the developer kit and Linux host computer to the same network.”
After I made network configuration for the Xavier, the installation completed successfully.
