Hi there.
I have trouble installing the SDK components on my TX2.
My host is Ubuntu 18.04 and I successfully flashed my TX2 with JetPack 4.2.
But as soon as I try to install the SDK components I get errors and installation fails.
Can somebody help me?
I can ping my Tx2 from my host and I do have Internet connection on my host.
09:56:48 INFO : CUDA Toolkit for L4T : Could not resolve ‘ports.ubuntu.com’
09:56:58 INFO : CUDA Toolkit for L4T : Err:8 http://ports.ubuntu.com/ubuntu-ports bionic-updates InRelease
09:56:58 INFO : CUDA Toolkit for L4T : Could not resolve ‘ports.ubuntu.com’
09:57:08 INFO : CUDA Toolkit for L4T : Err:9 http://ports.ubuntu.com/ubuntu-ports bionic-backports InRelease
09:57:08 INFO : CUDA Toolkit for L4T : Could not resolve ‘ports.ubuntu.com’
09:57:18 INFO : CUDA Toolkit for L4T : Err:10 http://ports.ubuntu.com/ubuntu-ports bionic-security InRelease
09:57:18 INFO : CUDA Toolkit for L4T : Could not resolve ‘ports.ubuntu.com’
09:57:19 INFO : CUDA Toolkit for L4T : Reading package lists…
09:57:19 INFO : CUDA Toolkit for L4T : W: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/dists/bionic/InRelease Could not resolve ‘ports.ubuntu.com’
09:57:19 INFO : CUDA Toolkit for L4T : W: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/dists/bionic-updates/InRelease Could not resolve ‘ports.ubuntu.com’
09:57:19 INFO : CUDA Toolkit for L4T : W: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/dists/bionic-backports/InRelease Could not resolve ‘ports.ubuntu.com’
09:57:19 INFO : CUDA Toolkit for L4T : W: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/dists/bionic-security/InRelease Could not resolve ‘ports.ubuntu.com’
09:57:19 INFO : CUDA Toolkit for L4T : W: Some index files failed to download. They have been ignored, or old ones used instead.
09:57:19 INFO : CUDA Toolkit for L4T : begin sudo apt-get install -y gnupg, 5
09:57:19 INFO : CUDA Toolkit for L4T : Building dependency tree…
09:57:19 INFO : CUDA Toolkit for L4T : Reading state information…
09:57:19 INFO : CUDA Toolkit for L4T : gnupg is already the newest version (2.2.4-1ubuntu1.2).
09:57:19 INFO : CUDA Toolkit for L4T : The following packages were automatically installed and are no longer required:
09:57:19 INFO : CUDA Toolkit for L4T : apt-clone archdetect-deb busybox-static cryptsetup-bin dpkg-repack
09:57:19 INFO : CUDA Toolkit for L4T : gir1.2-timezonemap-1.0 gir1.2-xkl-1.0 grub-common kde-window-manager kinit
09:57:19 INFO : CUDA Toolkit for L4T : kio kpackagetool5 kwayland-data kwin-common kwin-data kwin-x11
09:57:19 INFO : CUDA Toolkit for L4T : libdebian-installer4 libkdecorations2-5v5 libkdecorations2private5v5
09:57:19 INFO : CUDA Toolkit for L4T : libkf5activities5 libkf5attica5 libkf5completion-data libkf5completion5
09:57:19 INFO : CUDA Toolkit for L4T : libkf5declarative-data libkf5declarative5 libkf5doctools5
09:57:19 INFO : CUDA Toolkit for L4T : libkf5globalaccel-data libkf5globalaccel5 libkf5globalaccelprivate5
09:57:19 INFO : CUDA Toolkit for L4T : libkf5idletime5 libkf5jobwidgets-data libkf5jobwidgets5 libkf5kcmutils-data
09:57:19 INFO : CUDA Toolkit for L4T : libkf5kcmutils5 libkf5kiocore5 libkf5kiontlm5 libkf5kiowidgets5
09:57:19 INFO : CUDA Toolkit for L4T : libkf5newstuff-data libkf5newstuff5 libkf5newstuffcore5 libkf5package-data
09:57:19 INFO : CUDA Toolkit for L4T : libkf5package5 libkf5plasma5 libkf5quickaddons5 libkf5solid5
09:57:19 INFO : CUDA Toolkit for L4T : libkf5solid5-data libkf5sonnet5-data libkf5sonnetcore5 libkf5sonnetui5
09:57:19 INFO : CUDA Toolkit for L4T : libkf5textwidgets-data libkf5textwidgets5 libkf5waylandclient5
09:57:19 INFO : CUDA Toolkit for L4T : libkf5waylandserver5 libkf5xmlgui-bin libkf5xmlgui-data libkf5xmlgui5
09:57:19 INFO : CUDA Toolkit for L4T : libkscreenlocker5 libkwin4-effect-builtins1 libkwineffects11
09:57:19 INFO : CUDA Toolkit for L4T : libkwinglutils11 libkwinxrenderutils11 libqgsttools-p1 libqt5designer5
09:57:19 INFO : CUDA Toolkit for L4T : libqt5help5 libqt5multimedia5 libqt5multimedia5-plugins
09:57:19 INFO : CUDA Toolkit for L4T : libqt5multimediaquick-p5 libqt5multimediawidgets5 libqt5opengl5
09:57:19 INFO : CUDA Toolkit for L4T : libqt5positioning5 libqt5printsupport5 libqt5qml5 libqt5quick5
09:57:19 INFO : CUDA Toolkit for L4T : libqt5quickwidgets5 libqt5sensors5 libqt5sql5 libqt5test5 libqt5webchannel5
09:57:19 INFO : CUDA Toolkit for L4T : libqt5webkit5 libxcb-composite0 libxcb-cursor0 libxcb-damage0 os-prober
09:57:19 INFO : CUDA Toolkit for L4T : python3-dbus.mainloop.pyqt5 python3-icu python3-pam python3-pyqt5
09:57:19 INFO : CUDA Toolkit for L4T : python3-pyqt5.qtsvg python3-pyqt5.qtwebkit python3-sip
09:57:19 INFO : CUDA Toolkit for L4T : qml-module-org-kde-kquickcontrolsaddons qml-module-qtmultimedia
09:57:19 INFO : CUDA Toolkit for L4T : qml-module-qtquick2 rdate
09:57:19 INFO : CUDA Toolkit for L4T : Use ‘sudo apt autoremove’ to remove them.
09:57:19 INFO : CUDA Toolkit for L4T : 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
09:57:19 INFO : CUDA Toolkit for L4T : begin sudo apt-get -y --allow-downgrades install cuda-toolkit-10-0 libgomp1 libfreeimage-dev libopenmpi-dev openmpi-bin, 5
09:57:19 INFO : CUDA Toolkit for L4T : E: Unable to locate package libfreeimage-dev
09:57:19 INFO : CUDA Toolkit for L4T : E: Unable to locate package libopenmpi-dev
09:57:19 INFO : CUDA Toolkit for L4T : E: Unable to locate package openmpi-bin
09:57:19 INFO : CUDA Toolkit for L4T : Unhandled error when running sudo apt-get -y --allow-downgrades install cuda-toolkit-10-0 libgomp1 libfreeimage-dev libopenmpi-dev openmpi-bin
09:57:19 INFO : CUDA Toolkit for L4T : exit status 1
09:57:19 INFO : CUDA Toolkit for L4T : [ Package Install Finished with Error ]
09:57:19 INFO : CUDA Toolkit for L4T : [ 124.00 KB used. Disk Avail: 49.91 GB ]
09:57:19 INFO : CUDA Toolkit for L4T : [ NV_L4T_CUDA_TARGET_POST_INSTALL_COMP Install took 1m33s ]
09:57:19 ERROR : CUDA Toolkit for L4T : Run commands failed at step Install: command scp -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no /tmp/tmp_NV_L4T_CUDA_TARGET_POST_INSTALL_COMP.sh nvidia@10.42.0.1:~; ssh -t -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no nvidia@10.42.0.1 “~/tmp_NV_L4T_CUDA_TARGET_POST_INSTALL_COMP.sh && rm -f ~/tmp_NV_L4T_CUDA_TARGET_POST_INSTALL_COMP.sh” finished with error
09:57:19 ERROR : CUDA Toolkit for L4T : command terminated with error
09:59:20 INFO : CUDA Toolkit for L4T : Found file /home/fhoby/Downloads/nvidia/sdkm_downloads/cuda-repo-l4t-10-0-local-10.0.166_1.0-1_arm64.deb with correct checksum, skip downloading.
09:59:25 DEBUG : CUDA Toolkit for L4T : running command < cd ‘/home/fhoby/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3310’ ; ‘/opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter’ -a=‘install’ -c=‘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’ -i=‘NV_L4T_CUDA_TARGET_POST_INSTALL_COMP’ -v=‘10.0’ -l=’/home/fhoby/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3310’ -L=’/home/fhoby/.nvsdkm/logs/JetPack_4.2_Linux’ -p=‘16785’ -t=‘P3310’ -e=’/home/fhoby/Downloads/nvidia/sdkm_downloads/cuda-repo-l4t-10-0-local-10.0.166_1.0-1_arm64.deb’ >
09:59:25 INFO : CUDA Toolkit for L4T : [ Disk Avail:49.91 GB ]
09:59:25 INFO : CUDA Toolkit for L4T : Using GenericInstaller to Install NV_L4T_CUDA_TARGET_POST_INSTALL_COMP
09:59:25 INFO : CUDA Toolkit for L4T : NV_L4T_CUDA_TARGET_POST_INSTALL_COMP include 1 package
09:59:25 INFO : CUDA Toolkit for L4T : [ Package Install Started ]
09:59:25 INFO : CUDA Toolkit for L4T : current working directory is /home/fhoby/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3310
09:59:25 INFO : CUDA Toolkit for L4T : exec_command [target]:
09:59:25 INFO : CUDA Toolkit for L4T : **********************
09:59:25 INFO : CUDA Toolkit for L4T : #!/bin/bash
09:59:25 INFO : CUDA Toolkit for L4T : set -e
09:59:25 INFO : CUDA Toolkit for L4T : export LC_ALL=en_US.UTF-8 LANG=en_US.UTF-8 LANGUAGE=en_US.UTF-8
09:59:25 INFO : CUDA Toolkit for L4T : sudo mkdir -p /opt/nvidia/deb_repos
09:59:25 INFO : CUDA Toolkit for L4T : sudo chmod 777 /opt/nvidia/deb_repos
09:59:25 INFO : CUDA Toolkit for L4T : sudo rm -f /opt/nvidia/deb_repos/cuda-repo-l4t-10-0-local-10.0.166_1.0-1_arm64.deb
09:59:25 INFO : CUDA Toolkit for L4T : exec_command: scp -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no /tmp/tmp_NV_L4T_CUDA_TARGET_POST_INSTALL_COMP.sh nvidia@10.42.0.1:~; ssh -t -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no nvidia@10.42.0.1 “~/tmp_NV_L4T_CUDA_TARGET_POST_INSTALL_COMP.sh && rm -f ~/tmp_NV_L4T_CUDA_TARGET_POST_INSTALL_COMP.sh”
09:59:25 INFO : CUDA Toolkit for L4T : [target] nvidia@10.42.0.1’s password:
09:59:26 INFO : CUDA Toolkit for L4T :
09:59:26 INFO : CUDA Toolkit for L4T : [target] [sudo] password for nvidia:
09:59:26 INFO : CUDA Toolkit for L4T : exec_command: scp -F /dev/null -o PubkeyAuthentication=no -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no -o ConnectTimeout=5 -r /home/fhoby/Downloads/nvidia/sdkm_downloads/cuda-repo-l4t-10-0-local-10.0.166_1.0-1_arm64.deb nvidia@10.42.0.1:/opt/nvidia/deb_repos/
09:59:26 WARNING : CUDA Toolkit for L4T : Warning: Permanently added ‘10.42.0.1’ (ECDSA) to the list of known hosts.
09:59:26 INFO : CUDA Toolkit for L4T : [target] nvidia@10.42.0.1’s password:
09:59:36 INFO : CUDA Toolkit for L4T : exec_command [target]:
09:59:36 INFO : CUDA Toolkit for L4T : **********************
09:59:36 INFO : CUDA Toolkit for L4T : #!/bin/bash
09:59:36 INFO : CUDA Toolkit for L4T : set -e
09:59:36 INFO : CUDA Toolkit for L4T : function safe_apt_install {
09:59:36 INFO : CUDA Toolkit for L4T : echo "begin $1, $2"
09:59:36 INFO : CUDA Toolkit for L4T : tmp_log=/tmp/jetpack_dpkg_log.txt
09:59:36 INFO : CUDA Toolkit for L4T : sudo rm -f $tmp_log
09:59:36 INFO : CUDA Toolkit for L4T : set +e; $1 2>&1 | tee tmp_log; CMD_STATUS={PIPESTATUS[0]}; set -e
09:59:36 INFO : CUDA Toolkit for L4T : while [ ${CMD_STATUS} -ne 0 ]; do
09:59:36 INFO : CUDA Toolkit for L4T : if grep -q -e “is locked by another process” -e “E: Could not get lock /var/lib” $tmp_log; then
09:59:36 INFO : CUDA Toolkit for L4T : echo "Waiting 2 seconds for apt to be available"; sleep {2}
09:59:36 INFO : CUDA Toolkit for L4T : else
09:59:36 INFO : CUDA Toolkit for L4T : echo “Unhandled error when running $1”; exit 1
09:59:36 INFO : CUDA Toolkit for L4T : fi
09:59:36 INFO : CUDA Toolkit for L4T : done
09:59:36 INFO : CUDA Toolkit for L4T : }
09:59:36 INFO : CUDA Toolkit for L4T : export LC_ALL=en_US.UTF-8 LANG=en_US.UTF-8 LANGUAGE=en_US.UTF-8
09:59:36 INFO : CUDA Toolkit for L4T : safe_apt_install “sudo dpkg -i /opt/nvidia/deb_repos/cuda-repo-l4t-10-0-local-10.0.166_1.0-1_arm64.deb” 5
09:59:36 INFO : CUDA Toolkit for L4T : sleep 5
09:59:36 INFO : CUDA Toolkit for L4T : safe_apt_install "sudo apt-key add /var/cuda-repo--local/.pub" 5
09:59:36 INFO : CUDA Toolkit for L4T : sleep 2
09:59:36 INFO : CUDA Toolkit for L4T : safe_apt_install “sudo apt-get -y update” 5
09:59:36 INFO : CUDA Toolkit for L4T : safe_apt_install “sudo apt-get install -y gnupg” 5
09:59:36 INFO : CUDA Toolkit for L4T : safe_apt_install “sudo apt-get -y --allow-downgrades install cuda-toolkit-10-0 libgomp1 libfreeimage-dev libopenmpi-dev openmpi-bin” 5
09:59:36 INFO : CUDA Toolkit for L4T : grep -q 'export PATH=./usr/local/cuda-10.0/bin’ ~/.bashrc || echo ‘export PATH=/usr/local/cuda-10.0/bin:$PATH’>>~/.bashrc
09:59:36 INFO : CUDA Toolkit for L4T : grep -q ‘export LD_LIBRARY_PATH=/usr/local/cuda-10.0/lib64’ ~/.bashrc || echo ‘export LD_LIBRARY_PATH=/usr/local/cuda-10.0/lib64:$LD_LIBRARY_PATH’ >> ~/.bashrc
09:59:36 INFO : CUDA Toolkit for L4T : sudo rm -f /opt/nvidia/deb_repos/cuda-repo-l4t-10-0-local-10.0.166_1.0-1_arm64.deb
09:59:36 INFO : CUDA Toolkit for L4T : exec_command: scp -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no /tmp/tmp_NV_L4T_CUDA_TARGET_POST_INSTALL_COMP.sh nvidia@10.42.0.1:~; ssh -t -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no nvidia@10.42.0.1 “~/tmp_NV_L4T_CUDA_TARGET_POST_INSTALL_COMP.sh && rm -f ~/tmp_NV_L4T_CUDA_TARGET_POST_INSTALL_COMP.sh”
09:59:36 INFO : CUDA Toolkit for L4T : [target] nvidia@10.42.0.1’s password:
09:59:37 INFO : CUDA Toolkit for L4T : [target] nvidia@10.42.0.1’s password:
09:59:37 INFO : CUDA Toolkit for L4T : begin sudo dpkg -i /opt/nvidia/deb_repos/cuda-repo-l4t-10-0-local-10.0.166_1.0-1_arm64.deb, 5
09:59:37 INFO : CUDA Toolkit for L4T : [target] [sudo] password for nvidia:
09:59:37 INFO : CUDA Toolkit for L4T : (Reading database … 117271 files and directories currently installed.)
09:59:37 INFO : CUDA Toolkit for L4T : Preparing to unpack …/cuda-repo-l4t-10-0-local-10.0.166_1.0-1_arm64.deb …
09:59:37 INFO : CUDA Toolkit for L4T : Unpacking cuda-repo-l4t-10-0-local-10.0.166 (1.0-1) over (1.0-1) …
09:59:48 INFO : CUDA Toolkit for L4T : Setting up cuda-repo-l4t-10-0-local-10.0.166 (1.0-1) …
09:59:53 INFO : CUDA Toolkit for L4T : begin sudo apt-key add /var/cuda-repo--local/*.pub, 5
09:59:53 INFO : CUDA Toolkit for L4T : Warning: apt-key output should not be parsed (stdout is not a terminal)
09:59:53 INFO : CUDA Toolkit for L4T : OK
09:59:55 INFO : CUDA Toolkit for L4T : *begin sudo apt-get -y update, 5
09:59:55 INFO : CUDA Toolkit for L4T : Get:1 file:/var/cuda-repo-10-0-local-10.0.166 InRelease
09:59:55 INFO : CUDA Toolkit for L4T : Ign:1 file:/var/cuda-repo-10-0-local-10.0.166 InRelease
09:59:55 INFO : CUDA Toolkit for L4T : Get:2 file:/var/cuda-repo-10-0-local-10.0.326 InRelease
09:59:55 INFO : CUDA Toolkit for L4T : Ign:2 file:/var/cuda-repo-10-0-local-10.0.326 InRelease
09:59:55 INFO : CUDA Toolkit for L4T : Get:3 file:/var/cuda-repo-10-0-local-10.0.166 Release [574 B]
09:59:55 INFO : CUDA Toolkit for L4T : Get:4 file:/var/cuda-repo-10-0-local-10.0.326 Release [574 B]
10:00:25 INFO : CUDA Toolkit for L4T : Err:7 http://ports.ubuntu.com/ubuntu-ports bionic InRelease
10:00:25 INFO : CUDA Toolkit for L4T : Could not resolve ‘ports.ubuntu.com’
10:00:35 INFO : CUDA Toolkit for L4T : Err:8 http://ports.ubuntu.com/ubuntu-ports bionic-updates InRelease
10:00:35 INFO : CUDA Toolkit for L4T : Could not resolve ‘ports.ubuntu.com’
10:00:45 INFO : CUDA Toolkit for L4T : Err:9 http://ports.ubuntu.com/ubuntu-ports bionic-backports InRelease
10:00:45 INFO : CUDA Toolkit for L4T : Could not resolve ‘ports.ubuntu.com’
10:00:55 INFO : CUDA Toolkit for L4T : Err:10 http://ports.ubuntu.com/ubuntu-ports bionic-security InRelease
10:00:55 INFO : CUDA Toolkit for L4T : Could not resolve ‘ports.ubuntu.com’
10:00:56 INFO : CUDA Toolkit for L4T : Reading package lists…
10:00:56 INFO : CUDA Toolkit for L4T : W: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/dists/bionic/InRelease Could not resolve ‘ports.ubuntu.com’
10:00:56 INFO : CUDA Toolkit for L4T : W: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/dists/bionic-updates/InRelease Could not resolve ‘ports.ubuntu.com’
10:00:56 INFO : CUDA Toolkit for L4T : W: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/dists/bionic-backports/InRelease Could not resolve ‘ports.ubuntu.com’
10:00:56 INFO : CUDA Toolkit for L4T : W: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/dists/bionic-security/InRelease Could not resolve ‘ports.ubuntu.com’
10:00:56 INFO : CUDA Toolkit for L4T : W: Some index files failed to download. They have been ignored, or old ones used instead.
10:00:56 INFO : CUDA Toolkit for L4T : *begin sudo apt-get install -y gnupg, 5
10:00:56 INFO : CUDA Toolkit for L4T : Building dependency tree…
10:00:56 INFO : CUDA Toolkit for L4T : Reading state information…
10:00:56 INFO : CUDA Toolkit for L4T : gnupg is already the newest version (2.2.4-1ubuntu1.2).
10:00:56 INFO : CUDA Toolkit for L4T : The following packages were automatically installed and are no longer required:
10:00:56 INFO : CUDA Toolkit for L4T : apt-clone archdetect-deb busybox-static cryptsetup-bin dpkg-repack
10:00:56 INFO : CUDA Toolkit for L4T : gir1.2-timezonemap-1.0 gir1.2-xkl-1.0 grub-common kde-window-manager kinit
10:00:56 INFO : CUDA Toolkit for L4T : kio kpackagetool5 kwayland-data kwin-common kwin-data kwin-x11
10:00:56 INFO : CUDA Toolkit for L4T : libdebian-installer4 libkdecorations2-5v5 libkdecorations2private5v5
10:00:56 INFO : CUDA Toolkit for L4T : libkf5activities5 libkf5attica5 libkf5completion-data libkf5completion5
10:00:56 INFO : CUDA Toolkit for L4T : libkf5declarative-data libkf5declarative5 libkf5doctools5
10:00:56 INFO : CUDA Toolkit for L4T : libkf5globalaccel-data libkf5globalaccel5 libkf5globalaccelprivate5
10:00:56 INFO : CUDA Toolkit for L4T : libkf5idletime5 libkf5jobwidgets-data libkf5jobwidgets5 libkf5kcmutils-data
10:00:56 INFO : CUDA Toolkit for L4T : libkf5kcmutils5 libkf5kiocore5 libkf5kiontlm5 libkf5kiowidgets5
10:00:56 INFO : CUDA Toolkit for L4T : libkf5newstuff-data libkf5newstuff5 libkf5newstuffcore5 libkf5package-data
10:00:56 INFO : CUDA Toolkit for L4T : libkf5package5 libkf5plasma5 libkf5quickaddons5 libkf5solid5
10:00:56 INFO : CUDA Toolkit for L4T : libkf5solid5-data libkf5sonnet5-data libkf5sonnetcore5 libkf5sonnetui5
10:00:56 INFO : CUDA Toolkit for L4T : libkf5textwidgets-data libkf5textwidgets5 libkf5waylandclient5
10:00:56 INFO : CUDA Toolkit for L4T : libkf5waylandserver5 libkf5xmlgui-bin libkf5xmlgui-data libkf5xmlgui5
10:00:56 INFO : CUDA Toolkit for L4T : libkscreenlocker5 libkwin4-effect-builtins1 libkwineffects11
10:00:56 INFO : CUDA Toolkit for L4T : libkwinglutils11 libkwinxrenderutils11 libqgsttools-p1 libqt5designer5
10:00:56 INFO : CUDA Toolkit for L4T : libqt5help5 libqt5multimedia5 libqt5multimedia5-plugins
10:00:56 INFO : CUDA Toolkit for L4T : libqt5multimediaquick-p5 libqt5multimediawidgets5 libqt5opengl5
10:00:56 INFO : CUDA Toolkit for L4T : libqt5positioning5 libqt5printsupport5 libqt5qml5 libqt5quick5
10:00:56 INFO : CUDA Toolkit for L4T : libqt5quickwidgets5 libqt5sensors5 libqt5sql5 libqt5test5 libqt5webchannel5
10:00:56 INFO : CUDA Toolkit for L4T : libqt5webkit5 libxcb-composite0 libxcb-cursor0 libxcb-damage0 os-prober
10:00:56 INFO : CUDA Toolkit for L4T : python3-dbus.mainloop.pyqt5 python3-icu python3-pam python3-pyqt5
10:00:56 INFO : CUDA Toolkit for L4T : python3-pyqt5.qtsvg python3-pyqt5.qtwebkit python3-sip
10:00:56 INFO : CUDA Toolkit for L4T : qml-module-org-kde-kquickcontrolsaddons qml-module-qtmultimedia
10:00:56 INFO : CUDA Toolkit for L4T : qml-module-qtquick2 rdate
10:00:56 INFO : CUDA Toolkit for L4T : Use ‘sudo apt autoremove’ to remove them.
10:00:57 INFO : CUDA Toolkit for L4T : 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
10:00:57 INFO : CUDA Toolkit for L4T : *begin sudo apt-get -y --allow-downgrades install cuda-toolkit-10-0 libgomp1 libfreeimage-dev libopenmpi-dev openmpi-bin, 5
10:00:57 INFO : CUDA Toolkit for L4T : Reading package lists…
10:00:57 INFO : CUDA Toolkit for L4T : Building dependency tree…
10:00:57 INFO : CUDA Toolkit for L4T : Reading state information…
10:00:57 INFO : CUDA Toolkit for L4T : E: Unable to locate package libfreeimage-dev
10:00:57 INFO : CUDA Toolkit for L4T : E: Unable to locate package libopenmpi-dev
10:00:57 INFO : CUDA Toolkit for L4T : E: Unable to locate package openmpi-bin
10:00:57 INFO : CUDA Toolkit for L4T : Unhandled error when running sudo apt-get -y --allow-downgrades install cuda-toolkit-10-0 libgomp1 libfreeimage-dev libopenmpi-dev openmpi-bin
10:00:57 INFO : CUDA Toolkit for L4T : exit status 1
10:00:57 INFO : CUDA Toolkit for L4T : [ Package Install Finished with Error ]
10:00:57 INFO : CUDA Toolkit for L4T : [ 264.00 KB used. Disk Avail: 49.91 GB ]
10:00:57 INFO : CUDA Toolkit for L4T : [ NV_L4T_CUDA_TARGET_POST_INSTALL_COMP Install took 1m32s ]
10:00:57 ERROR : CUDA Toolkit for L4T : Run commands failed at step Install: command scp -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no /tmp/tmp_NV_L4T_CUDA_TARGET_POST_INSTALL_COMP.sh nvidia@10.42.0.1:~; ssh -t -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no nvidia@10.42.0.1 “~/tmp_NV_L4T_CUDA_TARGET_POST_INSTALL_COMP.sh && rm -f ~/tmp_NV_L4T_CUDA_TARGET_POST_INSTALL_COMP.sh” finished with error
10:00:57 ERROR : CUDA Toolkit for L4T : command terminated with error
