I am using the SDK manager. The flashing was successful. However, the SDK installation now fails. I got a pop-up notification during the installation that said “Activation of network connection failed.” This pops up every once in a while, even after the installation quit.
What should I do? Thanks in advance.
Below is the terminal output. The error messages appear at the 6th from last line and the last line.
10:50:13 INFO : CUDA Toolkit for L4T : while [ ${CMD_STATUS} -ne 0 ]; do
10:50:13 INFO : CUDA Toolkit for L4T : if grep -q -e "is locked by another process" -e "E: Could not get lock /var/lib" $tmp_log; then
10:50:13 INFO : CUDA Toolkit for L4T : sudo rm -f $tmp_log
10:50:13 INFO : CUDA Toolkit for L4T : set +e; $1 2>&1 | tee $tmp_log; CMD_STATUS=${PIPESTATUS[0]}; set -e
10:50:13 INFO : CUDA Toolkit for L4T : echo "Waiting $2 seconds for apt to be available"; sleep ${2}
10:50:13 INFO : CUDA Toolkit for L4T : else
10:50:13 INFO : CUDA Toolkit for L4T : echo "Unhandled error when running $1"; exit 1
10:50:13 INFO : CUDA Toolkit for L4T : fi
10:50:13 INFO : CUDA Toolkit for L4T : done
10:50:13 INFO : CUDA Toolkit for L4T : }
10:50:13 INFO : CUDA Toolkit for L4T : export LC_ALL=en_US.UTF-8 LANG=en_US.UTF-8 LANGUAGE=en_US.UTF-8
10:50:13 INFO : CUDA Toolkit for L4T : function safe_apt_install {
10:50:13 INFO : CUDA Toolkit for L4T : echo "*begin $1, $2"
10:50:13 INFO : CUDA Toolkit for L4T : tmp_log=/tmp/jetpack_dpkg_log.txt
10:50:13 INFO : CUDA Toolkit for L4T : safe_apt_install "sudo dpkg -i /opt/nvidia/deb_repos/cuda-repo-l4t-10-0-local-10.0.166_1.0-1_arm64.deb" 5
10:50:13 INFO : CUDA Toolkit for L4T : sleep 5
10:50:13 INFO : CUDA Toolkit for L4T : safe_apt_install "sudo apt-key add /var/cuda-repo-*-local*/*.pub" 5
10:50:13 INFO : CUDA Toolkit for L4T : sleep 2
10:50:13 INFO : CUDA Toolkit for L4T : safe_apt_install "sudo apt-get -y update" 5
10:50:13 INFO : CUDA Toolkit for L4T : safe_apt_install "sudo apt-get install -y gnupg" 5
10:50:13 INFO : CUDA Toolkit for L4T : safe_apt_install "sudo apt-get -y --allow-downgrades install cuda-toolkit-10-0 libgomp1 libfreeimage-dev libopenmpi-dev openmpi-bin" 5
10:50:13 INFO : CUDA Toolkit for L4T : grep -q 'export PATH=.*/usr/local/cuda-10.0/bin' ~/.bashrc || echo 'export PATH=/usr/local/cuda-10.0/bin:$PATH'>>~/.bashrc
10:50:13 INFO : CUDA Toolkit for L4T : grep -q 'export LD_LIBRARY_PATH=/usr/local/cuda-10.0/lib64' ~/.bashrc || echo 'export LD_LIBRARY_PATH=/usr/local/cuda-10.0/lib64:$LD_LIBRARY_PATH' >> ~/.bashrc
10:50:13 INFO : CUDA Toolkit for L4T : sudo rm -f /opt/nvidia/deb_repos/cuda-repo-l4t-10-0-local-10.0.166_1.0-1_arm64.deb
10:50:13 INFO : CUDA Toolkit for L4T : **********************
10:50:13 INFO : CUDA Toolkit for L4T : exec_command: scp -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no /tmp/tmp_NV_L4T_CUDA_TARGET_POST_INSTALL_COMP.sh farsightuser@192.168.55.1:~; ssh -t -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no farsightuser@192.168.55.1 "~/tmp_NV_L4T_CUDA_TARGET_POST_INSTALL_COMP.sh && rm -f ~/tmp_NV_L4T_CUDA_TARGET_POST_INSTALL_COMP.sh"
10:50:13 INFO : CUDA Toolkit for L4T : [target] farsightuser@192.168.55.1's password:
10:50:14 INFO : CUDA Toolkit for L4T : *begin sudo dpkg -i /opt/nvidia/deb_repos/cuda-repo-l4t-10-0-local-10.0.166_1.0-1_arm64.deb, 5
10:50:14 INFO : CUDA Toolkit for L4T : [target] [sudo] password for farsightuser:
10:50:14 INFO : CUDA Toolkit for L4T : Selecting previously unselected package cuda-repo-l4t-10-0-local-10.0.166.
10:50:14 INFO : CUDA Toolkit for L4T : (Reading database ... 117136 files and directories currently installed.)
10:50:14 INFO : CUDA Toolkit for L4T : Preparing to unpack .../cuda-repo-l4t-10-0-local-10.0.166_1.0-1_arm64.deb ...
10:50:14 INFO : CUDA Toolkit for L4T : Unpacking cuda-repo-l4t-10-0-local-10.0.166 (1.0-1) ...
10:50:21 INFO : CUDA Toolkit for L4T : Setting up cuda-repo-l4t-10-0-local-10.0.166 (1.0-1) ...
10:50:21 INFO : CUDA Toolkit for L4T : The public CUDA GPG key does not appear to be installed.
10:50:21 INFO : CUDA Toolkit for L4T : To install the key, run this command:
10:50:21 INFO : CUDA Toolkit for L4T : sudo apt-key add /var/cuda-repo-10-0-local-10.0.166/7fa2af80.pub
10:50:26 INFO : CUDA Toolkit for L4T : *begin sudo apt-key add /var/cuda-repo-*-local*/*.pub, 5
10:50:26 INFO : CUDA Toolkit for L4T : Warning: apt-key output should not be parsed (stdout is not a terminal)
10:50:26 INFO : CUDA Toolkit for L4T : OK
10:50:28 INFO : CUDA Toolkit for L4T : *begin sudo apt-get -y update, 5
10:50:29 INFO : CUDA Toolkit for L4T : Reading package lists...
10:50:29 INFO : CUDA Toolkit for L4T : E: Could not get lock /var/lib/apt/lists/lock - open (11: Resource temporarily unavailable)
10:50:29 INFO : CUDA Toolkit for L4T : E: Unable to lock directory /var/lib/apt/lists/
10:50:29 INFO : CUDA Toolkit for L4T : Waiting 5 seconds for apt to be available
10:50:34 INFO : CUDA Toolkit for L4T : Get:1 file:/var/cuda-repo-10-0-local-10.0.166 InRelease
10:50:34 INFO : CUDA Toolkit for L4T : Ign:1 file:/var/cuda-repo-10-0-local-10.0.166 InRelease
10:50:34 INFO : CUDA Toolkit for L4T : Get:2 file:/var/cuda-repo-10-0-local-10.0.166 Release [574 B]
10:50:34 INFO : CUDA Toolkit for L4T : Get:3 file:/var/cuda-repo-10-0-local-10.0.166 Release.gpg [819 B]
10:50:34 INFO : CUDA Toolkit for L4T : Get:4 file:/var/cuda-repo-10-0-local-10.0.166 Packages [10.9 kB]
10:51:00 INFO : CUDA Toolkit for L4T : Err:5 http://ports.ubuntu.com/ubuntu-ports bionic InRelease
10:51:00 INFO : CUDA Toolkit for L4T : Could not resolve 'ports.ubuntu.com'
10:51:05 INFO : CUDA Toolkit for L4T : Err:6 http://ports.ubuntu.com/ubuntu-ports bionic-updates InRelease
10:51:05 INFO : CUDA Toolkit for L4T : Could not resolve 'ports.ubuntu.com'
10:51:15 INFO : CUDA Toolkit for L4T : Err:7 http://ports.ubuntu.com/ubuntu-ports bionic-backports InRelease
10:51:15 INFO : CUDA Toolkit for L4T : Could not resolve 'ports.ubuntu.com'
10:51:25 INFO : CUDA Toolkit for L4T : Err:8 http://ports.ubuntu.com/ubuntu-ports bionic-security InRelease
10:51:25 INFO : CUDA Toolkit for L4T : Could not resolve 'ports.ubuntu.com'
10:51:26 INFO : CUDA Toolkit for L4T : Reading package lists...
10:51:26 INFO : CUDA Toolkit for L4T : W: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/dists/bionic/InRelease Could not resolve 'ports.ubuntu.com'
10:51:26 INFO : CUDA Toolkit for L4T : W: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/dists/bionic-updates/InRelease Could not resolve 'ports.ubuntu.com'
10:51:26 INFO : CUDA Toolkit for L4T : W: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/dists/bionic-backports/InRelease Could not resolve 'ports.ubuntu.com'
10:51:26 INFO : CUDA Toolkit for L4T : W: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/dists/bionic-security/InRelease Could not resolve 'ports.ubuntu.com'
10:51:26 INFO : CUDA Toolkit for L4T : W: Some index files failed to download. They have been ignored, or old ones used instead.
10:51:26 INFO : CUDA Toolkit for L4T : Waiting 5 seconds for apt to be available
10:51:31 INFO : CUDA Toolkit for L4T : *begin sudo apt-get install -y gnupg, 5
10:51:31 INFO : CUDA Toolkit for L4T : Reading package lists...
10:51:31 INFO : CUDA Toolkit for L4T : Building dependency tree...
10:51:31 INFO : CUDA Toolkit for L4T : Reading state information...
10:51:31 INFO : CUDA Toolkit for L4T : gnupg is already the newest version (2.2.4-1ubuntu1.2).
10:51:31 INFO : CUDA Toolkit for L4T : gnupg set to manually installed.
10:51:31 INFO : CUDA Toolkit for L4T : The following packages were automatically installed and are no longer required:
10:51:31 INFO : CUDA Toolkit for L4T : apt-clone archdetect-deb busybox-static cryptsetup-bin dpkg-repack
10:51:31 INFO : CUDA Toolkit for L4T : gir1.2-timezonemap-1.0 gir1.2-xkl-1.0 grub-common kde-window-manager kinit
10:51:31 INFO : CUDA Toolkit for L4T : kio kpackagetool5 kwayland-data kwin-common kwin-data kwin-x11
10:51:31 INFO : CUDA Toolkit for L4T : libdebian-installer4 libkdecorations2-5v5 libkdecorations2private5v5
10:51:31 INFO : CUDA Toolkit for L4T : libkf5activities5 libkf5attica5 libkf5completion-data libkf5completion5
10:51:31 INFO : CUDA Toolkit for L4T : libkf5declarative-data libkf5declarative5 libkf5doctools5
10:51:31 INFO : CUDA Toolkit for L4T : libkf5globalaccel-data libkf5globalaccel5 libkf5globalaccelprivate5
10:51:31 INFO : CUDA Toolkit for L4T : libkf5idletime5 libkf5jobwidgets-data libkf5jobwidgets5 libkf5kcmutils-data
10:51:31 INFO : CUDA Toolkit for L4T : libkf5kcmutils5 libkf5kiocore5 libkf5kiontlm5 libkf5kiowidgets5
10:51:31 INFO : CUDA Toolkit for L4T : libkf5newstuff-data libkf5newstuff5 libkf5newstuffcore5 libkf5package-data
10:51:31 INFO : CUDA Toolkit for L4T : libkf5package5 libkf5plasma5 libkf5quickaddons5 libkf5solid5
10:51:31 INFO : CUDA Toolkit for L4T : libkf5solid5-data libkf5sonnet5-data libkf5sonnetcore5 libkf5sonnetui5
10:51:31 INFO : CUDA Toolkit for L4T : libkf5textwidgets-data libkf5textwidgets5 libkf5waylandclient5
10:51:31 INFO : CUDA Toolkit for L4T : libkf5waylandserver5 libkf5xmlgui-bin libkf5xmlgui-data libkf5xmlgui5
10:51:31 INFO : CUDA Toolkit for L4T : libkscreenlocker5 libkwin4-effect-builtins1 libkwineffects11
10:51:31 INFO : CUDA Toolkit for L4T : libkwinglutils11 libkwinxrenderutils11 libqgsttools-p1 libqt5designer5
10:51:31 INFO : CUDA Toolkit for L4T : libqt5help5 libqt5multimedia5 libqt5multimedia5-plugins
10:51:31 INFO : CUDA Toolkit for L4T : libqt5multimediaquick-p5 libqt5multimediawidgets5 libqt5opengl5
10:51:31 INFO : CUDA Toolkit for L4T : libqt5positioning5 libqt5printsupport5 libqt5qml5 libqt5quick5
10:51:31 INFO : CUDA Toolkit for L4T : libqt5quickwidgets5 libqt5sensors5 libqt5sql5 libqt5test5 libqt5webchannel5
10:51:31 INFO : CUDA Toolkit for L4T : libqt5webkit5 libxcb-composite0 libxcb-cursor0 libxcb-damage0 os-prober
10:51:31 INFO : CUDA Toolkit for L4T : python3-dbus.mainloop.pyqt5 python3-icu python3-pam python3-pyqt5
10:51:31 INFO : CUDA Toolkit for L4T : python3-pyqt5.qtsvg python3-pyqt5.qtwebkit python3-sip
10:51:31 INFO : CUDA Toolkit for L4T : qml-module-org-kde-kquickcontrolsaddons qml-module-qtmultimedia
10:51:31 INFO : CUDA Toolkit for L4T : qml-module-qtquick2 rdate
10:51:31 INFO : CUDA Toolkit for L4T : Use 'sudo apt autoremove' to remove them.
10:51:32 INFO : CUDA Toolkit for L4T : 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
10:51:32 INFO : CUDA Toolkit for L4T : *begin sudo apt-get -y --allow-downgrades install cuda-toolkit-10-0 libgomp1 libfreeimage-dev libopenmpi-dev openmpi-bin, 5
10:51:32 INFO : CUDA Toolkit for L4T : Reading package lists...
10:51:32 INFO : CUDA Toolkit for L4T : Building dependency tree...
10:51:32 INFO : CUDA Toolkit for L4T : Reading state information...
10:51:32 INFO : CUDA Toolkit for L4T : E: Unable to locate package libfreeimage-dev
10:51:32 INFO : CUDA Toolkit for L4T : E: Unable to locate package libopenmpi-dev
10:51:32 INFO : CUDA Toolkit for L4T : E: Unable to locate package openmpi-bin
10:51:32 INFO : CUDA Toolkit for L4T : Unhandled error when running sudo apt-get -y --allow-downgrades install cuda-toolkit-10-0 libgomp1 libfreeimage-dev libopenmpi-dev openmpi-bin
10:51:32 INFO : CUDA Toolkit for L4T : exit status 1
10:51:32 INFO : CUDA Toolkit for L4T : [ Package Install Finished with Error ]
10:51:32 ERROR : CUDA Toolkit for L4T : NV_L4T_CUDA_TARGET_POST_INSTALL_COMP command scp -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no /tmp/tmp_NV_L4T_CUDA_TARGET_POST_INSTALL_COMP.sh farsightuser@192.168.55.1:~; ssh -t -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no farsightuser@192.168.55.1 "~/tmp_NV_L4T_CUDA_TARGET_POST_INSTALL_COMP.sh && rm -f ~/tmp_NV_L4T_CUDA_TARGET_POST_INSTALL_COMP.sh" finished with error
10:51:32 INFO : CUDA Toolkit for L4T : [ 52.00 KB used. Disk Avail: 341.34 GB ]
10:51:32 INFO : CUDA Toolkit for L4T : [ NV_L4T_CUDA_TARGET_POST_INSTALL_COMP Install took 1m57s ]
10:51:32 INFO : CUDA Toolkit for L4T : command scp -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no /tmp/tmp_NV_L4T_CUDA_TARGET_POST_INSTALL_COMP.sh farsightuser@192.168.55.1:~; ssh -t -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no farsightuser@192.168.55.1 "~/tmp_NV_L4T_CUDA_TARGET_POST_INSTALL_COMP.sh && rm -f ~/tmp_NV_L4T_CUDA_TARGET_POST_INSTALL_COMP.sh" finished with error
10:51:32 ERROR : CUDA Toolkit for L4T : command terminated with error
10:51:53 INFO : CUDA Toolkit for L4T : Found file /home/rishabh/Downloads/cuda-repo-l4t-10-0-local-10.0.166_1.0-1_arm64.deb with correct checksum, skip downloading.
11:10:36 DEBUG : CUDA Toolkit for L4T : running command < cd '/home/rishabh/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3310' ; '/opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter' -a='install' -c='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' -i='NV_L4T_CUDA_TARGET_POST_INSTALL_COMP' -v='10.0' -l='/home/rishabh/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3310' -L='/home/rishabh/.nvsdkm/logs/JetPack_4.2_Linux' -p='9343' -t='P3310' -e='/home/rishabh/Downloads/cuda-repo-l4t-10-0-local-10.0.166_1.0-1_arm64.deb' >
11:10:36 INFO : CUDA Toolkit for L4T : [ Disk Avail:341.34 GB ]
11:10:36 INFO : CUDA Toolkit for L4T : Using GenericInstaller to Install NV_L4T_CUDA_TARGET_POST_INSTALL_COMP
11:10:36 INFO : CUDA Toolkit for L4T : NV_L4T_CUDA_TARGET_POST_INSTALL_COMP include 1 package
11:10:36 INFO : CUDA Toolkit for L4T : [ Package Install Started ]
11:10:36 INFO : CUDA Toolkit for L4T : current working directory is /home/rishabh/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3310
11:10:36 INFO : CUDA Toolkit for L4T : exec_command [target]:
11:10:36 INFO : CUDA Toolkit for L4T : **********************
11:10:36 INFO : CUDA Toolkit for L4T : #!/bin/bash
11:10:36 INFO : CUDA Toolkit for L4T : set -e
11:10:36 INFO : CUDA Toolkit for L4T : function safe_apt_install {
11:10:36 INFO : CUDA Toolkit for L4T : echo "*begin $1, $2"
11:10:36 INFO : CUDA Toolkit for L4T : tmp_log=/tmp/jetpack_dpkg_log.txt
11:10:36 INFO : CUDA Toolkit for L4T : sudo rm -f $tmp_log
11:10:36 INFO : CUDA Toolkit for L4T : set +e; $1 2>&1 | tee $tmp_log; CMD_STATUS=${PIPESTATUS[0]}; set -e
11:10:36 INFO : CUDA Toolkit for L4T : while [ ${CMD_STATUS} -ne 0 ]; do
11:10:36 INFO : CUDA Toolkit for L4T : if grep -q -e "is locked by another process" -e "E: Could not get lock /var/lib" $tmp_log; then
11:10:36 INFO : CUDA Toolkit for L4T : echo "Waiting $2 seconds for apt to be available"; sleep ${2}
11:10:36 INFO : CUDA Toolkit for L4T : else
11:10:36 INFO : CUDA Toolkit for L4T : echo "Unhandled error when running $1"; exit 1
11:10:36 INFO : CUDA Toolkit for L4T : fi
11:10:36 INFO : CUDA Toolkit for L4T : done
11:10:36 INFO : CUDA Toolkit for L4T : }
11:10:36 INFO : CUDA Toolkit for L4T : export LC_ALL=en_US.UTF-8 LANG=en_US.UTF-8 LANGUAGE=en_US.UTF-8
11:10:36 INFO : CUDA Toolkit for L4T : sudo mkdir -p /opt/nvidia/deb_repos
11:10:36 INFO : CUDA Toolkit for L4T : sudo chmod 777 /opt/nvidia/deb_repos
11:10:36 INFO : CUDA Toolkit for L4T : sudo rm -f /opt/nvidia/deb_repos/cuda-repo-l4t-10-0-local-10.0.166_1.0-1_arm64.deb
11:10:36 INFO : CUDA Toolkit for L4T : exec_command: scp -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no /tmp/tmp_NV_L4T_CUDA_TARGET_POST_INSTALL_COMP.sh farsight@192.168.55.1:~; ssh -t -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no farsight@192.168.55.1 "~/tmp_NV_L4T_CUDA_TARGET_POST_INSTALL_COMP.sh && rm -f ~/tmp_NV_L4T_CUDA_TARGET_POST_INSTALL_COMP.sh"
11:10:37 INFO : CUDA Toolkit for L4T : [target] farsight@192.168.55.1's password:
11:10:38 INFO : CUDA Toolkit for L4T : [target] farsight@192.168.55.1's password:
11:10:38 INFO : CUDA Toolkit for L4T : [target] [sudo] password for farsight:
11:10:38 INFO : CUDA Toolkit for L4T : exec_command: scp -F /dev/null -o PubkeyAuthentication=no -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no -o ConnectTimeout=5 -r /home/rishabh/Downloads/cuda-repo-l4t-10-0-local-10.0.166_1.0-1_arm64.deb farsight@192.168.55.1:/opt/nvidia/deb_repos/
11:10:38 WARNING : CUDA Toolkit for L4T : Warning: Permanently added '192.168.55.1' (ECDSA) to the list of known hosts.
11:11:23 INFO : CUDA Toolkit for L4T : exec_command [target]:
11:11:23 INFO : CUDA Toolkit for L4T : **********************
11:11:23 INFO : CUDA Toolkit for L4T : #!/bin/bash
11:11:23 INFO : CUDA Toolkit for L4T : set -e
11:11:23 INFO : CUDA Toolkit for L4T : function safe_apt_install {
11:11:23 INFO : CUDA Toolkit for L4T : echo "*begin $1, $2"
11:11:23 INFO : CUDA Toolkit for L4T : tmp_log=/tmp/jetpack_dpkg_log.txt
11:11:23 INFO : CUDA Toolkit for L4T : sudo rm -f $tmp_log
11:11:23 INFO : CUDA Toolkit for L4T : set +e; $1 2>&1 | tee $tmp_log; CMD_STATUS=${PIPESTATUS[0]}; set -e
11:11:23 INFO : CUDA Toolkit for L4T : while [ ${CMD_STATUS} -ne 0 ]; do
11:11:23 INFO : CUDA Toolkit for L4T : if grep -q -e "is locked by another process" -e "E: Could not get lock /var/lib" $tmp_log; then
11:11:23 INFO : CUDA Toolkit for L4T : echo "Waiting $2 seconds for apt to be available"; sleep ${2}
11:11:23 INFO : CUDA Toolkit for L4T : else
11:11:23 INFO : CUDA Toolkit for L4T : echo "Unhandled error when running $1"; exit 1
11:11:23 INFO : CUDA Toolkit for L4T : fi
11:11:23 INFO : CUDA Toolkit for L4T : done
11:11:23 INFO : CUDA Toolkit for L4T : }
11:11:23 INFO : CUDA Toolkit for L4T : export LC_ALL=en_US.UTF-8 LANG=en_US.UTF-8 LANGUAGE=en_US.UTF-8
11:11:23 INFO : CUDA Toolkit for L4T : safe_apt_install "sudo dpkg -i /opt/nvidia/deb_repos/cuda-repo-l4t-10-0-local-10.0.166_1.0-1_arm64.deb" 5
11:11:23 INFO : CUDA Toolkit for L4T : sleep 5
11:11:23 INFO : CUDA Toolkit for L4T : safe_apt_install "sudo apt-key add /var/cuda-repo-*-local*/*.pub" 5
11:11:23 INFO : CUDA Toolkit for L4T : sleep 2
11:11:23 INFO : CUDA Toolkit for L4T : safe_apt_install "sudo apt-get -y update" 5
11:11:23 INFO : CUDA Toolkit for L4T : safe_apt_install "sudo apt-get install -y gnupg" 5
11:11:23 INFO : CUDA Toolkit for L4T : safe_apt_install "sudo apt-get -y --allow-downgrades install cuda-toolkit-10-0 libgomp1 libfreeimage-dev libopenmpi-dev openmpi-bin" 5
11:11:23 INFO : CUDA Toolkit for L4T : grep -q 'export PATH=.*/usr/local/cuda-10.0/bin' ~/.bashrc || echo 'export PATH=/usr/local/cuda-10.0/bin:$PATH'>>~/.bashrc
11:11:23 INFO : CUDA Toolkit for L4T : grep -q 'export LD_LIBRARY_PATH=/usr/local/cuda-10.0/lib64' ~/.bashrc || echo 'export LD_LIBRARY_PATH=/usr/local/cuda-10.0/lib64:$LD_LIBRARY_PATH' >> ~/.bashrc
11:11:23 INFO : CUDA Toolkit for L4T : sudo rm -f /opt/nvidia/deb_repos/cuda-repo-l4t-10-0-local-10.0.166_1.0-1_arm64.deb
11:11:23 INFO : CUDA Toolkit for L4T : exec_command: scp -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no /tmp/tmp_NV_L4T_CUDA_TARGET_POST_INSTALL_COMP.sh farsight@192.168.55.1:~; ssh -t -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no farsight@192.168.55.1 "~/tmp_NV_L4T_CUDA_TARGET_POST_INSTALL_COMP.sh && rm -f ~/tmp_NV_L4T_CUDA_TARGET_POST_INSTALL_COMP.sh"
11:11:23 INFO : CUDA Toolkit for L4T : [target] farsight@192.168.55.1's password:
11:11:24 INFO : CUDA Toolkit for L4T : *begin sudo dpkg -i /opt/nvidia/deb_repos/cuda-repo-l4t-10-0-local-10.0.166_1.0-1_arm64.deb, 5
11:11:24 INFO : CUDA Toolkit for L4T : [target] [sudo] password for farsight:
11:11:24 INFO : CUDA Toolkit for L4T : Selecting previously unselected package cuda-repo-l4t-10-0-local-10.0.166.
11:11:24 INFO : CUDA Toolkit for L4T : (Reading database ... 117136 files and directories currently installed.)
11:11:24 INFO : CUDA Toolkit for L4T : Preparing to unpack .../cuda-repo-l4t-10-0-local-10.0.166_1.0-1_arm64.deb ...
11:11:24 INFO : CUDA Toolkit for L4T : Unpacking cuda-repo-l4t-10-0-local-10.0.166 (1.0-1) ...
11:11:31 INFO : CUDA Toolkit for L4T : Setting up cuda-repo-l4t-10-0-local-10.0.166 (1.0-1) ...
11:11:31 INFO : CUDA Toolkit for L4T : The public CUDA GPG key does not appear to be installed.
11:11:31 INFO : CUDA Toolkit for L4T : To install the key, run this command:
11:11:31 INFO : CUDA Toolkit for L4T : sudo apt-key add /var/cuda-repo-10-0-local-10.0.166/7fa2af80.pub
11:11:36 INFO : CUDA Toolkit for L4T : *begin sudo apt-key add /var/cuda-repo-*-local*/*.pub, 5
11:11:36 INFO : CUDA Toolkit for L4T : Warning: apt-key output should not be parsed (stdout is not a terminal)
11:11:36 INFO : CUDA Toolkit for L4T : OK
11:11:38 INFO : CUDA Toolkit for L4T : *begin sudo apt-get -y update, 5
11:11:39 INFO : CUDA Toolkit for L4T : Get:1 file:/var/cuda-repo-10-0-local-10.0.166 InRelease
11:11:39 INFO : CUDA Toolkit for L4T : Ign:1 file:/var/cuda-repo-10-0-local-10.0.166 InRelease
11:11:39 INFO : CUDA Toolkit for L4T : Get:2 file:/var/cuda-repo-10-0-local-10.0.166 Release [574 B]
11:11:39 INFO : CUDA Toolkit for L4T : Get:3 file:/var/cuda-repo-10-0-local-10.0.166 Release.gpg [819 B]
11:11:39 INFO : CUDA Toolkit for L4T : Get:4 file:/var/cuda-repo-10-0-local-10.0.166 Packages [10.9 kB]
11:12:09 INFO : CUDA Toolkit for L4T : Err:5 http://ports.ubuntu.com/ubuntu-ports bionic InRelease
11:12:09 INFO : CUDA Toolkit for L4T : Could not resolve 'ports.ubuntu.com'
11:12:19 INFO : CUDA Toolkit for L4T : Err:6 http://ports.ubuntu.com/ubuntu-ports bionic-updates InRelease
11:12:19 INFO : CUDA Toolkit for L4T : Could not resolve 'ports.ubuntu.com'
11:12:29 INFO : CUDA Toolkit for L4T : Err:7 http://ports.ubuntu.com/ubuntu-ports bionic-backports InRelease
11:12:29 INFO : CUDA Toolkit for L4T : Could not resolve 'ports.ubuntu.com'
11:12:39 INFO : CUDA Toolkit for L4T : Err:8 http://ports.ubuntu.com/ubuntu-ports bionic-security InRelease
11:12:39 INFO : CUDA Toolkit for L4T : Could not resolve 'ports.ubuntu.com'
11:12:40 INFO : CUDA Toolkit for L4T : Reading package lists...
11:12:40 INFO : CUDA Toolkit for L4T : W: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/dists/bionic/InRelease Could not resolve 'ports.ubuntu.com'
11:12:40 INFO : CUDA Toolkit for L4T : W: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/dists/bionic-updates/InRelease Could not resolve 'ports.ubuntu.com'
11:12:40 INFO : CUDA Toolkit for L4T : W: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/dists/bionic-backports/InRelease Could not resolve 'ports.ubuntu.com'
11:12:40 INFO : CUDA Toolkit for L4T : W: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/dists/bionic-security/InRelease Could not resolve 'ports.ubuntu.com'
11:12:40 INFO : CUDA Toolkit for L4T : W: Some index files failed to download. They have been ignored, or old ones used instead.
11:12:40 INFO : CUDA Toolkit for L4T : *begin sudo apt-get install -y gnupg, 5
11:12:40 INFO : CUDA Toolkit for L4T : Building dependency tree...
11:12:40 INFO : CUDA Toolkit for L4T : Reading state information...
11:12:40 INFO : CUDA Toolkit for L4T : gnupg is already the newest version (2.2.4-1ubuntu1.2).
11:12:40 INFO : CUDA Toolkit for L4T : gnupg set to manually installed.
11:12:40 INFO : CUDA Toolkit for L4T : The following packages were automatically installed and are no longer required:
11:12:40 INFO : CUDA Toolkit for L4T : apt-clone archdetect-deb busybox-static cryptsetup-bin dpkg-repack
11:12:40 INFO : CUDA Toolkit for L4T : gir1.2-timezonemap-1.0 gir1.2-xkl-1.0 grub-common kde-window-manager kinit
11:12:40 INFO : CUDA Toolkit for L4T : kio kpackagetool5 kwayland-data kwin-common kwin-data kwin-x11
11:12:40 INFO : CUDA Toolkit for L4T : libdebian-installer4 libkdecorations2-5v5 libkdecorations2private5v5
11:12:40 INFO : CUDA Toolkit for L4T : libkf5activities5 libkf5attica5 libkf5completion-data libkf5completion5
11:12:40 INFO : CUDA Toolkit for L4T : libkf5declarative-data libkf5declarative5 libkf5doctools5
11:12:40 INFO : CUDA Toolkit for L4T : libkf5globalaccel-data libkf5globalaccel5 libkf5globalaccelprivate5
11:12:40 INFO : CUDA Toolkit for L4T : libkf5idletime5 libkf5jobwidgets-data libkf5jobwidgets5 libkf5kcmutils-data
11:12:40 INFO : CUDA Toolkit for L4T : libkf5kcmutils5 libkf5kiocore5 libkf5kiontlm5 libkf5kiowidgets5
11:12:40 INFO : CUDA Toolkit for L4T : libkf5newstuff-data libkf5newstuff5 libkf5newstuffcore5 libkf5package-data
11:12:40 INFO : CUDA Toolkit for L4T : libkf5package5 libkf5plasma5 libkf5quickaddons5 libkf5solid5
11:12:40 INFO : CUDA Toolkit for L4T : libkf5solid5-data libkf5sonnet5-data libkf5sonnetcore5 libkf5sonnetui5
11:12:40 INFO : CUDA Toolkit for L4T : libkf5textwidgets-data libkf5textwidgets5 libkf5waylandclient5
11:12:40 INFO : CUDA Toolkit for L4T : libkf5waylandserver5 libkf5xmlgui-bin libkf5xmlgui-data libkf5xmlgui5
11:12:40 INFO : CUDA Toolkit for L4T : libkscreenlocker5 libkwin4-effect-builtins1 libkwineffects11
11:12:40 INFO : CUDA Toolkit for L4T : libkwinglutils11 libkwinxrenderutils11 libqgsttools-p1 libqt5designer5
11:12:40 INFO : CUDA Toolkit for L4T : libqt5help5 libqt5multimedia5 libqt5multimedia5-plugins
11:12:40 INFO : CUDA Toolkit for L4T : libqt5multimediaquick-p5 libqt5multimediawidgets5 libqt5opengl5
11:12:40 INFO : CUDA Toolkit for L4T : libqt5positioning5 libqt5printsupport5 libqt5qml5 libqt5quick5
11:12:40 INFO : CUDA Toolkit for L4T : libqt5quickwidgets5 libqt5sensors5 libqt5sql5 libqt5test5 libqt5webchannel5
11:12:40 INFO : CUDA Toolkit for L4T : libqt5webkit5 libxcb-composite0 libxcb-cursor0 libxcb-damage0 os-prober
11:12:40 INFO : CUDA Toolkit for L4T : python3-dbus.mainloop.pyqt5 python3-icu python3-pam python3-pyqt5
11:12:40 INFO : CUDA Toolkit for L4T : python3-pyqt5.qtsvg python3-pyqt5.qtwebkit python3-sip
11:12:40 INFO : CUDA Toolkit for L4T : qml-module-org-kde-kquickcontrolsaddons qml-module-qtmultimedia
11:12:40 INFO : CUDA Toolkit for L4T : qml-module-qtquick2 rdate
11:12:40 INFO : CUDA Toolkit for L4T : Use 'sudo apt autoremove' to remove them.
11:12:40 INFO : CUDA Toolkit for L4T : 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
11:12:40 INFO : CUDA Toolkit for L4T : *begin sudo apt-get -y --allow-downgrades install cuda-toolkit-10-0 libgomp1 libfreeimage-dev libopenmpi-dev openmpi-bin, 5
11:12:40 INFO : CUDA Toolkit for L4T : E: Unable to locate package libfreeimage-dev
11:12:40 INFO : CUDA Toolkit for L4T : E: Unable to locate package libopenmpi-dev
11:12:40 INFO : CUDA Toolkit for L4T : E: Unable to locate package openmpi-bin
11:12:40 INFO : CUDA Toolkit for L4T : Unhandled error when running sudo apt-get -y --allow-downgrades install cuda-toolkit-10-0 libgomp1 libfreeimage-dev libopenmpi-dev openmpi-bin
11:12:40 INFO : CUDA Toolkit for L4T : exit status 1
11:12:40 INFO : CUDA Toolkit for L4T : [ Package Install Finished with Error ]
11:12:40 ERROR : CUDA Toolkit for L4T : NV_L4T_CUDA_TARGET_POST_INSTALL_COMP command scp -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no /tmp/tmp_NV_L4T_CUDA_TARGET_POST_INSTALL_COMP.sh farsight@192.168.55.1:~; ssh -t -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no farsight@192.168.55.1 "~/tmp_NV_L4T_CUDA_TARGET_POST_INSTALL_COMP.sh && rm -f ~/tmp_NV_L4T_CUDA_TARGET_POST_INSTALL_COMP.sh" finished with error
11:12:40 INFO : CUDA Toolkit for L4T : [ 60.00 KB used. Disk Avail: 341.34 GB ]
11:12:40 INFO : CUDA Toolkit for L4T : [ NV_L4T_CUDA_TARGET_POST_INSTALL_COMP Install took 2m4s ]
11:12:40 INFO : CUDA Toolkit for L4T : command scp -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no /tmp/tmp_NV_L4T_CUDA_TARGET_POST_INSTALL_COMP.sh farsight@192.168.55.1:~; ssh -t -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no farsight@192.168.55.1 "~/tmp_NV_L4T_CUDA_TARGET_POST_INSTALL_COMP.sh && rm -f ~/tmp_NV_L4T_CUDA_TARGET_POST_INSTALL_COMP.sh" finished with error
11:12:40 ERROR : CUDA Toolkit for L4T : command terminated with error
