Hello
I’m trying to install Jetson SDK Components on AGX Xavier with SDK Manager, the installation failed and the terminal of SDK Manager shows below:
12:44:11 SUMMARY: Flash Jetson AGX Xavier 16GB/32GB: Install completed successfully.
12:47:42 INFO: Start to check if only one device connected…
12:47:42 DEBUG: running command < true >
12:47:43 INFO: change working directory to /tmp
12:47:43 INFO: exec_command: ssh -F /dev/null -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no hirosawa@192.168.55.1 “dpkg-query -W -f=‘${db:Status-abbrev} ${Version}’ cuda-toolkit-10-2”
12:47:43 INFO: [target] hirosawa@192.168.55.1’s password:
12:47:44 INFO: Target Deb package [{cuda-toolkit-10-2 10.2}] not installed; [deb_name]: cuda-repo-l4t-10-2-local-10.2.89_1.0-1_arm64.deb
12:47:44 ERROR: command terminated with error
12:47:44 DEBUG: running command < true >
12:47:44 INFO: command finished successfully
12:47:44 DEBUG: using adapter to query target component: NV_L4T_CUDNN_TARGET_POST_INSTALL_COMP version: 8.0 for bundle:
12:47:44 INFO: change working directory to /tmp
12:47:44 INFO: exec_command: ssh -F /dev/null -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no hirosawa@192.168.55.1 “dpkg-query -W -f=‘${db:Status-abbrev} ${Version}’ libcudnn8”
12:47:44 INFO: [target] hirosawa@192.168.55.1’s password:
12:47:45 INFO: Target Deb package [{libcudnn8 8.0.0.180-1+cuda10.2}] not installed; [deb_name]: libcudnn8_8.0.0.180-1+cuda10.2_arm64.deb
12:47:45 ERROR: command terminated with error
It seems that ssh or scp failed to copy components to Jetson from Host computer.
I believe that the network works file because I’ve done following on my Host computer:
sudo -s
ssh <account_name>@192.168.55.1
ls -l # works
How to solve this problem?
I attached the log:
SDKM_logs_JetPack_4.4.1_Linux_for_Jetson_AGX_Xavier_2020-11-12_12-38-49.zip (160.3 KB)
Hi makoto,
The scp command is successful. The CUDA installation file is copied to /opt/nvidia/deb_repos/cuda-repo-l4t-10-2-local-10.2.89_1.0-1_arm64.deb on jetson device. However, the “sudo apt-get update” command has problem.
12:48:57.913 - info: NV_L4T_CUDA_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER: W: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/dists/bionic/InRelease Could not resolve ‘ports.ubuntu.com’
12:48:57.914 - info: NV_L4T_CUDA_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER: W: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/dists/bionic-updates/InRelease Could not resolve ‘ports.ubuntu.com’
12:48:57.914 - info: NV_L4T_CUDA_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER: W: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/dists/bionic-backports/InRelease Could not resolve ‘ports.ubuntu.com’
12:48:57.914 - info: NV_L4T_CUDA_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER: W: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/dists/bionic-security/InRelease Could not resolve ‘ports.ubuntu.com’
12:48:57.914 - info: NV_L4T_CUDA_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER: W: Failed to fetch https://repo.download.nvidia.com/jetson/common/dists/r32.4/InRelease Could not resolve ‘repo.download.nvidia.com’
12:48:57.914 - info: NV_L4T_CUDA_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER: W: Failed to fetch https://repo.download.nvidia.com/jetson/t194/dists/r32.4/InRelease Could not resolve ‘repo.download.nvidia.com’
It seems that there is DNS issue on the Jetson device.
Hi EdwardZhou-san, thanks for your reply.
My host computer of Jetson is connected to my company’s LAN which is configured to use proxy authentication.
So I tried following steps and found installation was a success.
- wait for ubuntu login screen on Jetson.
- login and create /etc/apt/apt.conf.d/90curtin-aptproxy file to use proxy authentication.
- start install of target components.
I think that proxy configuration of apt on Jetson should be done automatically,
because I write the same proxy settings on Settings menu of SDK Manager.
Anyway, thank you for your help.
I really appriciate it.
Hi makoto-san,
Thank you very much for your feedback. We’ll fix the proxy issue in future releases.
