Error installing SDK components
Below is the log, please have a look and let me know how to diagnose and resolve this issue. The jetson jetpack is 4.6.1 and I’m using sdkmanager archived versions to get it installed. It gave errors a lot of times while trying to install OS but was finally able to flash the OS without SDK components.
If there is a way to install sdk components in another way on the jetson target, please let me know.
13:18:18 SUMMARY: CUDA on Host - host: Install completed successfully.
13:18:18 SUMMARY: CUDA Cross Compile Package on Host - host: Install completed successfully.
13:18:18 SUMMARY: VisionWorks on Host - host: Install completed successfully.
13:18:18 SUMMARY: VPI on Host - host: Install completed successfully.
13:18:18 SUMMARY: NVIDIA Nsight Graphics - host: Install completed successfully.
13:18:18 SUMMARY: NVIDIA Nsight Systems - host: Install completed successfully.
13:18:35 ERROR: Connection to 192.168.1.246 22 port [tcp/ssh] succeeded!
13:18:36 ERROR: command terminated with error
13:18:37 ERROR: command terminated with error
13:18:38 ERROR: command terminated with error
13:18:39 ERROR: command terminated with error
13:18:40 ERROR: command terminated with error
13:18:41 SUMMARY: DateTime Target Setup - target: Install completed successfully.
13:20:31 ERROR: CUDA Toolkit for L4T - target: W: GPG error: file:/var/cuda-repo-l4t-10-2-local Release: The following signatures couldn’t be verified because the public key is not available: NO_PUBKEY F60F4B3D7FA2AF80
13:20:31 ERROR: CUDA Toolkit for L4T - target: E: The repository ‘file:/var/cuda-repo-l4t-10-2-local Release’ is not signed.
13:20:31 ERROR: CUDA Toolkit for L4T - target: N: Updating from such a repository can’t be done securely, and is therefore disabled by default.
13:20:31 ERROR: CUDA Toolkit for L4T - target: N: See apt-secure(8) manpage for repository creation and user configuration details.
13:20:45 ERROR: CUDA Toolkit for L4T - target: W: GPG error: file:/var/cuda-repo-l4t-10-2-local Release: The following signatures couldn’t be verified because the public key is not available: NO_PUBKEY F60F4B3D7FA2AF80
13:20:45 ERROR: CUDA Toolkit for L4T - target: E: The repository ‘file:/var/cuda-repo-l4t-10-2-local Release’ is not signed.
13:20:45 ERROR: CUDA Toolkit for L4T - target: N: Updating from such a repository can’t be done securely, and is therefore disabled by default.
13:20:45 ERROR: CUDA Toolkit for L4T - target: N: See apt-secure(8) manpage for repository creation and user configuration details.
13:21:09 ERROR: CUDA Toolkit for L4T - target: W: GPG error: file:/var/cuda-repo-l4t-10-2-local Release: The following signatures couldn’t be verified because the public key is not available: NO_PUBKEY F60F4B3D7FA2AF80
13:21:09 ERROR: CUDA Toolkit for L4T - target: E: The repository ‘file:/var/cuda-repo-l4t-10-2-local Release’ is not signed.
13:21:09 ERROR: CUDA Toolkit for L4T - target: N: Updating from such a repository can’t be done securely, and is therefore disabled by default.
13:21:09 ERROR: CUDA Toolkit for L4T - target: N: See apt-secure(8) manpage for repository creation and user configuration details.
13:21:09 ERROR: CUDA Toolkit for L4T - target: Unhandled error when running sudo apt-get -y update: W: GPG error: file:/var/cuda-repo-l4t-10-2-local Release: The following signatures couldn’t be verified because the public key is not available: NO_PUBKEY F60F4B3D7FA2AF80;E: The repository ‘file:/var/cuda-repo-l4t-10-2-local Release’ is not signed.;N: Updating from such a repository can’t be done securely, and is therefore disabled by default.;N: See apt-secure(8) manpage for repository creation and user configuration details.;
13:21:09 ERROR: CUDA Toolkit for L4T - target: command terminated with error
13:21:09 SUMMARY: CUDA Toolkit for L4T - target: First Error: Failed to install debian package [target]
13:21:09 SUMMARY: NVIDIA Container Runtime with Docker integration (Beta) - target: Depends on failed component
13:21:09 SUMMARY: Multimedia API - target: Depends on failed component
13:21:09 SUMMARY: TensorRT on Target - target: Depends on failed component
13:21:09 SUMMARY: VisionWorks on Target - target: Depends on failed component
13:21:09 SUMMARY: VPI on Target - target: Depends on failed component
13:21:15 ERROR: OpenCV on Target - target: W: GPG error: file:/var/cuda-repo-l4t-10-2-local Release: The following signatures couldn’t be verified because the public key is not available: NO_PUBKEY F60F4B3D7FA2AF80
13:21:15 ERROR: OpenCV on Target - target: E: The repository ‘file:/var/cuda-repo-l4t-10-2-local Release’ is not signed.
13:21:15 ERROR: OpenCV on Target - target: N: Updating from such a repository can’t be done securely, and is therefore disabled by default.
13:21:15 ERROR: OpenCV on Target - target: N: See apt-secure(8) manpage for repository creation and user configuration details.
13:21:15 ERROR: OpenCV on Target - target: Error: safe apt install failed: sudo apt-get update, exit code: 100, retry number: 1
13:21:29 ERROR: OpenCV on Target - target: W: GPG error: file:/var/cuda-repo-l4t-10-2-local Release: The following signatures couldn’t be verified because the public key is not available: NO_PUBKEY F60F4B3D7FA2AF80
13:21:29 ERROR: OpenCV on Target - target: E: The repository ‘file:/var/cuda-repo-l4t-10-2-local Release’ is not signed.
13:21:29 ERROR: OpenCV on Target - target: N: Updating from such a repository can’t be done securely, and is therefore disabled by default.
13:21:29 ERROR: OpenCV on Target - target: N: See apt-secure(8) manpage for repository creation and user configuration details.
13:21:29 ERROR: OpenCV on Target - target: Error: safe apt install failed: sudo apt-get update, exit code: 100, retry number: 2
13:21:53 ERROR: OpenCV on Target - target: W: GPG error: file:/var/cuda-repo-l4t-10-2-local Release: The following signatures couldn’t be verified because the public key is not available: NO_PUBKEY F60F4B3D7FA2AF80
13:21:53 ERROR: OpenCV on Target - target: E: The repository ‘file:/var/cuda-repo-l4t-10-2-local Release’ is not signed.
13:21:53 ERROR: OpenCV on Target - target: N: Updating from such a repository can’t be done securely, and is therefore disabled by default.
INSTALLATION FAILED
Please review the terminal tab for details. Resolve and RETRY.
EXPORT LOGS
RETRY
FAILED ITEMS
STOP TRYING
Copyright © 2023, NVIDIA CORPORATION. All rights reserved. | NVIDIA Developer
can you try running the following commands to install JetPack components on your device?
sudo apt update
sudo apt install nvidia-jetpack
Also, if there is no specific reason, we’d suggest using the latest JetPack/L4T release, which is 5.1.2 for AGX Xavier.
