Can not install SDK component by SDKmanager
I could not install SDK component by SDK manager.
13:20:47 ERROR: CUDA Toolkit for L4T - target: E: Unable to correct problems, you have held broken packages.
13:20:47 ERROR: CUDA Toolkit for L4T - target: Unhandled error when running sudo -E apt-get -y install cuda-toolkit-11-4 : E: Unable to correct problems, you have held broken packages.;
It is a part of error in SDK manager. I ran apt-get -f install, but it did not fixed. It seems that there is error with apt-get.
jetson@ubuntu:~$ sudo apt-get update
Get:1 file:/var/cuda-repo-l4t-11-4-local  InRelease [1.575 B]
Hit:2 http://ports.ubuntu.com/ubuntu-ports focal InRelease
Hit:3 https://repo.download.nvidia.com/jetson/common r35.3 InRelease
Hit:4 https://repo.download.nvidia.com/jetson/t194 r35.3 InRelease
Hit:5 http://ports.ubuntu.com/ubuntu-ports focal-updates InRelease
Hit:6 http://ports.ubuntu.com/ubuntu-ports focal-backports InRelease
Hit:7 http://ports.ubuntu.com/ubuntu-ports focal-security InRelease
Reading package lists... Done
So that I used sudo apt-get install nvidia-jetpack, but I got the error.
jetson@ubuntu:~$ sudo apt-get install nvidia-jetpack
Building dependency tree
Reading state information... Done
E: Unable to locate package nvidia-jetpack
jetson@ubuntu:~$ cat /etc/apt/sources.list.d/nvidia-l4t-apt-source.list
# SPDX-FileCopyrightText: Copyright (c) 2019-2021 NVIDIA CORPORATION & AFFILIATES. All rights reserved.
# SPDX-License-Identifier: LicenseRef-NvidiaProprietary
# NVIDIA CORPORATION, its affiliates and licensors retain all intellectual
# property and proprietary rights in and to this material, related
# documentation and any modifications thereto. Any use, reproduction,
# disclosure or distribution of this material and related documentation
# without an express license agreement from NVIDIA CORPORATION or
# its affiliates is strictly prohibited.
deb https://repo.download.nvidia.com/jetson/common r35.3 main
deb https://repo.download.nvidia.com/jetson/t194 r35.3 main
jetson@ubuntu:~$
Have you re-fresh the repo cache before installing nvidia-jetpack?
sudo apt update
sudo apt install nvidia-jetpack
@DaveYYY
It does not solved
Hit:2 https://repo.download.nvidia.com/jetson/common r35.3 InRelease
Hit:3 https://repo.download.nvidia.com/jetson/t194 r35.3 InRelease
Hit:4 http://ports.ubuntu.com/ubuntu-ports focal InRelease
Get:5 http://ports.ubuntu.com/ubuntu-ports focal-updates InRelease [114 kB]
Fetched 114 kB in 3s (34,5 kB/s)
It seems apt-get not work. I tried install python3-pip, but could not install
jetson@ubuntu:~$ sudo apt-get install python3-pip
Package python3-pip is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'python3-pip' has no installation candidate
What do you get with /etc/apt/sources.list?
Seems like there are some repo that are missing from your system.
@DaveYYY
Here is the output
# See http://help.ubuntu.com/community/UpgradeNotes for how to upgrade to
# newer versions of the distribution.
deb http://ports.ubuntu.com/ubuntu-ports/ focal main restricted
# deb-src http://ports.ubuntu.com/ubuntu-ports/ focal main restricted
## Major bug fix updates produced after the final release of the
## distribution.
deb http://ports.ubuntu.com/ubuntu-ports/ focal-updates main restricted
# deb-src http://ports.ubuntu.com/ubuntu-ports/ focal-updates main restricted
## N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu
## team. Also, please note that software in universe WILL NOT receive any
## review or updates from the Ubuntu security team.
deb http://ports.ubuntu.com/ubuntu-ports/ focal universe
# deb-src http://ports.ubuntu.com/ubuntu-ports/ focal universe
deb http://ports.ubuntu.com/ubuntu-ports/ focal-updates universe
# deb-src http://ports.ubuntu.com/ubuntu-ports/ focal-updates universe
## team, and may not be under a free licence. Please satisfy yourself as to
## your rights to use the software. Also, please note that software in
## multiverse WILL NOT receive any review or updates from the Ubuntu
## security team.
deb http://ports.ubuntu.com/ubuntu-ports/ focal multiverse
# deb-src http://ports.ubuntu.com/ubuntu-ports/ focal multiverse
deb http://ports.ubuntu.com/ubuntu-ports/ focal-updates multiverse
# deb-src http://ports.ubuntu.com/ubuntu-ports/ focal-updates multiverse
## N.B. software from this repository may not have been tested as
## extensively as that contained in the main release, although it includes
## newer versions of some applications which may provide useful features.
## Also, please note that software in backports WILL NOT receive any review
## or updates from the Ubuntu security team.
deb http://ports.ubuntu.com/ubuntu-ports/ focal-backports main restricted universe multiverse
# deb-src http://ports.ubuntu.com/ubuntu-ports/ focal-backports main restricted universe multiverse
## Uncomment the following two lines to add software from Canonical's
## 'partner' repository.
## This software is not part of Ubuntu, but is offered by Canonical and the
## respective vendors as a service to Ubuntu users.
# deb http://archive.canonical.com/ubuntu focal partner
# deb-src http://archive.canonical.com/ubuntu focal partner
deb http://ports.ubuntu.com/ubuntu-ports/ focal-security main restricted
# deb-src http://ports.ubuntu.com/ubuntu-ports/ focal-security main restricted
deb http://ports.ubuntu.com/ubuntu-ports/ focal-security universe
# deb-src http://ports.ubuntu.com/ubuntu-ports/ focal-security universe
deb http://ports.ubuntu.com/ubuntu-ports/ focal-security multiverse
# deb-src http://ports.ubuntu.com/ubuntu-ports/ focal-security multiverse
Is it a fresh L4T installation?
Are you using 35.3.1 or have you tried 35.4.1?
Yes, I used SDK manager to install JP5.1 (old JP was 5.1.2)
I flashed JP5.1, so Jetson Linux 35.3.1 is correct.
here is log of installation fail (nvidia container runtime) from SDK manager
13:58:46 ERROR: NVIDIA Container Runtime with Docker integration (Beta) - target: E: Unable to correct problems, you have held broken packages.
13:58:46 ERROR: NVIDIA Container Runtime with Docker integration (Beta) - target: Unhandled error when running sudo -E apt-get -y --allow-downgrades install /opt/nvidia/deb_repos/nvidia-docker2_2.11.0-1_all.deb: E: Unable to correct problems, you have held broken packages.;
The combination is JetPack 5.1/L4T 35.2.1, JetPack 5.1.1/L4T 35.3.1.
Can you please confirm it?
Maybe also try flashing the device manually again:
https://docs.nvidia.com/jetson/archives/r35.4.1/DeveloperGuide/text/IN/QuickStart.html
Yes, it is correct.
As the above error, the problem is with apt.
I mean please confirm whether you are using 5.1 or 5.1.1.
If it’s JetPack 5.1, then the repo should be pointing to 35.2:
deb https://repo.download.nvidia.com/jetson/common r35.2 main
deb https://repo.download.nvidia.com/jetson/t194 r35.2 main
Please just try re-flashing if you cannot get it done.
I install JP5.1.1 from SDK manager. I am re-flashing.
It took time but resolved my issues. Thanks.
