I am installing CUDA manually on my Jetson Xavier due to conflicts with OpenCV’s ability to run with CUDA after being installed from sdkmanager. After encountering many troubles with installing CUDA for ARM64 architectures, I have now gotten to the point at which I can run:
sudo apt-get -y install cuda
However when I do, I get an error code and it fails to install:
Errors were encountered while processing:
/tmp/apt-dpkg-install-ajkx61/43-libnvidia-compute-435_435.17.01-0ubuntu1_arm64.deb
/tmp/apt-dpkg-install-ajkx61/47-libnvidia-gl-435_435.17.01-0ubuntu1_arm64.deb
E: Sub-process /usr/bin/dpkg returned an error code (1)
What conflicts were you facing? OpenCV that is installed through the SDK Manager does not include support for CUDA, so if you try to use OpenCV cuda wrapper with the default version you will find errors.
Thanks for your reply, I have now resolved the installing of OpenCV with CUDA enabled on the Jetson. My only challenge now is to get it to install it whilst recognizing the cuDNN installed. As it returns the error that the version found is unsuitable. Which should be the pjne installed from SDK Manager.
