Info
| NVIDIA-SMI 570.144 Driver Version: 570.144 CUDA Version: 12.8 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA GeForce RTX 5090 Off | 00000000:01:00.0 On | N/A |
| 0% 54C P8 28W / 600W | 118MiB / 32607MiB | 0% Default |
| | | N/A |
| 1 NVIDIA GeForce RTX 5090 Off | 00000000:04:00.0 Off | N/A |
| 0% 53C P8 12W / 600W | 30017MiB / 32607MiB | 0% Default |
| | | N/A |
Copyright (c) 2005-2025 NVIDIA Corporation
Built on Fri_Feb_21_20:23:50_PST_2025
Cuda compilation tools, release 12.8, V12.8.93
Build cuda_12.8.r12.8/compiler.35583870_0
When I run Samples/1_Utilities/deviceQuery$ ./deviceQuery
./deviceQuery Starting…
CUDA Device Query (Runtime API) version (CUDART static linking)
cudaGetDeviceCount returned 3
→ initialization error
Result = FAIL
Also error in pytorch2.7.0 cu12.8
torch.cuda.is_available()
/home/yons/.local/lib/python3.10/site-packages/torch/cuda/init.py:174: UserWarning: CUDA initialization: CUDA driver initialization failed, you might not have a CUDA gpu. (Triggered internally at /pytorch/c10/cuda/CUDAFunctions.cpp:109.)
return torch._C._cuda_getDeviceCount() > 0
False
torch.cuda.device_count()
2
But when I set export CUDA_VISIBLE_DEVICES=0 or export CUDA_VISIBLE_DEVICES=1, both single card works.
Detected 1 CUDA Capable device(s)
Device 0: “NVIDIA GeForce RTX 5090”
CUDA Driver Version / Runtime Version 12.8 / 12.8
CUDA Capability Major/Minor version number: 12.0
Total amount of global memory: 32120 MBytes (33680326656 bytes)
(170) Multiprocessors, (128) CUDA Cores/MP: 21760 CUDA Cores
GPU Max Clock rate: 2655 MHz (2.65 GHz)
Memory Clock rate: 14001 Mhz
Memory Bus Width: 512-bit
L2 Cache Size: 100663296 bytes
Maximum Texture Dimension Size (x,y,z) 1D=(131072), 2D=(131072, 65536), 3D=(16384, 16384, 16384)
Maximum Layered 1D Texture Size, (num) layers 1D=(32768), 2048 layers
Maximum Layered 2D Texture Size, (num) layers 2D=(32768, 32768), 2048 layers
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 49152 bytes
Total shared memory per multiprocessor: 102400 bytes
Total number of registers available per block: 65536
Warp size: 32
Maximum number of threads per multiprocessor: 1536
Maximum number of threads per block: 1024
Max dimension size of a thread block (x,y,z): (1024, 1024, 64)
Max dimension size of a grid size (x,y,z): (2147483647, 65535, 65535)
Maximum memory pitch: 2147483647 bytes
Texture alignment: 512 bytes
Concurrent copy and kernel execution: Yes with 2 copy engine(s)
Run time limit on kernels: Yes
Integrated GPU sharing Host Memory: No
Support host page-locked memory mapping: Yes
Alignment requirement for Surfaces: Yes
Device has ECC support: Disabled
Device supports Unified Addressing (UVA): Yes
Device supports Managed Memory: Yes
Device supports Compute Preemption: Yes
Supports Cooperative Kernel Launch: Yes
Supports MultiDevice Co-op Kernel Launch: Yes
Device PCI Domain ID / Bus ID / location ID: 0 / 4 / 0
Compute Mode:
< Default (multiple host threads can use ::cudaSetDevice() with device simultaneously) >
deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 12.8, CUDA Runtime Version = 12.8, NumDevs = 1
Result = PASS
