Strange problem with CUDA on 3 GPUS (5090, 6000 Ada, RTX8000)
I have a strange problem with my GPU setup.
I’m on Windows 11, Core i9-9920X, 128 GB RAM.
I have 3 GPUs: 5090, 6000 Ada and recently added RTX8000.
Everything is installed and configured and confirmed working.
Currently on 576.52 Studio driver.
When all 3 GPUs are turned on (in device manager) any kind of CUDA application fails usually reporting device 1 is busy (no matter on what order the GPUs are).
Or that CUDA context failed with unknown error (Blender)
When any 2 are on everything works fine no errors in multiple applications I’ve tested.
So to simplify everything I’ve got a simple test with pytorch:
python -c ‘import torch; torch.randn(1).to(0)’
With all 3 on:
When I run the test I get:
PS X:\!_Nvidia_problem> python -c 'import torch; torch.randn(1).to(0)'                                                  Traceback (most recent call last):        File "<string>", line 1, in <module>        import torch; torch.randn(1).to(0)        ~~~~~~~~~~~~~~~~~^^^        RuntimeError: CUDA error: CUDA-capable device(s) is/are busy or unavailable                                             CUDA kernel errors might be asynchronously reported at some other API call, so the stacktrace below might be incorrect. For debugging consider passing CUDA_LAUNCH_BLOCKING=1
        Compile with `TORCH_USE_CUDA_DSA` to enable device-side assertions.
When I turn off any of those three GPUs test runs just fine.
Also tested with KoboldCPP
ggml_cuda_init: found 3 CUDA devices:        Device 0: NVIDIA GeForce RTX 5090, compute capability 12.0, VMM: yes                                                    Device 1: NVIDIA RTX 6000 Ada Generation, compute capability 8.9, VMM: yes                                              Device 2: Quadro RTX 8000, compute capability 7.5, VMM: yes                                                           CUDA error: CUDA-capable device(s) is/are busy or unavailable                                                             current device: 1, in function ggml_cuda_set_device at C:\a\koboldcpp\koboldcpp\ggml\src\ggml-cuda\ggml-cuda.cu:90      cudaSetDevice(device)        C:\a\koboldcpp\koboldcpp\ggml\src\ggml-cuda\ggml-cuda.cu:77: CUDA error                                                 done
This is the most common one also in ComfyUI when generating.
Sometimes it just quits with no error (the simple test I mentioned before acts the same but it happens rarely).
With exact same settings (size of the model doesn’t matter acts same with smallest models) and 2 GPUS no matter which ones all works fine.
Blender refuses to initialize CUDA when all three are present, no matter which ones are turned on in preferences. But when one is turned off in device manager runs without problem.
I’ve also tried to run big LLM model on any 2 GPUs with third turned off, it runs no problem. Then I turn on the third one and start ComfyUI (only app I know how to designate on which GPU should run and designate the third one (–cuda-device n) where n is either 0,1 or 2 I can successfully run Flux alongside LLM on the other 2 GPUs. So all three can work at the same time, just can’t initialize for one app.
I’ve tried to switch 6000 Ada and 8000 to TCC but it changes nothing except the vRAM is not shared (VMM: no).
RTX8000 has no display ports so can run either in TCC or MCDM mode. MCDM seams to cooperate better with Windows as it recognizes it in task manager as NPU.
Here are nvidia-smi queries of each card:
==============NVSMI LOG==============
Timestamp                                 : Thu May 29 11:53:00 2025
Driver Version                            : 576.52
CUDA Version                              : 12.9
Attached GPUs                             : 3
GPU 00000000:C1:00.0
    Product Name                          : NVIDIA GeForce RTX 5090
    Product Brand                         : GeForce
    Product Architecture                  : Blackwell
    Display Mode                          : Requested functionality has been deprecated
    Display Attached                      : Yes
    Display Active                        : Enabled
    Persistence Mode                      : N/A
    Addressing Mode                       : N/A
    MIG Mode
        Current                           : N/A
        Pending                           : N/A
    Accounting Mode                       : Disabled
    Accounting Mode Buffer Size           : 4000
    Driver Model
        Current                           : WDDM
        Pending                           : WDDM
    Serial Number                         : 0
    GPU UUID                              : GPU-a4a0e04a-b19d-5b58-33f5-32fa6d7c1a0a
    Minor Number                          : N/A
    VBIOS Version                         : 98.02.2e.40.c0
    MultiGPU Board                        : No
    Board ID                              : 0xc100
    Board Part Number                     : N/A
    GPU Part Number                       : 2B85-300-A1
    FRU Part Number                       : N/A
    Platform Info
        Chassis Serial Number             :
        Slot Number                       : 0
        Tray Index                        : 0
        Host ID                           : 1
        Peer Type                         : Direct Connected
        Module Id                         : 1
        GPU Fabric GUID                   : 0x0000000000000000
    Inforom Version
        Image Version                     : G005.0000.98.01
        OEM Object                        : 2.1
        ECC Object                        : N/A
        Power Management Object           : N/A
    Inforom BBX Object Flush
        Latest Timestamp                  : N/A
        Latest Duration                   : N/A
    GPU Operation Mode
        Current                           : N/A
        Pending                           : N/A
    GPU C2C Mode                          : Disabled
    GPU Virtualization Mode
        Virtualization Mode               : None
        Host VGPU Mode                    : N/A
        vGPU Heterogeneous Mode           : N/A
    GPU Reset Status
        Reset Required                    : Requested functionality has been deprecated
        Drain and Reset Recommended       : Requested functionality has been deprecated
    GPU Recovery Action                   : None
    GSP Firmware Version                  : N/A
    IBMNPU
        Relaxed Ordering Mode             : N/A
    PCI
        Bus                               : 0xC1
        Device                            : 0x00
        Domain                            : 0x0000
        Device Id                         : 0x2B8510DE
        Bus Id                            : 00000000:C1:00.0
        Sub System Id                     : 0x89EC1043
        GPU Link Info
            PCIe Generation
                Max                       : 3
                Current                   : 3
                Device Current            : 3
                Device Max                : 5
                Host Max                  : 3
            Link Width
                Max                       : 16x
                Current                   : 16x
        Bridge Chip
            Type                          : N/A
            Firmware                      : N/A
        Replays Since Reset               : 0
        Replay Number Rollovers           : 0
        Tx Throughput                     : 14689 KB/s
        Rx Throughput                     : 16210 KB/s
        Atomic Caps Outbound              : N/A
        Atomic Caps Inbound               : N/A
    Fan Speed                             : 30 %
    Performance State                     : P0
    Clocks Event Reasons
        Idle                              : Not Active
        Applications Clocks Setting       : Not Active
        SW Power Cap                      : Not Active
        HW Slowdown                       : Not Active
            HW Thermal Slowdown           : Not Active
            HW Power Brake Slowdown       : Not Active
        Sync Boost                        : Not Active
        SW Thermal Slowdown               : Not Active
        Display Clock Setting             : Not Active
    Clocks Event Reasons Counters
        SW Power Capping                  : 219635 us
        Sync Boost                        : 0 us
        SW Thermal Slowdown               : 0 us
        HW Thermal Slowdown               : 0 us
        HW Power Braking                  : 0 us
    Sparse Operation Mode                 : N/A
    FB Memory Usage
        Total                             : 32607 MiB
        Reserved                          : 506 MiB
        Used                              : 3882 MiB
        Free                              : 28220 MiB
    BAR1 Memory Usage
        Total                             : 32768 MiB
        Used                              : 32740 MiB
        Free                              : 28 MiB
    Conf Compute Protected Memory Usage
        Total                             : N/A
        Used                              : N/A
        Free                              : N/A
    Compute Mode                          : Default
    Utilization
        GPU                               : 5 %
        Memory                            : 1 %
        Encoder                           : 0 %
        Decoder                           : 9 %
        JPEG                              : 0 %
        OFA                               : 0 %
    Encoder Stats
        Active Sessions                   : 0
        Average FPS                       : 0
        Average Latency                   : 0
    FBC Stats
        Active Sessions                   : 0
        Average FPS                       : 0
        Average Latency                   : 0
    DRAM Encryption Mode
        Current                           : Disabled
        Pending                           : Disabled
    ECC Mode
        Current                           : N/A
        Pending                           : N/A
    ECC Errors
        Volatile
            SRAM Correctable              : N/A
            SRAM Uncorrectable Parity     : N/A
            SRAM Uncorrectable SEC-DED    : N/A
            DRAM Correctable              : N/A
            DRAM Uncorrectable            : N/A
        Aggregate
            SRAM Threshold Exceeded       : N/A
        Aggregate Uncorrectable SRAM Sources
            SRAM L2                       : N/A
            SRAM SM                       : N/A
            SRAM Microcontroller          : N/A
            SRAM PCIE                     : N/A
            SRAM Other                    : N/A
    Retired Pages
        Single Bit ECC                    : N/A
        Double Bit ECC                    : N/A
        Pending Page Blacklist            : N/A
    Remapped Rows                         : N/A
    Temperature
        GPU Current Temp                  : 32 C
        GPU T.Limit Temp                  : 57 C
        GPU Shutdown T.Limit Temp         : -5 C
        GPU Slowdown T.Limit Temp         : -2 C
        GPU Max Operating T.Limit Temp    : 0 C
        GPU Target Temperature            : N/A
        Memory Current Temp               : N/A
        Memory Max Operating T.Limit Temp : N/A
    GPU Power Readings
        Average Power Draw                : 61.96 W
        Instantaneous Power Draw          : 63.83 W
        Current Power Limit               : 450.00 W
        Requested Power Limit             : 450.00 W
        Default Power Limit               : 600.00 W
        Min Power Limit                   : 400.00 W
        Max Power Limit                   : 600.00 W
    GPU Memory Power Readings
        Average Power Draw                : N/A
        Instantaneous Power Draw          : N/A
    Module Power Readings
        Current Power Limit               : N/A
        Requested Power Limit             : N/A
        Default Power Limit               : N/A
        Min Power Limit                   : N/A
        Max Power Limit                   : N/A
    Power Smoothing                       : N/A
    Workload Power Profiles
        Requested Profiles                : N/A
        Enforced Profiles                 : N/A
    Clocks
        Graphics                          : 907 MHz
        SM                                : 907 MHz
        Memory                            : 14001 MHz
        Video                             : 1320 MHz
    Applications Clocks
        Graphics                          : N/A
        Memory                            : N/A
    Default Applications Clocks
        Graphics                          : N/A
        Memory                            : N/A
    Deferred Clocks
        Memory                            : N/A
    Max Clocks
        Graphics                          : 3090 MHz
        SM                                : 3090 MHz
        Memory                            : 14001 MHz
        Video                             : 3090 MHz
    Max Customer Boost Clocks
        Graphics                          : N/A
    Clock Policy
        Auto Boost                        : N/A
        Auto Boost Default                : N/A
    Voltage
        Graphics                          : Requested functionality has been deprecated
    Fabric
        State                             : N/A
        Status                            : N/A
        CliqueId                          : N/A
        ClusterUUID                       : N/A
        Health
            Bandwidth                     : N/A
            Route Recovery in progress    : N/A
            Route Unhealthy               : N/A
            Access Timeout Recovery       : N/A
    Processes
        GPU instance ID                   : N/A
        Compute instance ID               : N/A
        Process ID                        : 2364
            Type                          : C+G
            Name                          :
            Used GPU Memory               : Not available in WDDM driver model
        Process ID                        : 3396
            Type                          : C+G
            Name                          : C:\Program Files\WindowsApps\MSTeams_25094.310.3616.953_x64__8wekyb3d8bbwe\ms-teams.exe
        Process ID                        : 4500
            Type                          : C+G
            Name                          : C:\Program Files\WindowsApps\Microsoft.WindowsTerminal_1.22.11141.0_x64__8wekyb3d8bbwe\WindowsTerminal.exe
        Process ID                        : 5596
            Type                          : C+G
        Process ID                        : 8460
            Type                          : C+G
        Process ID                        : 9176
            Type                          : C+G
            Name                          : D:\Program Files\Session\Session.exe
        Process ID                        : 9620
            Type                          : C+G
            Name                          : D:\Program Files\QNAP\QVR Pro Client\QVR Pro Client.exe
        Process ID                        : 9964
            Type                          : C+G
        Process ID                        : 13284
            Type                          : C+G
            Name                          : C:\Program Files\WindowsApps\AdobeNotificationClient_6.0.0.1_x86__enpm4xejd91yc\AdobeNotificationClient.exe
        Process ID                        : 13932
            Type                          : C+G
        Process ID                        : 13960
            Type                          : C+G
        Process ID                        : 16628
            Type                          : C+G
            Name                          : C:\Program Files (x86)\Microsoft\Edge\Application\msedge.exe
        Process ID                        : 17416
            Type                          : C+G
        Process ID                        : 17440
            Type                          : C+G
            Name                          : C:\Program Files\WindowsApps\Microsoft.MicrosoftStickyNotes_6.1.4.0_x64__8wekyb3d8bbwe\Microsoft.Notes.exe
        Process ID                        : 17576
            Type                          : C+G
            Name                          : C:\Program Files\WindowsApps\MicrosoftWindows.Client.WebExperience_525.10401.30.0_x64__cw5n1h2txyewy\WidgetBoard.exe
        Process ID                        : 17616
            Type                          : C+G
        Process ID                        : 19400
            Type                          : C+G
        Process ID                        : 19596
            Type                          : C+G
        Process ID                        : 20340
            Type                          : C+G
        Process ID                        : 21036
            Type                          : C+G
            Name                          : C:\Windows\SystemApps\MicrosoftWindows.Client.CBS_cw5n1h2txyewy\TextInputHost.exe
        Process ID                        : 21052
            Type                          : C+G
            Name                          : C:\Program Files (x86)\Microsoft\EdgeWebView\Application\136.0.3240.92\msedgewebview2.exe
        Process ID                        : 21508
            Type                          : C+G
            Name                          : C:\Program Files\Mozilla Firefox\firefox.exe
        Process ID                        : 21772
            Type                          : C+G
            Name                          : C:\Program Files\NZXT CAM\NZXT CAM.exe
        Process ID                        : 22356
            Type                          : C+G
            Name                          : C:\Program Files\LGHUB\system_tray\lghub_system_tray.exe
        Process ID                        : 24336
            Type                          : C+G
        Process ID                        : 24528
            Type                          : C+G
        Process ID                        : 27460
            Type                          : C+G
            Name                          :
        Process ID                        : 28012
            Type                          : C+G
            Name                          : D:\Program Files (x86)\VMware\VMware Workstation\x64\mksSandbox.exe
        Process ID                        : 28692
            Type                          : C+G
        Process ID                        : 31884
            Type                          : C+G
        Process ID                        : 34764
            Type                          : C+G
            Name                          :
        Process ID                        : 39632
            Type                          : C+G
    Capabilities
        EGM                               : disabled
Timestamp                                 : Thu May 29 11:52:47 2025
CUDA Version                              : 12.9
Attached GPUs                             : 3
GPU 00000000:A1:00.0
    Product Name                          : NVIDIA RTX 6000 Ada Generation
    Product Brand                         : NVIDIA RTX
    Product Architecture                  : Ada Lovelace
    Display Attached                      : No
    Display Active                        : Disabled
    MIG Mode
        Current                           : N/A
        Pending                           : N/A
    Driver Model
        Current                           : WDDM
        Pending                           : WDDM
    Serial Number                         : 1791225053806
    GPU UUID                              : GPU-d41ff7ba-43d9-db12-e2a8-e08213b10599
    Minor Number                          : N/A
    VBIOS Version                         : 95.02.59.00.09
    MultiGPU Board                        : No
    Board ID                              : 0xa100
    Board Part Number                     : 900-5G133-2250-000
    GPU Part Number                       : 26B1-870-A1
    Platform Info
        Chassis Serial Number             : N/A
        Slot Number                       : N/A
        Tray Index                        : N/A
        Host ID                           : N/A
        Peer Type                         : N/A
        Module Id                         : 1
        GPU Fabric GUID                   : N/A
    Inforom Version
        Image Version                     : G133.0510.00.02
        OEM Object                        : 2.1
        ECC Object                        : 6.16
    GPU Operation Mode
        Current                           : N/A
        Pending                           : N/A
    GPU C2C Mode                          : N/A
    GPU Reset Status
    IBMNPU
    PCI
        Bus                               : 0xA1
        Device                            : 0x00
        Domain                            : 0x0000
        Device Id                         : 0x26B110DE
        Bus Id                            : 00000000:A1:00.0
        Sub System Id                     : 0x16A110DE
        GPU Link Info
            PCIe Generation
                Max                       : 3
                Current                   : 1
                Device Current            : 1
                Device Max                : 4
                Host Max                  : 3
            Link Width
                Max                       : 16x
                Current                   : 16x
        Bridge Chip
            Type                          : N/A
            Firmware                      : N/A
        Tx Throughput                     : 50 KB/s
        Rx Throughput                     : 550 KB/s
    Fan Speed                             : 30 %
    Performance State                     : P8
        Idle                              : Active
        SW Power Capping                  : 0 us
        Sync Boost                        : 0 us
    FB Memory Usage
        Total                             : 49140 MiB
        Reserved                          : 727 MiB
        Used                              : 0 MiB
        Free                              : 48413 MiB
    BAR1 Memory Usage
        Total                             : 65536 MiB
        Used                              : 49156 MiB
        Free                              : 16380 MiB
        Total                             : N/A
        Used                              : N/A
        Free                              : N/A
    Utilization
        GPU                               : 0 %
        Memory                            : 0 %
        Encoder                           : 0 %
        Decoder                           : 0 %
        JPEG                              : 0 %
        OFA                               : 0 %
    Encoder Stats
        Active Sessions                   : 0
        Average FPS                       : 0
        Average Latency                   : 0
    FBC Stats
        Active Sessions                   : 0
        Average FPS                       : 0
        Average Latency                   : 0
        Current                           : N/A
        Pending                           : N/A
    ECC Mode
        Current                           : Disabled
        Pending                           : Disabled
    ECC Errors
        Volatile
        Aggregate
            SRAM L2                       : N/A
            SRAM SM                       : N/A
            SRAM PCIE                     : N/A
            SRAM Other                    : N/A
    Retired Pages
    Remapped Rows
        Correctable Error                 : 0
        Uncorrectable Error               : 0
        Pending                           : No
        Remapping Failure Occurred        : No
        Bank Remap Availability Histogram
            Max                           : 192 bank(s)
            High                          : 0 bank(s)
            Partial                       : 0 bank(s)
            Low                           : 0 bank(s)
            None                          : 0 bank(s)
    Temperature
        GPU Current Temp                  : 36 C
        GPU T.Limit Temp                  : 55 C
        GPU Shutdown T.Limit Temp         : -7 C
        GPU Target Temperature            : 85 C
    GPU Power Readings
        Average Power Draw                : 8.70 W
        Instantaneous Power Draw          : 8.79 W
        Current Power Limit               : 225.00 W
        Requested Power Limit             : 225.00 W
        Default Power Limit               : 300.00 W
        Min Power Limit                   : 100.00 W
        Max Power Limit                   : 300.00 W
    Clocks
        Graphics                          : 210 MHz
        SM                                : 210 MHz
        Memory                            : 405 MHz
        Video                             : 1185 MHz
    Applications Clocks
        Graphics                          : 2505 MHz
        Memory                            : 10001 MHz
        Graphics                          : 2505 MHz
        Memory                            : 10001 MHz
    Deferred Clocks
        Memory                            : N/A
    Max Clocks
        Graphics                          : 3105 MHz
        SM                                : 3105 MHz
        Memory                            : 10001 MHz
        Video                             : 2415 MHz
        Graphics                          : N/A
    Clock Policy
        Auto Boost                        : N/A
    Voltage
    Fabric
        State                             : N/A
        Status                            : N/A
        CliqueId                          : N/A
        ClusterUUID                       : N/A
        Health
            Bandwidth                     : N/A
    Processes                             : None
    Capabilities
        EGM                               : disabled
Timestamp                                 : Thu May 29 11:53:14 2025
CUDA Version                              : 12.9
Attached GPUs                             : 3
GPU 00000000:E1:00.0
    Product Name                          : Quadro RTX 8000
    Product Architecture                  : Turing
    MIG Mode
        Current                           : N/A
        Pending                           : N/A
    Driver Model
        Current                           : MCDM
        Pending                           : MCDM
    Serial Number                         : 1324420022419
    GPU UUID                              : GPU-e6babc56-1f6d-da32-a65f-c51266d74f93
    Minor Number                          : N/A
    VBIOS Version                         : 90.02.4e.00.03
    MultiGPU Board                        : No
    Board ID                              : 0xe100
    Board Part Number                     : 900-2G150-0150-030
    GPU Part Number                       : 1E78-895-A1
    Platform Info
        Slot Number                       : N/A
        Tray Index                        : N/A
        Host ID                           : N/A
        Peer Type                         : N/A
        Module Id                         : 1
    Inforom Version
        Image Version                     : G150.0231.00.02
        OEM Object                        : 1.1
        ECC Object                        : 5.0
    GPU Operation Mode
        Current                           : N/A
        Pending                           : N/A
    GPU C2C Mode                          : N/A
    GPU Reset Status
    IBMNPU
    PCI
        Bus                               : 0xE1
        Device                            : 0x00
        Domain                            : 0x0000
        Device Id                         : 0x1E7810DE
        Bus Id                            : 00000000:E1:00.0
        Sub System Id                     : 0x13D810DE
        GPU Link Info
            PCIe Generation
                Max                       : 3
                Current                   : 3
                Device Current            : 3
                Device Max                : 3
                Host Max                  : 3
            Link Width
                Max                       : 16x
                Current                   : 8x
        Bridge Chip
            Type                          : N/A
            Firmware                      : N/A
        Rx Throughput                     : 50 KB/s
    Fan Speed                             : N/A
        Idle                              : Active
        SW Power Capping                  : 157900434 us
        Sync Boost                        : 0 us
    FB Memory Usage
        Total                             : 49152 MiB
        Reserved                          : 552 MiB
        Used                              : 0 MiB
        Free                              : 48601 MiB
    BAR1 Memory Usage
        Total                             : 32768 MiB
        Used                              : 32739 MiB
        Free                              : 29 MiB
        Total                             : N/A
        Used                              : N/A
        Free                              : N/A
    Utilization
        GPU                               : 0 %
        Memory                            : 0 %
        Encoder                           : 0 %
        Decoder                           : 0 %
        JPEG                              : 0 %
        OFA                               : 0 %
    Encoder Stats
        Active Sessions                   : 0
        Average FPS                       : 0
        Average Latency                   : 0
    FBC Stats
        Active Sessions                   : 0
        Average FPS                       : 0
        Average Latency                   : 0
        Current                           : N/A
        Pending                           : N/A
    ECC Mode
        Current                           : Disabled
        Pending                           : Disabled
    ECC Errors
        Volatile
            SRAM Uncorrectable            : N/A
        Aggregate
    Retired Pages
        Single Bit ECC                    : 0
        Double Bit ECC                    : 0
        Pending Page Blacklist            : No
    Remapped Rows                         : N/A
    Temperature
        GPU Current Temp                  : 29 C
        GPU T.Limit Temp                  : N/A
        GPU Shutdown Temp                 : 87 C
        GPU Slowdown Temp                 : 84 C
        GPU Max Operating Temp            : 82 C
        Memory Max Operating Temp         : N/A
    GPU Power Readings
        Instantaneous Power Draw          : 18.37 W
        Current Power Limit               : 250.00 W
        Requested Power Limit             : 250.00 W
        Default Power Limit               : 250.00 W
        Min Power Limit                   : 150.00 W
        Max Power Limit                   : 250.00 W
    Clocks
        Graphics                          : 300 MHz
        SM                                : 300 MHz
        Memory                            : 405 MHz
        Video                             : 540 MHz
    Applications Clocks
        Graphics                          : 1230 MHz
        Memory                            : 6501 MHz
        Graphics                          : 1230 MHz
        Memory                            : 6501 MHz
    Deferred Clocks
        Memory                            : N/A
    Max Clocks
        Graphics                          : 1620 MHz
        SM                                : 1620 MHz
        Memory                            : 6501 MHz
        Video                             : 1500 MHz
        Graphics                          : 1620 MHz
    Clock Policy
        Auto Boost                        : N/A
    Voltage
    Fabric
        State                             : N/A
        Status                            : N/A
        CliqueId                          : N/A
        ClusterUUID                       : N/A
        Health
            Bandwidth                     : N/A
    Processes                             : None
    Capabilities
        EGM                               : disabled
Also installed newest CUDA Toolkit.
I’ve been scratching my head for a while now and done so many tests. I’m sure its either something I forgot to setup or its just not possible for some reason.
Also I’m just a hobbyist and not all that experienced.
Haven’t tried running Ubuntu and setting everything up but I’d prefer it working on Windows just out of convenience.
If it was always the same GPU failing I’d say bad GPU but all three work fine in pairs so this is what makes it so frustrating :)
So any ideas welcome :)
And I’m sorry if I’ve posted it in the wrong section, its my first time :)
Also can attach just one picture cause I’m new so I’m sorry for bad formatting.
A little bit of an update, got to test the setup with Quadro RTX 4000 (the little sister to the 8000 - basically same lineup just lower specs otherwise exactly same CUDA version - 7.5) the only difference was it was card with DP ports so it was in WDDM mode instead of MCDM.
So the effect is identical so its not the particular card, maybe this hardware combination plus my setup is just not possible.
I give up, removed the third card and putting it in another rig, so it will be two quadros 4000 and 8000 and will be able to utilize quadro drivers.
I was wondering maybe BAR1 or Resize BAR settings could be at fault here? I don’t know much about it so don’t even know how to set it up properly aside that there are BIOS settings and in general it works for me. But maybe with third card it needs to be tweaked?
