I’m trying to get CUDA interoperability to work in OptiX. When I try to compile the Collision example project I get a bunch of linker errors. Also when I try to include in another project I get a ton of error complaining about cuda_runtime_api. Has anyone else seen these error and figure out a way to get either things to work?
2>CollisionOptiX.obj : error LNK2019: unresolved external symbol _cudaGetErrorString@4 referenced in function "private: void __thiscall CollisionScene::SimLineOfSightEye(bool,unsigned int)" (?SimLineOfSightEye@CollisionScene@@AAEX_NI@Z)
2>CollisionOptiX.obj : error LNK2019: unresolved external symbol _cudaGetLastError@0 referenced in function "private: void __thiscall CollisionScene::SimLineOfSightEye(bool,unsigned int)" (?SimLineOfSightEye@CollisionScene@@AAEX_NI@Z)
2>CollisionOptiX.obj : error LNK2019: unresolved external symbol _cudaSetDevice@4 referenced in function "private: void __thiscall CollisionScene::SimLineOfSightEye(bool,unsigned int)" (?SimLineOfSightEye@CollisionScene@@AAEX_NI@Z)
2>collision_generated_collision_CUDA.cu.obj : error LNK2019: unresolved external symbol _cudaConfigureCall@32 referenced in function _LOS_reduction_CUDA
2>collision_generated_collision_CUDA.cu.obj : error LNK2019: unresolved external symbol _cudaSetupArgument@12 referenced in function "void __cdecl __device_stub__Z13LOS_reductionPK6float4PS_jPK6float3jPKfS7_fff(struct float4 const *,struct float4 *,unsigned int,struct float3 const *,unsigned int,float const *,float const *,float,float,float)" (?__device_stub__Z13LOS_reductionPK6float4PS_jPK6float3jPKfS7_fff@@YAXPBUfloat4@@PAU1@IPBUfloat3@@IPBM3MMM@Z)
2>collision_generated_collision_CUDA.cu.obj : error LNK2019: unresolved external symbol ___cudaRegisterVar@32 referenced in function "void __cdecl __sti____cudaRegisterAll_49_tmpxft_000013e0_00000000_6_collision_CUDA_cpp1_ii_40b6c2ed(void)" (?__sti____cudaRegisterAll_49_tmpxft_000013e0_00000000_6_collision_CUDA_cpp1_ii_40b6c2ed@@YAXXZ)
2>collision_generated_collision_CUDA.cu.obj : error LNK2019: unresolved external symbol ___cudaRegisterFunction@40 referenced in function "void __cdecl __sti____cudaRegisterAll_49_tmpxft_000013e0_00000000_6_collision_CUDA_cpp1_ii_40b6c2ed(void)" (?__sti____cudaRegisterAll_49_tmpxft_000013e0_00000000_6_collision_CUDA_cpp1_ii_40b6c2ed@@YAXXZ)
2>collision_generated_collision_CUDA.cu.obj : error LNK2019: unresolved external symbol ___cudaRegisterFatBinary@4 referenced in function "void __cdecl __sti____cudaRegisterAll_49_tmpxft_000013e0_00000000_6_collision_CUDA_cpp1_ii_40b6c2ed(void)" (?__sti____cudaRegisterAll_49_tmpxft_000013e0_00000000_6_collision_CUDA_cpp1_ii_40b6c2ed@@YAXXZ)
2>collision_generated_collision_CUDA.cu.obj : error LNK2019: unresolved external symbol ___cudaUnregisterFatBinary@4 referenced in function "void __cdecl __cudaUnregisterBinaryUtil(void)" (?__cudaUnregisterBinaryUtil@@YAXXZ)
2>collision_generated_collision_CUDA.cu.obj : error LNK2019: unresolved external symbol _cudaLaunch@4 referenced in function "enum cudaError __cdecl cudaLaunch(char *)" (??$cudaLaunch@D@@YA?AW4cudaError@@PAD@Z)
Error 1 error C2143: syntax error : missing ';' before '__stdcall' c:program files (x86)
vidia gpu computing toolkitcudav4.2includecuda_runtime_api.h 200
Error 2 error C4430: missing type specifier - int assumed. Note: C++ does not support default-int c:program files (x86)
Error 3 error C2143: syntax error : missing ';' before '__stdcall' c:program files (x86)
Error 4 error C4430: missing type specifier - int assumed. Note: C++ does not support default-int c:program files (x86)
