I believe your conclusion is flawed, possibly because you have made a mistake of some sort.
I don’t witness any such discrepancy.
Here is a fully worked test case, comparing both usages (dynamically allocated shared memory and statically allocated shared memory) based on the code presented in the programming guide:
http://docs.nvidia.com/cuda/cuda-c-programming-guide/index.html#shared-memory
$ cat t995.cu
#include <stdio.h>
// DSIZE should be evenly divisible by BLOCK_SIZE
#define DSIZE 2048
#define AROW DSIZE
#define ACOL DSIZE
#define BCOL DSIZE
#define TEST_VAL 1.0f
// Thread block size
#define BLOCK_SIZE 16
#include <time.h>
#include <sys/time.h>
#define USECPSEC 1000000ULL
long long dtime_usec(unsigned long long start){
timeval tv;
gettimeofday(&tv, 0);
return ((tv.tv_sec*USECPSEC)+tv.tv_usec)-start;
typedef float sft[BLOCK_SIZE];
// Matrices are stored in row-major order:
// M(row, col) = *(M.elements + row * M.stride + col)
typedef struct {
int width;
int height;
int stride;
float* elements;
} Matrix;
// Get a matrix element
__device__ float GetElement(const Matrix A, int row, int col)
return A.elements[row * A.stride + col];
// Set a matrix element
__device__ void SetElement(Matrix A, int row, int col,
float value)
A.elements[row * A.stride + col] = value;
// Get the BLOCK_SIZExBLOCK_SIZE sub-matrix Asub of A that is
// located col sub-matrices to the right and row sub-matrices down
// from the upper-left corner of A
__device__ Matrix GetSubMatrix(Matrix A, int row, int col)
Matrix Asub;
Asub.width = BLOCK_SIZE;
Asub.height = BLOCK_SIZE;
Asub.stride = A.stride;
Asub.elements = &A.elements[A.stride * BLOCK_SIZE * row
+ BLOCK_SIZE * col];
return Asub;
// Forward declaration of the matrix multiplication kernel
__global__ void MatMulKernel(const Matrix, const Matrix, Matrix);
// Matrix multiplication - Host code
// Matrix dimensions are assumed to be multiples of BLOCK_SIZE
void MatMul(const Matrix A, const Matrix B, Matrix C)
// Load A and B to device memory
Matrix d_A;
d_A.width = d_A.stride = A.width; d_A.height = A.height;
size_t size = A.width * A.height * sizeof(float);
cudaMalloc(&d_A.elements, size);
cudaMemcpy(d_A.elements, A.elements, size,
cudaMemcpyHostToDevice);
Matrix d_B;
d_B.width = d_B.stride = B.width; d_B.height = B.height;
size = B.width * B.height * sizeof(float);
cudaMalloc(&d_B.elements, size);
cudaMemcpy(d_B.elements, B.elements, size,
// Allocate C in device memory
Matrix d_C;
d_C.width = d_C.stride = C.width; d_C.height = C.height;
size = C.width * C.height * sizeof(float);
cudaMalloc(&d_C.elements, size);
// Invoke kernel
dim3 dimBlock(BLOCK_SIZE, BLOCK_SIZE);
dim3 dimGrid(B.width / dimBlock.x, A.height / dimBlock.y);
#ifndef SDYNAMIC
MatMulKernel<<<dimGrid, dimBlock>>>(d_A, d_B, d_C);
#else
MatMulKernel<<<dimGrid, dimBlock,sizeof(float)*BLOCK_SIZE*BLOCK_SIZE*2>>>(d_A, d_B, d_C);
#endif
// Read C from device memory
cudaMemcpy(C.elements, d_C.elements, size,
cudaMemcpyDeviceToHost);
// Free device memory
cudaFree(d_A.elements);
cudaFree(d_B.elements);
cudaFree(d_C.elements);
// Matrix multiplication kernel called by MatMul()
__global__ void MatMulKernel(Matrix A, Matrix B, Matrix C)
// Block row and column
int blockRow = blockIdx.y;
int blockCol = blockIdx.x;
// Each thread block computes one sub-matrix Csub of C
Matrix Csub = GetSubMatrix(C, blockRow, blockCol);
// Each thread computes one element of Csub
// by accumulating results into Cvalue
float Cvalue = 0;
// Thread row and column within Csub
int row = threadIdx.y;
int col = threadIdx.x;
// Loop over all the sub-matrices of A and B that are
// required to compute Csub
// Multiply each pair of sub-matrices together
// and accumulate the results
for (int m = 0; m < (A.width / BLOCK_SIZE); ++m) {
// Get sub-matrix Asub of A
Matrix Asub = GetSubMatrix(A, blockRow, m);
// Get sub-matrix Bsub of B
Matrix Bsub = GetSubMatrix(B, m, blockCol);
// Shared memory used to store Asub and Bsub respectively
#ifndef SDYNAMIC
__shared__ float As[BLOCK_SIZE][BLOCK_SIZE];
__shared__ float Bs[BLOCK_SIZE][BLOCK_SIZE];
#else
extern __shared__ float smem[];
sft *As = (sft *)(smem);
sft *Bs = (sft *)(smem+BLOCK_SIZE*BLOCK_SIZE);
#endif
// Load Asub and Bsub from device memory to shared memory
// Each thread loads one element of each sub-matrix
As[row][col] = GetElement(Asub, row, col);
Bs[row][col] = GetElement(Bsub, row, col);
// Synchronize to make sure the sub-matrices are loaded
// before starting the computation
__syncthreads();
// Multiply Asub and Bsub together
for (int e = 0; e < BLOCK_SIZE; ++e)
Cvalue += As[row][e] * Bs[e][col];
// Synchronize to make sure that the preceding
// computation is done before loading two new
// sub-matrices of A and B in the next iteration
__syncthreads();
// Write Csub to device memory
// Each thread writes one element
SetElement(Csub, row, col, Cvalue);
int main(){
Matrix A,B,C;
A.height = AROW;
A.width = ACOL;
B.height = ACOL;
B.width = BCOL;
C.height = AROW;
C.width = BCOL;
A.elements = new float[A.height*A.width]();
B.elements = new float[B.height*C.width]();
C.elements = new float[C.height*C.width]();
for (int i = 0; i < A.height*A.width; i++) A.elements[i] = TEST_VAL;
for (int i = 0; i < B.height*B.width; i++) B.elements[i] = TEST_VAL;
unsigned long dt = dtime_usec(0);
MatMul(A,B,C);
dt = dtime_usec(dt);
for (int i = 0; i < C.height*C.width; i++) if (C.elements[i] != (A.width*TEST_VAL*TEST_VAL)) {printf("mismatch at %d, was: %f, should be: %f\n", i, C.elements[i], (float)(A.width*TEST_VAL*TEST_VAL)); return 1;}
printf("elapsed time: %f\n", dt/(float)USECPSEC);
return 0;
$ nvcc -O3 -o t995 t995.cu
$ ./t995
elapsed time: 0.810462
$ nvcc -O3 -o t995 t995.cu -DSDYNAMIC
$ ./t995
elapsed time: 0.809575
