I’m getting a cudaErrorIllegalAddress error due to an illegal memory access on CUDA API call to cudaFree. cuda-memcheck identifies the cause of the error as the libcuda.so as shown below
========= Saved host backtrace up to driver entry point at error
========= Host Frame:/usr/lib/x86_64-linux-gnu/libcuda.so.1 [0x32f753]
========= Host Frame:/usr/lib/x86_64-linux-gnu/libcudart.so.8.0 (cudaFree + 0x186) [0x3de66]
========= Host Frame:./myProgram [0x12cb76]
========= Host Frame:./myProgram [0x15f645]
========= Host Frame:./myProgram [0x191416]
========= Host Frame:./myProgram [0x191161]
========= Host Frame:./myProgram [0x45ea9]
========= Host Frame:./myProgram [0x37523]
========= Host Frame:./myProgram [0x2cab7]
========= Host Frame:./myProgram [0x27718]
========= Host Frame:./myProgram [0x24c42]
========= Host Frame:./myProgram [0x20a64]
========= Host Frame:./myProgram [0x1f0bd]
========= Host Frame:./myProgram [0x1e8c7]
========= Host Frame:./myProgram [0x1e39a]
========= Host Frame:./myProgram [0x1c076]
========= Host Frame:./myProgram [0x1c043]
========= Host Frame:./myProgram [0x1bfc8]
========= Host Frame:/lib/x86_64-linux-gnu/libc.so.6 (__libc_start_main + 0xf1) [0x203f1]
========= Host Frame:./myProgram [0xbdfa]
The error was thrown after an attempt to free some memory. I have done an error check after my last kernel call, before the cudaFree call that threw the exception, but the check did not detect any errors.
I am at a loss as to how to proceed as the error does not point to any of my kernels but rather libcuda.so. Are such errors typical? What other debugging options should I be looking at in this case. BTW, I am running CUDA 8 (instead of CUDA 9) because I’ve got a Fermi GPU.
I will post a minimal example as as soon as I am able to (the actual code is somewhat complicated).
Update
Thinking that my kernel had accessed invalid memory I decided to try perform an allocate, memset and deallocation after my the kernel like so, hoping to
myKernel<<<1,1>>>();
int* d_test;
status = cudaMalloc( &d_test , 25 * sizeof(int) );
ERROR_CHECK( status ) // OK
status = cudaMemset( d_test , 25 * sizeof(int) , 0 );
status = cudaFree( d_test );
ERROR_CHECK( status ) // error
However the error occurs only on the cudaFree call. I’ve got several other cudaFree calls. The first cudaFree call always generates this error.
