I am trying to install caffe with gpu supported nvidia driver. I have nvidia GTX860M graphic card (msi GE702Pe Apache Pro computer with ubuntu Linux version 4.4.0-38-generic (kernel), (gcc version 4.8.4). When i try ‘make runtest’, i got the following error (I did Compilation with Make, yet i also got error with cmake one). On my software&Updates, it is written as: NVIDIA Corporation:Unknown (This device is using the recommended driver. It uses NVIDIA binary driver-version 352.63 from nvidia-352(proprietary, supported). I installed cuda as follows:
wget http://developer.download.nvidia.com/compute/cuda/7.5/Prod/local_installers/cuda-repo-ubuntu1404-7-5-local_7.5-18_amd64.deb
sudo dpkg -i cuda-repo-ubuntu1404-7-5-local_7.5-18_amd64.deb
sudo apt-get update
sudo apt-get install cuda
For opencv installation, I used the command: conda install opencv.
I would appreciate your help regarding to the solution of the following error. Thank you in advance.
The error of make runtest command for caffe installation
*[100%] Built target test.testbin
Scanning dependencies of target runtest
modprobe: FATAL: Module nvidia not found.
Cuda number of devices: 0
Current device id: 0
Current device name:
Note: Randomizing tests' orders with a seed of 445 .
[==========] Running 2021 tests from 267 test cases.
[----------] Global test environment set-up.
[----------] 5 tests from EmbedLayerTest/1, where TypeParam =
caffe::CPUDevice<double>
[ RUN ] EmbedLayerTest/1.TestSetUp
E0930 17:27:42.258497 14590 common.cpp:113] Cannot create Cublas
handle. Cublas won't be available.
E0930 17:27:42.263166 14590 common.cpp:120] Cannot create Curand
generator. Curand won't be available.
[ OK ] EmbedLayerTest/1.TestSetUp (9 ms)
[ RUN ] EmbedLayerTest/1.TestForward
[ OK ] EmbedLayerTest/1.TestForward (0 ms)
[ RUN ] EmbedLayerTest/1.TestForwardWithBias
[ OK ] EmbedLayerTest/1.TestForwardWithBias (111 ms)
[ RUN ] EmbedLayerTest/1.TestGradient
E0930 17:27:42.374208 14590 common.cpp:140] Curand not available.
Skipping setting the curand seed.
[ OK ] EmbedLayerTest/1.TestGradient (7 ms)
[ RUN ] EmbedLayerTest/1.TestGradientWithBias
[ OK ] EmbedLayerTest/1.TestGradientWithBias (11 ms)
[----------] 5 tests from EmbedLayerTest/1 (138 ms total)
[----------] 8 tests from SliceLayerTest/3, where TypeParam =
caffe::GPUDevice<double>
[ RUN ] SliceLayerTest/3.TestSetupNum
F0930 17:27:42.392833 14590 syncedmem.hpp:18] Check failed: error ==
cudaSuccess (38 vs. 0) no CUDA-capable device is detected
*** Check failure stack trace: ***
@ 0x2ac73c075daa (unknown)
@ 0x2ac73c075ce4 (unknown)
@ 0x2ac73c0756e6 (unknown)
@ 0x2ac73c078687 (unknown)
@ 0x2ac73b01b145 caffe::SyncedMemory::mutable_cpu_data()
@ 0x2ac73b091c48 caffe::Blob<>::Reshape()
@ 0x2ac73b0920a9 caffe::Blob<>::Reshape()
@ 0x2ac73b09213c caffe::Blob<>::Blob()
@ 0x8f2345
caffe::SliceLayerTest<>::SliceLayerTest()
@ 0x8f275b
testing::internal::TestFactoryImpl<>::CreateTest()
@ 0xd3ede3
testing::internal::HandleExceptionsInMethodIfSupported<>()
@ 0xd35785 testing::TestInfo::Run()
@ 0xd358a5 testing::TestCase::Run()
@ 0xd385f8
testing::internal::UnitTestImpl::RunAllTests()
@ 0xd38897 testing::UnitTest::Run()
@ 0x86e2ff main
@ 0x2ac741a75f45 (unknown)
@ 0x874ba2 (unknown)
@ (nil) (unknown)
make[3]:***[src/caffe/test/CMakeFiles/runtest] Aborted (core dumped)
make[2]:*** [src/caffe/test/CMakeFiles/runtest.dir/all] Error 2
make[1]:*** [src/caffe/test
