My graphic card is Geforce GTX 280, and the linux is 64 bit linux, after I installed the driver( 180.60 ) and Toolkit,SDK( CUDA 2.0 ), I compile the SDK and get the error:
cannot find -lcudart
How can do now? thanks
You should verify the common.mk file in the sdk_dir/common/common.mk
and enter the right cuda installation path
also make sure you have PATH and LD_LIBRARY_PATH set
looks something like this
PATH=/cuda/cuda/bin:$PATH
LD_LIBRARY_PATH=/cuda/cuda/lib:$LD_LIBRARY_PATH
then edit the /etc/ld.so.conf file
and make sure you have this entry
/cuda/cuda/lib # path should be set to your installation path
and run ldconfig
should work now
