Hi, I’m following the Getting started with CUDA on WSL2 guide.
I have WSL2 with Ubuntu 20.04.
However, at section 4.2.2 following command throws an error:
sudo apt-get update
Error:
Err:34 https://developer.download.nvidia.com/compute/cuda/repos/<distro>/x86_64 Release
404 Not Found [IP: 152.199.20.126 443]
Err:35 https://developer.download.nvidia.com/compute/cuda/repos/ubuntu/x86_64 Release
Err:36 https://developer.download.nvidia.com/compute/cuda/repos/ubuntu_20.04/x86_64 Release
Get:37 https://developer.download.nvidia.com/compute/cuda/repos/ubuntu2004/x86_64 Release [696 B]
Get:38 https://developer.download.nvidia.com/compute/cuda/repos/ubuntu2004/x86_64 Release.gpg [836 B]
Get:39 https://developer.download.nvidia.com/compute/cuda/repos/ubuntu2004/x86_64 Packages [554 kB]
Reading package lists... Done
E: The repository 'https://developer.download.nvidia.com/compute/cuda/repos/<distro>/x86_64 Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
Also, this command:
curl -s -L https://nvidia.github.io/nvidia-docker/$distribution/nvidia-docker.list | sudo tee /etc/apt/sources.list.d/nvidia-docker.list
does not list any Ubuntu 20.04:
deb https://nvidia.github.io/libnvidia-container/stable/ubuntu18.04/$(ARCH) /
#deb https://nvidia.github.io/libnvidia-container/experimental/ubuntu18.04/$(ARCH) /
deb https://nvidia.github.io/nvidia-container-runtime/stable/ubuntu18.04/$(ARCH) /
#deb https://nvidia.github.io/nvidia-container-runtime/experimental/ubuntu18.04/$(ARCH) /
deb https://nvidia.github.io/nvidia-docker/ubuntu18.04/$(ARCH) /
Something similar with the command to install docker:
curl https://get.docker.com | sh
error:
E: The repository 'https://developer.download.nvidia.com/compute/cuda/repos/ubuntu/x86_64 Release' does not have a Release file.
E: The repository 'https://developer.download.nvidia.com/compute/cuda/repos/ubuntu_20.04/x86_64 Release' does not have a Release file.
Could anyone help me here?
Might this be related to this post?
