CUDA pseudorandom number generator CURAND
Hello
I read the manual “CUDA Toolkit 4.0 CURAND Guide PG-05328-040_v01 | January 2011”
When I compile the source from my PC so I have to change path of cuda.h and curand.h
* This program uses the host CURAND API to generate 100
* pseudorandom floats .
# include "stdio.h"
# include "stdlib.h"
# include "../include/cuda.h"
# include "../include/curand.h"
# define CUDA_CALL (x) do { if ((x) != cudaSuccess ) { \
	printf (" Error at %s:%d\n", __FILE__ , __LINE__ );\
	return EXIT_FAILURE ;}} while (0)
# define CURAND_CALL (x) do { if ((x) != CURAND_STATUS_SUCCESS ) { \
	printf (" Error at %s:%d\n", __FILE__ , __LINE__ ); \
int main (int argc , char * argv [])
	size_t n = 100;
	size_t i;
	curandGenerator_t gen;
	float * devData , * hostData ;
	/* Allocate n floats on host */
	hostData = ( float *) calloc (n, sizeof ( float ));
	/* Allocate n floats on device */
	CUDA_CALL ( cudaMalloc (( void **)& devData , n * sizeof ( float )));	//HERE IS 26TH line
	/* Create pseudo - random number generator */
	CURAND_CALL ( curandCreateGenerator (& gen ,	CURAND_RNG_PSEUDO_DEFAULT ));
	/* Set seed */
	CURAND_CALL ( curandSetPseudoRandomGeneratorSeed (gen , 1234));	//HERE IS 32TH LINE
	/* Generate n floats on device */
	CURAND_CALL ( curandGenerateUniform (gen , devData , n));
	/* Copy device memory to host */
	CUDA_CALL ( cudaMemcpy ( hostData , devData , n * sizeof ( float ),
	cudaMemcpyDeviceToHost ));
	/* Show result */
	for(i = 0; i < n; i++) {
		printf ("%1.4 f ", hostData [i]);
	printf ("\ n");
	/* Cleanup */
	CURAND_CALL ( curandDestroyGenerator (gen));
	CUDA_CALL ( cudaFree ( devData ));
	free ( hostData );
	return EXIT_SUCCESS ;
I wonder the result.
C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v4.0\sarit>nvcc -arch=sm_13 c
udarand.cu
cudarand.cu
cudarand.cu(26): error: identifier "x" is undefined
cudarand.cu(26): error: expected a ";"
cudarand.cu(29): error: expected a ";"
cudarand.cu(32): error: expected a ";"
cudarand.cu(35): error: expected a ";"
cudarand.cu(38): error: expected a ";"
cudarand.cu(45): warning: unrecognized character escape sequence
cudarand.cu(48): error: expected a ";"
cudarand.cu(49): error: expected a ";"
cudarand.cu(19): warning: variable "gen" was declared but never referenced
cudarand.cu(20): warning: variable "devData" was declared but never referenced
8 errors detected in the compilation of "C:/Users/7-64/AppData/Local/Temp/tmpxft
_00000498_00000000-6_cudarand.cpp1.ii".
Here is my nvcc version. (If need)
C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v4.0\sarit>nvcc --version
Copyright (c) 2005-2011 NVIDIA Corporation
Built on Fri_May_13_01:41:59_PDT_2011
Cuda compilation tools, release 4.0, V0.2.1221
There is a “x” in the argument. So what does this mean ?
I deleted “ULL” at 32th line, even it does not relevant to 8 erros.
The line number has been shortened in order to view in compact page.
Where should I start to figure out the problem ?
Any help would be appreciated.
It looks like something is going wrong with the interpretation of the preprocessor macros you have. (That’s where the “x” is coming from, I assume.) I’m not sure what the problem is beyond that.
Thank you for your reply.
Is there anyboy got this problem please let me know.
My OS = M$ 7-64.
MS visual studio professional 2008.
TwT
I take a look at my classic book, “Numerical Recipe in C”
After that I try to use ran2() on GPU.
Badluck,
"static" is not allowed within a __device__ or __global__ function
External Image
I copy directory common from “CUDA by Example” and place in the toolkit
C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v4.0>dir
 Volume in drive C has no label.
 Volume Serial Number is F417-A0D2
Directory of C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v4.0
07/08/2011  03:11 AM    <DIR>          .
07/08/2011  03:11 AM    <DIR>          ..
06/28/2011  03:01 PM    <DIR>          bin
07/08/2011  03:11 AM    <DIR>          common
06/28/2011  03:01 PM    <DIR>          computeprof
06/28/2011  03:01 PM    <DIR>          doc
06/28/2011  03:01 PM    <DIR>          extras
06/28/2011  03:01 PM    <DIR>          include
06/28/2011  03:01 PM    <DIR>          lib
06/28/2011  03:01 PM    <DIR>          open64
07/08/2011  03:20 AM    <DIR>          sarit
06/28/2011  03:01 PM    <DIR>          src
               0 File(s)              0 bytes
In directory common you will found file book.h as uaual.
Therefore I modify my #include and get rid of the CUDA_CALL
C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v4.0\sarit>nvcc ridda.cu
ridda.cu
tmpxft_00001a00_00000000-3_ridda.cudafe1.gpu
tmpxft_00001a00_00000000-8_ridda.cudafe2.gpu
ridda.cu
tmpxft_00001a00_00000000-3_ridda.cudafe1.cpp
tmpxft_00001a00_00000000-14_ridda.ii
tmpxft_00001a00_00000000-15_ridda.obj : error LNK2019: unresolved external symbo
l curandDestroyGenerator referenced in function main
l curandGenerateUniform referenced in function main
l curandSetPseudoRandomGeneratorSeed referenced in function main
l curandCreateGenerator referenced in function main
a.exe : fatal error LNK1120: 4 unresolved externals
External Image
