CUDA reduction precision issues
Hello, I’ve been following this presentation made by Nvidia https://developer.download.nvidia.com/assets/cuda/files/reduction.pdf And I’m having some precision issues.
My kernel looks like this:
global void SummationReductionKernel(float* input, float* output, unsigned int count)
device void WarpReduce(volatile float* data, unsigned int tid)
    if (MAX_CUDA_THREADS_PER_BLOCK >= 64) data[tid] += data[tid + 32];
    if (MAX_CUDA_THREADS_PER_BLOCK >= 32) data[tid] += data[tid + 16];
    if (MAX_CUDA_THREADS_PER_BLOCK >= 16) data[tid] += data[tid + 8];
    if (MAX_CUDA_THREADS_PER_BLOCK >= 8)  data[tid] += data[tid + 4];
    if (MAX_CUDA_THREADS_PER_BLOCK >= 4)  data[tid] += data[tid + 2];
    if (MAX_CUDA_THREADS_PER_BLOCK >= 2)  data[tid] += data[tid + 1];
#define MAX_CUDA_THREADS_PER_BLOCK 512
    extern shared float sdata[MAX_CUDA_THREADS_PER_BLOCK];
    unsigned int tid = threadIdx.x;
    unsigned int i = blockIdx.x * (MAX_CUDA_THREADS_PER_BLOCK * 2) + tid;
    unsigned int gridSize = MAX_CUDA_THREADS_PER_BLOCK * 2 * gridDim.x;
    sdata[tid] = 0;
    while (i < count)
        sdata[tid] += input[i] + input[i + MAX_CUDA_THREADS_PER_BLOCK];
        i += gridSize;
    syncthreads();
    if (MAX_CUDA_THREADS_PER_BLOCK >= 512) { if (tid < 256) { sdata[tid] += sdata[tid + 256]; } syncthreads(); }
    if (MAX_CUDA_THREADS_PER_BLOCK >= 256) { if (tid < 128) { sdata[tid] += sdata[tid + 128]; } syncthreads(); }
    if (MAX_CUDA_THREADS_PER_BLOCK >= 128) { if (tid < 64)  { sdata[tid] += sdata[tid + 64];  } syncthreads(); }
    if (tid < 32) { WarpReduce(sdata, tid); }
    if (tid == 0)
        output[blockIdx.x] = sdata[0];
(I’ve pretty much just switched from ints to floats and removed the template)
After calling the kernel I copy the output back to host and add the individual parts together. This works for small arrays (< 10k elements), but for larger ones the results vary between host and device implementations. This wouldn’t be an issue if this was a floating point precision issue and I was getting tiny differences, but I’m getting differences in the 1000’s. Any ideas about how to solve this would be greatly appreciated :heart:
differences in the 1000’s might still be a floating-point issue depending on the input data. There isn’t any way to diagnose this without knowing what the input data is. For example, if every input point is 1000, then you are going to have differences in the thousands once you exceed around 16 million elements.
You may also have problems with this code depending on the grid size and the data set size. Here is a simple thought experiment. Suppose for a given iteration of the while loop, the calculated i variable is equal to count-1. Will this line be legal:
(hint: it will not)
For better help, I usually suggest providing a complete test case. Also, use the compute-sanitizer tool any time you are having trouble with a CUDA code.
