Hi All,
I did a simple test to see if there is checking on out-of-bound memory access on shared memory. What i did was quite simple that I allocated an integer array on shared memory and I tried to access to an element that already exceeds the size of the array (a lot). On my old Geforce 9400M there was nothing happened. I was able to access that invalid address and print the element out. I was guessing the hardware did something like modulus on the shared memory for out-of-bound access but based on my experiment the valid elements of the array were not affected.
Any idea of that?
Thank you in advance.
