I’m trying to create some static libraries to be used in a CUDA program, however I am getting a compiler error MSB3721L… exited with code 255. More specifically, here is the error:
[b]1>C:\Users\User\Documents\Visual Studio 2013\Projects\Test CUDA App\Test CUDA App>"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v7.5\bin\nvcc.exe" -dlink -o "x64\Debug\Test CUDA App.device-link.obj" -Xcompiler "/EHsc /W3 /nologo /Od /Zi /RTC1 /MDd " -L"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v7.5\lib\x64" -L"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v7.5\lib\x64" -LD:\Libs D:\Libs\deviceLib.lib cudart.lib kernel32.lib user32.lib gdi32.lib winspool.lib comdlg32.lib advapi32.lib shell32.lib ole32.lib oleaut32.lib uuid.lib odbc32.lib odbccp32.lib -gencode=arch=compute_30,code=sm_30 -G --machine 64 x64\Debug\kernel.cu.obj
1>CUDALINK : nvlink error : Undefined reference to '_Z16devFunctionff' in 'x64/Debug/kernel.cu.obj'[/b]
The codes are very simple, and copy/pasted form supposedly working examples I found online. Here are the two files that I use for creating the static library:
deviceLib.h
#ifdef __CUDACC__
#define CUDADEV __host__ __device__
#else
#define CUDADEV
#endif
extern CUDADEV float devFunction(float a, float b);
deviceLib.cu
#include "deviceLib.h"
CUDADEV float devFunction(float a, float b) {
return a + b;
This compiles fine, and creates the deviceLib.lib file. In a completely separate CUDA application, I have the following:
kernel.cu
#include "cuda_runtime.h"
#include "device_launch_parameters.h"
__global__ void simpleAdd(float a, float b, float * target)
*target = devFunction(a, b);
int main()
float hostTarget;
float * devTarget;
cudaMalloc((void**)&devTarget, sizeof(float));
simpleAdd << < 1, 1 >> > (5, 5, devTarget);
cudaMemcpy(&hostTarget, devTarget, sizeof(float), cudaMemcpyDeviceToHost);
return 0;
For which the .lib file is in, inside of the project configuration properties, I have added the directory for the VC++ Directories, added it to the Linker->Input->Addition Dependencies, Generated Relocatable Device Code = True, Perform Device Link = Yes.
What am I missing to get this CUDA application linked to the deviceLib? IntelliSense also picks up on it. Thanks in advance.
