I have a problem with run my c++ tensorflow app in TX2 directly after reboot.
normally I build app by bazel build
bazel build -c opt --local_resources 3072,4.0,1.0 --verbose_failures --config=monolithic //tensorflow/app/...
after build, when i execute
bazel-bin/tensorflow/app/run
everything is work perfectly but, when I reboot TX2 and execute firstly bazel-bin I have spam of this errors.
May 11 12:29:05 tegra-ubuntu start.sh[800]: 2018-05-11 12:29:04.622723: E tensorflow/stream_executor/cuda/cuda_driver.cc:967] failed to alloc 2304 bytes on host: CUDA_ERROR_UNKNOWN
May 11 12:29:05 tegra-ubuntu start.sh[800]: 2018-05-11 12:29:04.622849: E tensorflow/stream_executor/cuda/cuda_driver.cc:967] failed to alloc 2304 bytes on host: CUDA_ERROR_UNKNOWN
I guess that is a problem in loaded packages. When bazel build is executing before bazel-run, loading packages is correct.
There is a way to only load missing packages without earlier building? I need to run app imidiatly after start but my building process is to long to building before run app :(
