Hello everyone!
I have started working with cuda streams and keep getting very puzzling results. I’m testing the very basic examples of asynchronous methods (both can be found here How to Overlap Data Transfers in CUDA C/C++ | NVIDIA Technical Blog) and running them on GeForce GTX 760 (compute capability 3).
It the official documentation it says, the best overlap is for the cycle of the type
for (int i = 0; i < nStreams; ++i) {
int offset = i * streamSize;
checkCuda(cudaMemcpyAsync(&d_a[offset], &a[offset],
streamBytes, cudaMemcpyHostToDevice,
stream[i]));
kernel << <streamSize / blockSize, blockSize, 0, stream[i] >> >(d_a, offset);
checkCuda(cudaMemcpyAsync(&a[offset], &d_a[offset],
streamBytes, cudaMemcpyDeviceToHost,
stream[i]));
However, I’m not getting ANY overlap at all!
Moreover, I have tested the code on GeForce GTX 970 and it shows the best overlap for the cycle
stream[i]));
stream[i]));
I’m not sure how to treat such a divergence with the official recommendations.
Does anybody know where could be the reason for it?
Many thanks for your time and help!
Sofya
