I’m trying to overlap memcpy and kernel execution using streams. If I do it as in the Programmer’s Guide example - first start all in-copy operations, then all kernel calls, then all out-copy operations - it works:
[codebox] for(int i=0;i<stream_count;i++) {
int begin=vector_size*i/stream_count;
int end=vector_size*(i+1)/stream_count;
int size=end-begin;
// copy input vector to gpu //
cudaMemcpyAsync(vector_input_gpu+begin,vector_input_cpu+begi
n,
size*sizeof(float),
cudaMemcpyHostToDevice,streams[i]);
int size=end-begin;
// cuda kernel call //
compute<<<30,32,0,streams[i]>>>(vector_input_gpu+begin,
vector_output_gpu+begin,
size);
int size=end-begin;
// copy output vector from gpu to cpu //
cudaMemcpyAsync(vector_output_cpu+begin,vector_output_gpu+be
gin,
size*sizeof(float),
cudaMemcpyDeviceToHost,streams[i]);
}[/codebox]
But I wonder why I cannot put everything in one loop - starting first all operations of stream0 then of stream1… - if try to do this it is as slow as the non-streamed version. It seems it doesn’t do any overlap then:
int size=end-begin;
n,
size*sizeof(float),
size);
gin,
size*sizeof(float),
}[/codebox]
Can someone explain this to me?
If I just combine in-copy and kernel or just kernel and out-copy in one loop it works fine, but not if I combine all three. I think this is really weird.
