Why the cuda kernel and copy do not overlap?
#include <cuda_runtime.h>
#include <iostream>
__global__ void kernel(int* data, int value, int iterations) {
    int idx = threadIdx.x;
    for (int i = 0; i < iterations; ++i) {
        data[idx] += value;
int main() {
    const int numElements = 10 * 1024 * 1024;
    const int iterations = 1 << 20;
    const int numRounds = 10;
    int* devData1, * devData2;
    int* hostData1, * hostData2;
    cudaMallocHost((void**)&hostData1, numElements * sizeof(int));
    cudaMallocHost((void**)&hostData2, numElements * sizeof(int));
    cudaMalloc((void**)&devData1, numElements * sizeof(int));
    cudaMalloc((void**)&devData2, numElements * sizeof(int));
    cudaStream_t stream1, stream2;
    cudaStreamCreate(&stream1);
    cudaStreamCreate(&stream2);
    kernel << <1, 1024, 0, stream1 >> > (devData1, 1, iterations);
    cudaStreamSynchronize(stream1);
    cudaMemcpyAsync(hostData1, devData1, numElements * sizeof(int), cudaMemcpyDeviceToHost, stream1);
    kernel << <1, 1024, 0, stream2 >> > (devData2, 2, iterations);
    cudaStreamSynchronize(stream2);
    cudaMemcpyAsync(hostData2, devData2, numElements * sizeof(int), cudaMemcpyDeviceToHost, stream2);
    std::cout << "Test completed." << std::endl;
    return 0;
win10
vs2022
cuda 12.6
The above demo code, hope stream1 in copy, stream2 can execute kernel to achieve overlap, but the test results do not achieve overlap. What is the reason?
I think some overlap between these two:
should be possible. When in a WDDM setting, it’s possible that WDDM is causing issues. I sometimes suggest that people try both settings of Hardware Accelerated GPU Scheduling setting, to see if either setting results in observing the desired overlap. You can simply take a google search of that term (Hardware Accelerated GPU Scheduling), take the first blog hit from Microsoft, and use that to guide your study.
