Cuda Thrust Custom function
How can I impliment this function in Thrust?
for (i=0;i<n;i++)
    if (i==pos)
        h1[i]=1/h1[i];
    else
        h1[i]=-h1[i]/value;
In CUDA I did it like:
__global__ void inverse_1(double* h1, double value, int pos, int N)
    int i = blockDim.x * blockIdx.x + threadIdx.x;
    if (i < N){
        if (i == pos)
            h1[i] = 1 / h1[i];
        else
            h1[i] = -h1[i] / value;
First you define a Functor for the transform, that includes pos and value and works with one h1-element and it’s index i as parameters.
struct InvertFunctor: thrust::binary_function<double, int, double> {
	int pos;
	double value;
	InvertFunctor(int pos_, double value_) :
		pos(pos_), value(value_) {
	__host__ __device__
	double operator()(double h1, int i) {
		if (i == pos)
			return 1 / h1;
		else
			return -h1 / value;
You use it with thrust’s binary transform on a device_vector h1 for example. A counting_iterator provides the indices.
thrust::transform(h1.begin(), h1.end(), thrust::make_counting_iterator(0), h1.begin(), InvertFunctor(pos, value));
thank you very much!!! One last thing if I wanted to pass another vector to copy values such as this?
for (i=0;i<n;i++)
    for (j=0;j<n;j++)
        y[i*n+j]=h1[i]*a1[pos*n+j];
Its still not clear to me how to pass values to the function created Thanks!
Once you want to input/output even more vectors it gets complicated. The zip_iterator is what you need. (Especially note the two examples linked in that section.)
However you might want to ponder first whether it’s really worth the effort at this level of complexity. A handwritten kernel will probably be much easier and possibly faster. You can even use it with your thrust vectors by unwrapping their pointers.
I have it in a Cuda kernel however I want to make my program use Thrust.
Yes but the arrays have different lengths
Okay, if you insist. I’d say this version with permutation_iterators should be clearest. Note: idx = i * n + j.
First a Functor to calculate h1’s indices i = idx/n.
struct Indexh1Functor: thrust::unary_function<int, int> {
	int n;
	Indexh1Functor(int n_) :
		n(n_) {
	__host__ __device__
	int operator()(int idx) {
		return idx / n;
Second a Functor to calculate a1’s indices pos * n + j with j = idx%n.
struct Indexa1Functor: thrust::unary_function<int, int> {
	int n;
	int pos;
	Indexa1Functor(int n_, int pos_) :
		n(n_), pos(pos_) {
	__host__ __device__
		return pos * n + idx % n;
But the call is probably quite obscure.
thrust::transform(
		thrust::make_permutation_iterator(
				h1.begin(),
				thrust::make_transform_iterator(
						Indexh1Functor(n))),
				h1.begin(),
						Indexh1Functor(n))) + n * n,
				a1.begin(),
						Indexa1Functor(n, pos))),
		y.begin(),
		thrust::multiplies<double>());
The permutation_iterators choose the elements from h1 and a1 by the indices we calculate with the Functors. The multiplication can then simply be done with thrust’s multiplies and outputted directly to y.
Thanks mate!
I m giving it a try right now External Image
