Hello I have this loop in C+, and I was trying to convert it to thrust but without getting the same results…
Any ideas?
thank you
C++ Code
for (i=0;i<n;i++)
for (j=0;j<n;j++)
values[i]=values[i]+(binv[i*n+j]*d[j]);
Thrust Code
thrust::fill(values.begin(), values.end(), 0);
thrust::transform(make_zip_iterator(make_tuple(
thrust::make_permutation_iterator(values.begin(), thrust::make_transform_iterator(thrust::make_counting_iterator(0), IndexDivFunctor(n))),
binv.begin(),
thrust::make_permutation_iterator(d.begin(), thrust::make_transform_iterator(thrust::make_counting_iterator(0), IndexModFunctor(n))))),
thrust::make_permutation_iterator(values.begin(), thrust::make_transform_iterator(thrust::make_counting_iterator(0), IndexDivFunctor(n))) + n,
binv.end(),
thrust::make_permutation_iterator(d.begin(), thrust::make_transform_iterator(thrust::make_counting_iterator(0), IndexModFunctor(n))) + n)),
function1()
Thrust Functions
struct IndexDivFunctor: thrust::unary_function<int, int>
int n;
IndexDivFunctor(int n_) : n(n_) {}
__host__ __device__
int operator()(int idx)
return idx / n;
struct IndexModFunctor: thrust::unary_function<int, int>
int n;
IndexModFunctor(int n_) : n(n_) {}
__host__ __device__
return idx % n;
struct function1
template <typename Tuple>
__host__ __device__
double operator()(Tuple v)
return thrust::get<0>(v) + thrust::get<1>(v) * thrust::get<2>(v);
